    Formbot Troodon RRF 3.1.1 Update
    Firmware installation
    22
    89
    8.8k
    • PCRundefined
      PCR @koreandi
      @koreandi was already fixed. Try updating to 3.4B6
      All hail to @oliof who bought a formbot board only to solve the issue.
      koreandiundefined 2 Replies Last reply Reply Quote 1
      • koreandiundefined
        koreandi @PCR
        @PCR
        Sounds great. I didn´t considered any beta realeses till now.
        I will try that in the afternoon and will report about it.
        Thanks a lot.
        • koreandiundefined
          koreandi @PCR
          @pcr
          Hmm. I still don´t manage to get any other version installed.
          Still the same message:
          Error: M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found
          koreandiundefined 1 Reply Last reply Reply Quote 0
          • koreandiundefined
            koreandi @koreandi
            @koreandi
            Okay.. I rerolled 3.3 and afterwards 3.4B6 worked...
            I will test the functions.
            Thanks a lot.
            • nomukaikiundefined
              nomukaiki
              With the RRF 3.4 these problems seem to have gone.
              Can this thread be marked as resolved to help anyone that is searching the forum?
              patate1684undefined 1 Reply Last reply Reply Quote 1
              • Phaedruxundefined Phaedrux has marked this topic as solved
              • patate1684undefined
                patate1684 @nomukaiki
                @nomukaiki I got a formbot Troodon and I am looking to updating the firmware. After reading this entire thread, from what I understand, i can safely update to RRF 3.4 and everything should work as intended. (With the appropriate changes to the config file of course). Am I correct ?
                  jay_s_uk @patate1684
                  @patate1684 that appears to be the long and short of it, yes
                  • TheBasedDogeundefined
                    TheBasedDoge
                    I updated my Troodon to Release 3.4.1 RC1 and it works but i have two issues
                    • When the printer first starts up, it says the motor phase error, but if i click ok it just seems to work.
                    • The screen won't connect anymore, it just says "connecting.." forever.
                    any ideas?
                    • oliofundefined
                      oliof @TheBasedDoge
                      @thebaseddoge the motor phase error in the beginning is due to the missing drivers in the board design. If they only happen during startup you have nothing to worry about.
                      For the display you may need to add an explicit M575 P0 B57600 at the end of config.g -- this wasn't required in earlier releases of RRF, but is required for the current ones.
                      TheBasedDogeundefined 1 Reply Last reply Reply Quote 0
                        TheBasedDoge @oliof
                        @oliof said in Formbot Troodon RRF 3.1.1 Update:
                        l
                        thanks, unfortunately no go on on adding the M575 P0 B57600
                        It still says connecting. I confirmed the baudrate on the screen is set correctly.
                        also is there any way to surpresss the motor warning?
                        oliofundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        • oliofundefined
                          oliof @TheBasedDoge
                          @thebaseddoge the motor warning should go away if you disable them in config.g. But they may pop up at start before config.g is fully parsed.
                            Phaedrux Moderator @TheBasedDoge
                            @thebaseddoge said in Formbot Troodon RRF 3.1.1 Update:
                            M575 P0 B57600
                            Please try M575 P1 B57600 S1
                            You may also want to update your PanelDue firmware to 3.4 as well if you haven't already.
                            TheBasedDogeundefined 2 Replies Last reply Reply Quote 0
                              TheBasedDoge @Phaedrux
                              @phaedrux
                              Thanks I will try it and report back. unfortunately I now have to wait for a 10 hour print to finish to try it lol. I'll check the paneldue firmware too.
                                @phaedrux said in Formbot Troodon RRF 3.1.1 Update:
                                M575 P1 B57600 S1
                                Thanks, this worked. I think it's all working now. I noticed the fans are running louder than before so that's next to figure out.
                                nomukaikiundefined 1 Reply Last reply Reply Quote 1
                                • jay_s_ukundefined jay_s_uk referenced this topic
                                • droftartsundefined droftarts referenced this topic
                                  nomukaiki @TheBasedDoge
                                  @TheBasedDoge sorry to open this old topic, but only now I've upgraded my Troodon to 3.4.4.
                                  I'm also noticing that the fan to cool off the MCU is now constantly on at high speed, when on 3.0.0 it was controlled by temperature.
                                  Did you managed to fix yours?
                                  Thanks
                                    TheBasedDoge @nomukaiki
                                    Does anyone know how I can fix this? The printer works but on every bootup I still get this after updating to 3.4.4
                                    Driver 9 error: over temperature shutdown, phase A short to ground, phase B short to ground
                                    @nomukaiki
                                    Sorry I only saw this now. here is my fan config
                                    ; --- fans ---
                                    M950 F0 C"fan0" ; Fan 0 uses the Fan0 output
                                    M950 F1 C"fan1" ; Fan 1 uses the Fan1 output
                                    M950 F2 C"fan2" ; Fan 2 uses the Fan2 output
                                    M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off - PART COOLING FAN
                                    M106 P1 S1 I0 F500 H1 T65 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on - HOTEND FAN
                                    ;M106 P2 S.35 I0 F500 H1 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on - CASE FAN
                                    ; --- Case Fan ---
                                    M950 P5 C"duex.fan7"
                                    M42 P5 S0.0 ;
                                    ; --- Controller Fan ---
                                    M950 P4 C"duex.fan8"
                                    M42 P4 S0.5 ;
                                      droftarts administrators @TheBasedDoge
                                      Add M569 P9 R-1 to your config.g to disable the driver. And don't worry about it.
                                        TheBasedDoge @droftarts
                                        @droftarts
                                        It looks like I already had that line in the config, so i guess i am just stuck with it. That's fine, will just ignore it.
                                          dc42 administrators @TheBasedDoge
                                          @TheBasedDoge said in Formbot Troodon RRF 3.1.1 Update:
                                          I presume the error is only reported once. You could try moving that line earlier in config.g if it isn't already near the start.
                                            TheBasedDoge @dc42
                                            @dc42 It's only on bootup. I tried putting that line at the very beginning of the config, but no change. I guess config is not being loaded fast enough before it pops the error?
