    Smart Effector issue
    Smart effector for delta printers
    10
    87
    4.2k
    • tecnoundefined
      tecno @Phaedrux
      @phaedrux said in Smart Effector issue:
      @tecno said in Smart Effector issue:
      Where do I set hotend offset and where to set effector offset?
      Looking from front X0/Y0 effector is to left and the hotend is a bit left too.
      I'm not sure what you mean.
      G10 P0 X-4 Y0 Z0 ; set tool 0 axis offsets
      G10 P0 R0 S0
      Fixed offset issue
      • tecnoundefined
        tecno @dc42
        @dc42 said in Smart Effector issue:
        FWIW we've identified a modification to the Smart Effector version 3 that improves the signal-to-noise ratio, which in turn allows you to use a higher sensitivity unless fan noise etc. prevents that. The modification is to remove capacitor C8. This can be done using a soldering iron with a bit large enough to cover both pads. Alternatively, you could use a small twist drill bit to remove a thin sliver of copper around the adjacent via that connects one end of the capacitor to the ground plane.
        This image is as viewed from the top of the PCB, so you need to invert it when looking at the bottom.
        So far during my tests no fans are used, good to know when adding fans.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @tecno
          Still some issues with false trig = does not go down but LED lights up = trig.
          How to solve this?
            When and where was it purchased?
            tecnoundefined 2 Replies Last reply Reply Quote 0
            • tecnoundefined
              tecno @Phaedrux
              Warning: Skipping grid point X=40.0, Y=60.0 because Z probe cannot reach it
              37 points probed, min error -0.260, max error 0.240, mean -0.026, deviation 0.113
              Height map saved to file 0:/sys/heightmap.csv
              From where does this X=40.0, Y=60.0 coordinate originate?
              • tecnoundefined
                tecno @Phaedrux
                A few weeks ago via James
                • tecnoundefined
                  tecno @tecno
                  @phaedrux
                  And looks like that, had to go all way up to 2500 to get reliable trig.
                  Now on 3500 and the false trigs seems to be away, but need more testing to be sure.
                  Also Dive height affects this now on 5mm
                    dc42 administrators @tecno
                    @tecno have you tried the following to eliminate the false triggering:
                    • increase the R parameter in the M558 command, in case it is the previous XY move causing the spurious triggering;
                    • reduce the probing acceleration, because it may be the Z acceleration at the start of the probing move that causes the spurious triggering.
                    • tecnoundefined
                      tecno @dc42
                      Tried R0.8 still the issue +++ Will not go down to bed on all points !!!
                        Phaedrux Moderator @tecno
                        Assuming you're doing a G29 there, the grid spacing is determined by M557 in your config.g
                        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_mesh_bed
                        • tecnoundefined
                          tecno @Phaedrux
                          Thanks, now it gets a bit clearer.
                          • Barracuda72undefined
                            Barracuda72
                            after watching our vid our prob are the short rods...but makeing the effector mount wider just makes it softer..more bending while probing. Other problen, that i had on my Delta with faulty sensivity..heatbreak came loose...so it looses lots of sensivity.
                            About your Rods...when i designed my delta some years ago there where plently of sites to calculate things like Rod lenght...max angles of rods. Maybe DC42 still have some links to such a calculator. It would be much better to have longer rods..if its ok to loose some build height. Your construction is prone to effector tilts that affects the stability while probing
                            tecnoundefined 1 Reply Last reply Reply Quote 1
                            • tecnoundefined
                              tecno @Barracuda72
                              @barracuda72 said in Smart Effector issue:
                              The rods and the adapter are original Dreammaker OverLord PRO, going back to a larger/wider effector (original adapter) made the situation better. Only trying to get this old Delta printer functional with a bit more modern parts.
                              I am in a process of building a large Delta of 1.4m height and ~550mm print diameter, Rods 610mm long directly to Smart Effector via magnets.
                              tecnoundefined Barracuda72undefined rjenkinsgbundefined 3 Replies Last reply Reply Quote 0
                              • tecnoundefined
                                tecno @tecno
                                Can somebody show me how mesh.g is written? To be run with G29
                                Stephen6309undefined 1 Reply Last reply Reply Quote 0
                                • Stephen6309undefined
                                  Stephen6309 @tecno
                                  @tecno This is what I use.
                                  ; mesh.g
                                  ; called to load/make heightmap.csv
                                  M98 P"/macros/ResetBabystepping"
                                  M561       ; clear any bed transform
                                  while iterations < #move.axes & move.axes[iterations].visible
                                    if !move.axes[iterations].homed
                                       G28
                                       break
                                  G29 S1        ; load heightmap.csv
                                  if result > 1 ; make if it doesn't exist
                                  	G29 S0
                                  That {1} isn't in it.
                                  • tecnoundefined
                                    tecno @Stephen6309
                                    @stephen6309 said in Smart Effector issue:
                                    ; mesh.g
                                         G28
                                         break
                                    	G29 S0
                                    Not what I was looking for, below a mesh of small circles I want to probe But do not how to write that mesh.g file.
                                      Barracuda72 @tecno
                                      @tecno take a look at https://reprap.org/wiki/Delta_geometry and theres a minimum angle of the arms..and in your vid the angles looks smaller if you probe the outermost ppoints...and then you loose all the stability..for m it looks if the arms are too short or the build diameter is too big. make a small test and just probe with a smaller build plate diameter. Use http://www.escher3d.com/pages/wizards/wizardbed.php to get a bed.g and do the probing again...and look how stable the effector might be without probing in the air
                                      • tecnoundefined
                                        tecno @Barracuda72
                                        With 80mm probe radius I have just under 30° angle on rods. So the angle is well over recommended 20° minimum.
                                        Barracuda72undefined 1 Reply Last reply Reply Quote 0
                                          Barracuda72 @tecno
                                          @tecno in the vid..when you probe the oauter points the whol effector tilts..and dont trigger...i had the same...2 towers forces the effector on the buildplate and the 3rd tower cant stabilize it...mybe its a prob because we only have mag arms...im sure you need more than 20° if you use mag arms..
                                          its easy to try a smaller bed diameter in the bed.g and make a test...
                                          Its just the same probe that i had on my 300mm Delta
                                          • tecnoundefined
                                            tecno @Barracuda72
                                            Medicine is M558 P8 R0.45 C"probe+servo0" H5 F3500 T2500
