    Additional temp graph items
    Duet Web Control
    8
    12
    744
    • MartinNYHCundefined
      MartinNYHC
      Is it possible to add additional items to the temp graph which are don't configured via M308? For example the CPU temperature of the SBC.
        I thought MCU temp and other "Virtual" heaters could already be shown on the graph by adding them from the "extras" tab.
        https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Extra_view
        cosmowaveundefined 1 Reply Last reply Reply Quote 0
        • cosmowaveundefined
          cosmowave @Phaedrux
          @phaedrux I think, he means a connected Raspberry or something similar...
          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
            Phaedrux Moderator @cosmowave
            @cosmowave Ah yes, I think you're right.
            In that case your most direct option might be adding a thermistor to the pi cpu package to monitor, though I could see that being a plugin candidate in future. Anyone care to write it?
            MartinNYHCundefined 1 Reply Last reply Reply Quote 0
              MartinNYHC @Phaedrux
              @phaedrux said in Additional temp graph items:
              Monitoring the CPU temp is simple but adding additional data to the graph is the point 😉
              • o_lampeundefined
                o_lampe @MartinNYHC
                @martinnyhc
                Once you have defined the thermistor in config.g, you can click 'extras' in the tool window of DWC and select the new PI-temp sensor
                  MartinNYHC @o_lampe
                  @o_lampe said in Additional temp graph items:
                  @martinnyhc
                  Yes I know, but I would like to display data that deosn't come from a hardware sensor but for example from a script on the SBC.
                    jay_s_uk @MartinNYHC
                    @martinnyhc yea, its currently only items configured using M308.
                    Maybe @chrishamm can add it to his wishlist for the SBC?
                    leobgundefined 1 Reply Last reply Reply Quote 2
                    • leobgundefined
                      leobg @jay_s_uk
                      @jay_s_uk upvoting this - having SBC temperature displayed in DWC along with MCU would be very useful.
                      • Rushmere3Dundefined
                        Rushmere3D
                        Does anyone know why the "Drivers" for both a 6HC and 3HC show 0, when they are configured? Maybe I'm missing something?
                        This is what I have in config.g
                        M308 S11 Y"drivers" A"6HC Steppers"
                        M308 S13 Y"drivers" P"1.dummy" A"3HC Steppers"
                        Thanks
                        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                        • gloomyandyundefined
                          gloomyandy
                          @rushmere3d What are you expecting the drivers to show? The TMC driver temperature output does not show the actual temperature it is just a status report that basically says ok, hot, too hot. see: https://forum.duet3d.com/topic/18390/driver-temperature-display
                          Rushmere3Dundefined 1 Reply Last reply Reply Quote 1
                            Rushmere3D @gloomyandy
                            @gloomyandy oh ok, yeah I was expecting an actual temperature. Thanks.
