    12864 display (ST7920) on Duet 3 Mini5+
    31
    3.6k
    • PCRundefined
      PCR @PCR
      @pcr
      The adapters are here and they work. I tested it with the classic Display, the BTT 35 and the BTT 70.
      Please PN if you want one! You can choose between a plugin type or a "extension" one 😉 For plugin see the image above
      WhatsApp Image 2021-07-05 at 10.41.58.jpeg WhatsApp Image 2021-07-05 at 10.41.584.jpeg WhatsApp Image 2021-07-05 at 10.41.585.jpeg
      MatixYoundefined 1 Reply Last reply Reply Quote 3
      • MatixYoundefined
        MatixYo @PCR
        @pcr how much is it?
        PCRundefined 1 Reply Last reply Reply Quote 0
        • PCRundefined
          PCR @MatixYo
          @matixyo
          6€ with connectors.
          4€ untracked shipping. 7€ tracked
          MatixYoundefined Giannivoxundefined 2 Replies Last reply Reply Quote 0
          • MatixYoundefined
            MatixYo @PCR
            @pcr not bad
            • Giannivoxundefined
              Giannivox @PCR
              @pcr Hi, adapters in compatible with mks mini12864 v2.1?
              thanks
              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
              • DIY-O-Sphereundefined
                DIY-O-Sphere @Giannivox
                @giannivox
                If the LCD has a ST7567 chip, the adapter is not required.
                (UTC+1)
                • kgolgerundefined
                  kgolger @PCR
                  @pcr
                  Does the adapter also work with a Duet2 Wifi (Ref. 1.04, Firmware 3.3)?
                  DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                    DIY-O-Sphere @kgolger
                    @kgolger
                    The input will not match directly by plug. You have to wire them pin by pin.
                    @PCR also provides a wired version
                    (UTC+1)
                      DIY-O-Sphere @DIY-O-Sphere
                      Thanks to the support of @pcr i was able to replace my prototype board.
                      Finally a clean wiring!
                      (UTC+1)
                      tecnoundefined 1 Reply Last reply Reply Quote 1
                      • DIY-O-Sphereundefined DIY-O-Sphere referenced this topic
                      • tecnoundefined
                        tecno @DIY-O-Sphere
                        @DIY-O-Sphere
                        Hello , just got adapterboards from PCR and I can not get things to work OK here.
                        Connected as below picture No shorts on 3-pin.
                        M918 P1 E-4 F1999999
                        M575 P1 S0 B57600 ; enable support for PanelDue
                        M550 P"BigDelta"
                          DIY-O-Sphere @tecno
                          @tecno
                          As far as I can tell, the cables on the display are plugged in backwards. I think the noses on the plugs are under the cable and look upwards. But the noses must be above the white boxes.
                          (UTC+1)
                          tecnoundefined 1 Reply Last reply Reply Quote 0
                          • tecnoundefined
                            tecno @DIY-O-Sphere
                            @DIY-O-Sphere
                            No go that way either. (Funny thing is that the display had the nose notches the other way! from factory)
                            S O R R Y MY BAD Now working
                              DIY-O-Sphere @tecno
                              @tecno
                              The jumper is only required to enable the sd-card reader.
                              (UTC+1)
                              • tecnoundefined
                                tecno @DIY-O-Sphere
                                @DIY-O-Sphere
                                OK, what pins?
                                  DIY-O-Sphere @tecno
                                  @tecno
                                  For the Mini you can shorten CD_LCD and CD_D pin with the jumper.
                                  (UTC+1)
                                  • PCRundefined
                                    PCR
                                    Just a information.
                                    Have some left if somebody wants
                                    repier37undefined 1 Reply Last reply Reply Quote 1
                                    • repier37undefined
                                      repier37 @PCR
                                      @PCR I know this is old post, but if you have some left, I am interested
                                      • chrishammundefined chrishamm referenced this topic
