    Additional temp graph items
    Duet Web Control
    8
    12
    748
    • cosmowaveundefined
      cosmowave @Phaedrux
      @phaedrux I think, he means a connected Raspberry or something similar...
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        Phaedrux Moderator @cosmowave
        @cosmowave Ah yes, I think you're right.
        In that case your most direct option might be adding a thermistor to the pi cpu package to monitor, though I could see that being a plugin candidate in future. Anyone care to write it?
        MartinNYHCundefined 1 Reply Last reply Reply Quote 0
        • MartinNYHCundefined
          MartinNYHC @Phaedrux
          @phaedrux said in Additional temp graph items:
          Monitoring the CPU temp is simple but adding additional data to the graph is the point 😉
          • o_lampeundefined
            o_lampe @MartinNYHC
            @martinnyhc
            Once you have defined the thermistor in config.g, you can click 'extras' in the tool window of DWC and select the new PI-temp sensor
              MartinNYHC @o_lampe
              @o_lampe said in Additional temp graph items:
              @martinnyhc
              Yes I know, but I would like to display data that deosn't come from a hardware sensor but for example from a script on the SBC.
                jay_s_uk @MartinNYHC
                @martinnyhc yea, its currently only items configured using M308.
                Maybe @chrishamm can add it to his wishlist for the SBC?
                leobgundefined 1 Reply Last reply Reply Quote 2
                • leobgundefined
                  leobg @jay_s_uk
                  @jay_s_uk upvoting this - having SBC temperature displayed in DWC along with MCU would be very useful.
                  • Rushmere3Dundefined
                    Rushmere3D
                    Does anyone know why the "Drivers" for both a 6HC and 3HC show 0, when they are configured? Maybe I'm missing something?
                    This is what I have in config.g
                    M308 S11 Y"drivers" A"6HC Steppers"
                    M308 S13 Y"drivers" P"1.dummy" A"3HC Steppers"
                    Thanks
                    Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                    • gloomyandyundefined
                      gloomyandy
                      @rushmere3d What are you expecting the drivers to show? The TMC driver temperature output does not show the actual temperature it is just a status report that basically says ok, hot, too hot. see: https://forum.duet3d.com/topic/18390/driver-temperature-display
                      Rushmere3Dundefined 1 Reply Last reply Reply Quote 1
                        Rushmere3D @gloomyandy
                        @gloomyandy oh ok, yeah I was expecting an actual temperature. Thanks.
