    Simple relay control... or not?
    43
    2.0k
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet @droftarts
      @droftarts I was half hoping it was 2 amps it would of simplified my wiring a fair bit!
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      • Nightowlundefined
        Nightowl @droftarts
        This post is deleted!
        • Nightowlundefined
          Nightowl @droftarts
          @droftarts said in Simple relay control... or not?:
          Just as a quick follow-up, this should work, then:
          M950 R0 C"out4+out7"
          ...with the relay wires connected to the pins of Out 7 and the Out 7-9 jumper between V_OUTLC2 and 12V?
          Thank you 👍
          jay_s_ukundefined alankilianundefined 2 Replies Last reply Reply Quote 1
            jay_s_uk @Nightowl
            @nightowl999 yep
            Nightowlundefined 1 Reply Last reply Reply Quote 0
            • Nightowlundefined
              Nightowl @jay_s_uk
              Spiffing, @jay_s_uk 😀 😀
              And then it will 'activate' with M3 and deactivate with M5.
              Thank you @jay_s_uk
              • alankilianundefined
                alankilian @Nightowl
                @nightowl999
                I just read the Amazon description for your relay-control module and it says it can be triggered by an Arduino using any voltage from 3 to 14 Volts, so you don't need to worry about drawing too much power from the onboard 12 Volt supply at all.
                Where did you read that it takes 2 Amps to drive the module? I'd like to verify that.
                • Nightowlundefined
                  Nightowl @alankilian
                  Erm, I didn't @alankilian. That was @jumpedwithbothfeet wishing it was 2A!
                    @nightowl999 said in Simple relay control... or not?:
                    OK, I got it.
                    It looks like you're in good shape!
                    Nightowlundefined 2 Replies Last reply Reply Quote 1
                    • Nightowlundefined
                      @alankilian
                      Yep. Just keep an eye out for a big cloud of smoke in SW England. If there is one, it didn't work 😱 😱
                        dc42 administrators @Nightowl
                        @nightowl999 have you considered using the Laser/VFD output to drive the relay module? It provides a 5V signal.
                        Nightowlundefined 1 Reply Last reply Reply Quote 1
                        • Nightowlundefined
                          Nightowl @dc42
                          My intention is to 'upgrade' to a milling motor in the not too distant future, @dc42, so I was going to leave the Laser/VFD output for that.
                          Doing it this way for now will support both my router and dust collector, and just the dust collector when I've saved enough for the MM.
                          • Nightowlundefined
                            @alankilian Ah, perhaps not.
                            I think I've missed something because, when I send the M3 code from the Console, I get the error:
                            M3
                            Error: M3: No P parameter and no active tool with spindle.
                            Am I supposed to configure this elsewhere in the config.g file?
                            Thank you
                              @nightowl999
                              From the GCODE page:
                              "It is an error if there is no tool active or the active tool does not have a spindle assigned and there is no P parameter provided to define which spindle this should be applied to."
                              Maybe you just need to select a tool using a T command? REFERENCE
                              Or you need to define a tool using M563 ?
                              • Nightowlundefined
                                @alankilian Oops, well I haven't defined a tool, so that's probably a good starting point!
                                Would it just be a case of adding a single line like this before the M950 line, then:
                                M563 P0 R0 S"Makita" ; assign spindle 0 to tool 0 and name it Makita
                                Thank you
                                • Nightowlundefined
                                  Nightowl
                                  I'm still having some difficulty getting this 'simple' thing to work, but I have made some progress, thanks to you guys on here!
                                  I've revisited my config.g file and come up with this to configure the relay:
                                  ; Makita and relay configuration
                                  M950 R0 C"out1+out8" ; enable router relay on out8
                                  M563 P0 S"Makita" R0 ; assign spindle 0 to tool 0 and name it Makita
                                  T0 ; select tool 0
                                  Now, when entering M3 in the command line I don't any errors at all - but the relay doesn't activate, so nothing happens.
                                  I know I'm getting there, but I must have missed something!
                                  Any further help would be appreciated.
                                  Thank you
                                  jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                    jay_s_uk @Nightowl
                                    @nightowl999 try adding L1 to the M950 and then sending M3 S1 rather than just M3
                                      droftarts administrators @Nightowl
                                      @nightowl999 Apologies if you have already stated this, I can't see it in the thread, but what firmware version are you on? Send M115 and post the response. Earlier versions of RRF 3.x dealt with assigning spindle outputs differently. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes/M453
                                      • Nightowlundefined
                                        Nightowl @droftarts
                                        Hi @droftarts.
                                        The result is...
                                        m115
                                        FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-03-15 18:57:26
                                        • Nightowlundefined
                                          Nightowl @jay_s_uk
                                          Tried that, @jay_s_uk, but got the following error:
                                          Error: M3: Requested spindle RPM out of range.
                                          I also tried S0, which didn't produce an error, but didn't operate the relay, either 😞
                                            jay_s_uk @Nightowl
                                            @nightowl999 ok, attempt 2.
                                            Remove the L1 from the M950.
                                            And just send something like M3 S4000 (I know we don't have RPM control)
