    12864 display (ST7920) on Duet 3 Mini5+
    31
    3.6k
    • PCRundefined
      PCR @MatixYo
      @matixyo
      6€ with connectors.
      4€ untracked shipping. 7€ tracked
      MatixYoundefined Giannivoxundefined 2 Replies Last reply Reply Quote 0
      • MatixYoundefined
        MatixYo @PCR
        @pcr not bad
        • Giannivoxundefined
          Giannivox @PCR
          @pcr Hi, adapters in compatible with mks mini12864 v2.1?
          thanks
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
          • DIY-O-Sphereundefined
            DIY-O-Sphere @Giannivox
            @giannivox
            If the LCD has a ST7567 chip, the adapter is not required.
            (UTC+1)
            • kgolgerundefined
              kgolger @PCR
              @pcr
              Does the adapter also work with a Duet2 Wifi (Ref. 1.04, Firmware 3.3)?
              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                DIY-O-Sphere @kgolger
                @kgolger
                The input will not match directly by plug. You have to wire them pin by pin.
                @PCR also provides a wired version
                (UTC+1)
                  DIY-O-Sphere @DIY-O-Sphere
                  Thanks to the support of @pcr i was able to replace my prototype board.
                  Finally a clean wiring!
                  (UTC+1)
                  tecnoundefined 1 Reply Last reply Reply Quote 1
                  • DIY-O-Sphereundefined DIY-O-Sphere referenced this topic
                  • tecnoundefined
                    tecno @DIY-O-Sphere
                    @DIY-O-Sphere
                    Hello , just got adapterboards from PCR and I can not get things to work OK here.
                    Connected as below picture No shorts on 3-pin.
                    M918 P1 E-4 F1999999
                    M575 P1 S0 B57600 ; enable support for PanelDue
                    M550 P"BigDelta"
                      DIY-O-Sphere @tecno
                      @tecno
                      As far as I can tell, the cables on the display are plugged in backwards. I think the noses on the plugs are under the cable and look upwards. But the noses must be above the white boxes.
                      (UTC+1)
                      tecnoundefined 1 Reply Last reply Reply Quote 0
                      • tecnoundefined
                        tecno @DIY-O-Sphere
                        @DIY-O-Sphere
                        No go that way either. (Funny thing is that the display had the nose notches the other way! from factory)
                        S O R R Y MY BAD Now working
                          DIY-O-Sphere @tecno
                          @tecno
                          The jumper is only required to enable the sd-card reader.
                          (UTC+1)
                          • tecnoundefined
                            tecno @DIY-O-Sphere
                            @DIY-O-Sphere
                            OK, what pins?
                              DIY-O-Sphere @tecno
                              @tecno
                              For the Mini you can shorten CD_LCD and CD_D pin with the jumper.
                              (UTC+1)
                              • PCRundefined
                                PCR
                                Just a information.
                                Have some left if somebody wants
                                repier37undefined 1 Reply Last reply Reply Quote 1
                                • repier37undefined
                                  repier37 @PCR
                                  @PCR I know this is old post, but if you have some left, I am interested
                                  • chrishammundefined chrishamm referenced this topic
