    12864 display (ST7920) on Duet 3 Mini5+
    31
    4.3k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @kgolger
      @kgolger
      The input will not match directly by plug. You have to wire them pin by pin.
      @PCR also provides a wired version
      (UTC+1)
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
        DIY-O-Sphere @DIY-O-Sphere
        Thanks to the support of @pcr i was able to replace my prototype board.
        Finally a clean wiring!
        (UTC+1)
        tecnoundefined 1 Reply Last reply Reply Quote 1
        • DIY-O-Sphereundefined DIY-O-Sphere referenced this topic
        • tecnoundefined
          tecno @DIY-O-Sphere
          @DIY-O-Sphere
          Hello , just got adapterboards from PCR and I can not get things to work OK here.
          Connected as below picture No shorts on 3-pin.
          M918 P1 E-4 F1999999
          M575 P1 S0 B57600 ; enable support for PanelDue
          M550 P"BigDelta"
            DIY-O-Sphere @tecno
            @tecno
            As far as I can tell, the cables on the display are plugged in backwards. I think the noses on the plugs are under the cable and look upwards. But the noses must be above the white boxes.
            (UTC+1)
            tecnoundefined 1 Reply Last reply Reply Quote 0
            • tecnoundefined
              tecno @DIY-O-Sphere
              @DIY-O-Sphere
              No go that way either. (Funny thing is that the display had the nose notches the other way! from factory)
              S O R R Y MY BAD Now working
                DIY-O-Sphere @tecno
                @tecno
                The jumper is only required to enable the sd-card reader.
                (UTC+1)
                • tecnoundefined
                  tecno @DIY-O-Sphere
                  @DIY-O-Sphere
                  OK, what pins?
                    DIY-O-Sphere @tecno
                    @tecno
                    For the Mini you can shorten CD_LCD and CD_D pin with the jumper.
                    (UTC+1)
                    • PCRundefined
                      PCR
                      Just a information.
                      Have some left if somebody wants
                      repier37undefined 1 Reply Last reply Reply Quote 1
                      • repier37undefined
                        repier37 @PCR
                        @PCR I know this is old post, but if you have some left, I am interested
                        • chrishammundefined chrishamm referenced this topic
