    Formbot Troodon RRF 3.1.1 Update
    Firmware installation
    22
    89
    8.8k
    • koreandiundefined
      koreandi
      Good morning together..
      I just got a Vivedino Trodoon 400.
      It ran with Duet 2.x and I wanted to upgrade it to an actual Duet Firmware.
      However.. After upgrading to 3.0 all seemed to work fine.
      After upgrading to 3.3 I got the same issues as reported by Guzzi.
      I should have read this topic before upgrading my system. 🙂
      I am not able to downgrade the Firmware to earlier FW releases.
      After uploading the Firmware the machine refuses to upgrade with error, something like that:
      M997 In-application programming binary Duet2_SDiap32_WiFiEth.bin not found
      Even if I manual put this file in to System it does not work.
      Any tipps or workflows how to downgrade back to 3.0?
      I have read different topics but it was too much input last night and I had to got to bed...
      greetings
      Andreas
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @koreandi
        @koreandi was already fixed. Try updating to 3.4B6
        All hail to @oliof who bought a formbot board only to solve the issue.
        koreandiundefined 2 Replies Last reply Reply Quote 1
        • koreandiundefined
          koreandi @PCR
          @PCR
          Sounds great. I didn´t considered any beta realeses till now.
          I will try that in the afternoon and will report about it.
          Thanks a lot.
          • koreandiundefined
            koreandi @PCR
            @pcr
            Hmm. I still don´t manage to get any other version installed.
            Still the same message:
            Error: M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
            koreandiundefined 1 Reply Last reply Reply Quote 0
            • koreandiundefined
              koreandi @koreandi
              @koreandi
              Okay.. I rerolled 3.3 and afterwards 3.4B6 worked...
              I will test the functions.
              Thanks a lot.
              • nomukaikiundefined
                nomukaiki
                With the RRF 3.4 these problems seem to have gone.
                Can this thread be marked as resolved to help anyone that is searching the forum?
                patate1684undefined 1 Reply Last reply Reply Quote 1
                • Phaedruxundefined Phaedrux has marked this topic as solved
                • patate1684undefined
                  patate1684 @nomukaiki
                  @nomukaiki I got a formbot Troodon and I am looking to updating the firmware. After reading this entire thread, from what I understand, i can safely update to RRF 3.4 and everything should work as intended. (With the appropriate changes to the config file of course). Am I correct ?
                    jay_s_uk @patate1684
                    @patate1684 that appears to be the long and short of it, yes
                    • TheBasedDogeundefined
                      TheBasedDoge
                      I updated my Troodon to Release 3.4.1 RC1 and it works but i have two issues
                      • When the printer first starts up, it says the motor phase error, but if i click ok it just seems to work.
                      • The screen won't connect anymore, it just says "connecting.." forever.
                      any ideas?
                      • oliofundefined
                        oliof @TheBasedDoge
                        @thebaseddoge the motor phase error in the beginning is due to the missing drivers in the board design. If they only happen during startup you have nothing to worry about.
                        For the display you may need to add an explicit M575 P0 B57600 at the end of config.g -- this wasn't required in earlier releases of RRF, but is required for the current ones.
                        TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
                          TheBasedDoge @oliof
                          @oliof said in Formbot Troodon RRF 3.1.1 Update:
                          l
                          thanks, unfortunately no go on on adding the M575 P0 B57600
                          It still says connecting. I confirmed the baudrate on the screen is set correctly.
                          also is there any way to surpresss the motor warning?
                          oliofundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          • oliofundefined
                            oliof @TheBasedDoge
                            @thebaseddoge the motor warning should go away if you disable them in config.g. But they may pop up at start before config.g is fully parsed.
                              Phaedrux Moderator @TheBasedDoge
                              @thebaseddoge said in Formbot Troodon RRF 3.1.1 Update:
                              M575 P0 B57600
                              Please try M575 P1 B57600 S1
                              You may also want to update your PanelDue firmware to 3.4 as well if you haven't already.
                              TheBasedDogeundefined 2 Replies Last reply Reply Quote 0
                                TheBasedDoge @Phaedrux
                                @phaedrux
                                Thanks I will try it and report back. unfortunately I now have to wait for a 10 hour print to finish to try it lol. I'll check the paneldue firmware too.
                                  @phaedrux said in Formbot Troodon RRF 3.1.1 Update:
                                  M575 P1 B57600 S1
                                  Thanks, this worked. I think it's all working now. I noticed the fans are running louder than before so that's next to figure out.
                                  nomukaikiundefined 1 Reply Last reply Reply Quote 1
                                  • jay_s_ukundefined jay_s_uk referenced this topic
                                  • droftartsundefined droftarts referenced this topic
                                    nomukaiki @TheBasedDoge
                                    @TheBasedDoge sorry to open this old topic, but only now I've upgraded my Troodon to 3.4.4.
                                    I'm also noticing that the fan to cool off the MCU is now constantly on at high speed, when on 3.0.0 it was controlled by temperature.
                                    Did you managed to fix yours?
                                    Thanks
                                      TheBasedDoge @nomukaiki
                                      Does anyone know how I can fix this? The printer works but on every bootup I still get this after updating to 3.4.4
                                      Driver 9 error: over temperature shutdown, phase A short to ground, phase B short to ground
                                      @nomukaiki
                                      Sorry I only saw this now. here is my fan config
                                      ; --- fans ---
                                      M950 F0 C"fan0" ; Fan 0 uses the Fan0 output
                                      M950 F1 C"fan1" ; Fan 1 uses the Fan1 output
                                      M950 F2 C"fan2" ; Fan 2 uses the Fan2 output
                                      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off - PART COOLING FAN
                                      M106 P1 S1 I0 F500 H1 T65 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on - HOTEND FAN
                                      ;M106 P2 S.35 I0 F500 H1 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on - CASE FAN
                                      ; --- Case Fan ---
                                      M950 P5 C"duex.fan7"
                                      M42 P5 S0.0 ;
                                      ; --- Controller Fan ---
                                      M950 P4 C"duex.fan8"
                                      M42 P4 S0.5 ;
                                        droftarts administrators @TheBasedDoge
                                        Add M569 P9 R-1 to your config.g to disable the driver. And don't worry about it.
                                          TheBasedDoge @droftarts
                                          @droftarts
                                          It looks like I already had that line in the config, so i guess i am just stuck with it. That's fine, will just ignore it.
                                            dc42 administrators @TheBasedDoge
                                            @TheBasedDoge said in Formbot Troodon RRF 3.1.1 Update:
                                            I presume the error is only reported once. You could try moving that line earlier in config.g if it isn't already near the start.
