    Software bundle 3.4.0 stable released!
    Firmware installation
    24
    52
    5.9k
    • zaptaundefined
      zapta @chrishamm
      @chrishamm, do the extra plug-ins work with stand alone duet? (Asking because they have DSF in their path)
      jay_s_ukundefined 1 Reply Last reply Reply Quote 1
        jay_s_uk @zapta
        @zapta only the motion one is SBC only
        • Mike3Dundefined
          Mike3D
          Thanks for this update.
          I can see the thumbnails on the pc using webcontrol.
          But i see no thumbnails on the PanelDue.
          On the PanelDeu is the latest firmware 3.4.1-pre2.
          The slicer i have is Prusaslicer and thumbnails are 160x160.
          jjudeundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • jjudeundefined
            jjude @Mike3D
            @mike3d note: PanelDue can only use QOI format. PrusaSlicer 2.4.1 not creating yet QOI.
              dc42 administrators @Mike3D
              @mike3d you can get Windows and Mac binaries of a fork of Prusa Slicer that supports QOI format from https://github.com/n8bot/PrusaSlicer/releases/tag/version_2.5.0-alpha0%2Bn8-release1. This version also has the option to retrieve the machine parameters from the Duet via http, if you have configured it for upload via http. Thanks to user @bot for implementing all of this.
              bbergerundefined 1 Reply Last reply Reply Quote 3
              • chrishammundefined
                chrishamm administrators @fractalengineer
                @fractalengineer Have a look at the DSF upgrade notes for v3.3, it sounds like you missed them.
                Duet software engineer
                • bbergerundefined
                  bberger @dc42
                  @dc42 said in Software bundle 3.4.0 stable released!:
                  This is big news. Especially on the Duet integration part.
                  • zaptaundefined
                    zapta
                    Thanks @chrishamm, I was able to install the external input shaping plugin. Next will figure out how to use it.
                    BTW, if most of the external plugins are not DSF specific, maybe remove DSF from their path on github?
                    • botundefined
                      bot @bberger
                      @bberger I have submitted a Pull Request to PrusaSlicer to include those integrations: https://github.com/prusa3d/PrusaSlicer/pull/8087
                      n8bot opened this pull request in prusa3d/PrusaSlicer
                      open Fix RRF Time Estimates and Add "Get Machine Limits" button for Duet printer hosts #8087
                      *not actually a robot
                      1 Reply Last reply Reply Quote 6
                      • ctilley79undefined
                        ctilley79
                        Is there a roadmap for RRF 3.5 available? What will be its focus?
                        oliofundefined 1 Reply Last reply Reply Quote 1
                        • oliofundefined
                          oliof @ctilley79
                          @ctilley79 Looking at the Github commit history, independent gcode streams seems to be the main feature being developed right now.
                          ctilley79undefined 1 Reply Last reply Reply Quote 0
                          • StevenLundefined
                            StevenL
                            Failed up to Upgrade from 3.2.2 to 3.4.0
                            Wifi card is stuck in Starting mode. no actual IP working.
                            Help!
                            Do I need to revert back to 3.2.2 or reset back to factory or what?
                            Please advise
                              Phaedrux Moderator @StevenL
                              @stevenl said in Software bundle 3.4.0 stable released!:
                              Help!
                              Please advise
                              You may need to reflash the wifi module. Try sending M997 S1 from the USB terminal.
                                ctilley79 @oliof
                                @oliof I was hoping they would continue to work on input shaper implementation because I believe it still lags behind Klipper.
                                  dc42 administrators @ctilley79
                                  @ctilley79 said in Software bundle 3.4.0 stable released!:
                                  In what way? We are continuing work on the IS plugin to make it easier to use accelerometer data to tune IS.
                                  Argoundefined 1 Reply Last reply Reply Quote 0
                                  • Argoundefined
                                    Argo @dc42
                                    Differences I see compared to Klipper right now:
                                    • separate shaper frequency for each axis
                                    • automatic resonance testing (with a accelerometer): Klipper firmware generates vibrations from lower to higher frequencies and tests each shaper for it‘s effectiveness at each frequency. The results and recommendations are then displayed in a graph. It also recommends maximum acceleration values.
                                      Example:
                                    721e564d-2a11-405f-a5e4-4aaa59d925df-image.png https://www.klipper3d.org/img/calibrate-y.png
                                    dc42undefined 1 Reply Last reply Reply Quote 3
                                      dc42 administrators @Argo
                                      @argo separate shaper per axis is not only unnecessary (because the supported shapers cover frequency ranges of up to 3:1), it is a bad idea because if you use different shape on different axes then the motion of the axes will no longer be synchronised during acceleration and deceleration. This will result in print artefacts, for example on corners that are not aligned with the axes.
                                      I already said that we are continuing work on the input shaping plugin to make tuning IS easier.
                                      zaptaundefined 1 Reply Last reply Reply Quote 6
                                      • zaptaundefined
                                        zapta @dc42
                                        How about a single input shaping that is direction dependent? That is, some interpolation for angles between X only and Y only?
                                        (I don't know how input shaping works, just thinking loud).
                                          chrishamm administrators @zapta
                                          @zapta Applying two different input shapers on two axes has certain downsides so we decided it would be better to support only a single input shaper for two axes to damp both ringing frequencies.
                                          We have a first beta of a new input shaping plugin ready but we need to discuss a few more details internally before we eventually release it. I expect we'll publish it sometime this week.
                                          samlogan87undefined zaptaundefined 2 Replies Last reply Reply Quote 2
                                          • samlogan87undefined
                                            samlogan87 @chrishamm
                                            @chrishamm looking forward to this
                                            Custom Core-XY
