    Auto pressure advance turning by hotend pressure
    35
    3.0k
    • PenguinAkikoundefined
      PenguinAkiko
      https://cdn.discordapp.com/attachments/800676015776858152/1155449596068253727/D3ACB29F2817F93C0817BAF0AA8F404D.mov
        PenguinAkiko @PenguinAkiko
        a1 mini use pcb coil
          T3P3Tony administrators @PenguinAkiko
          @penguinya what inductance are they measuring to determine pressure for pressure advance calibration?
          o_lampeundefined PenguinAkikoundefined 3 Replies Last reply Reply Quote 0
          • o_lampeundefined
            o_lampe @T3P3Tony
            @T3P3Tony
            It's probably the filament that bends in a certain direction when pressure increases. They could design the filament path in such way, that it bends in a predictable way.
            But that would highly depend on the stiffness of the filament and would need a calibration with temp-compensation
              PenguinAkiko @T3P3Tony
              @T3P3Tony Same as the string gauge, it looks like the hotend can move up and down
                PenguinAkiko
                RP2040 have two core and fust enough ADC to measure string gauge.
                I think it can save pressure data to calculate pressure curve
                PenguinAkikoundefined 1 Reply Last reply Reply Quote 0
                    @T3P3Tony found some articles https://airtripper.com/1338/airtripper-extruder-filament-force-sensor-introduction/
                      PenguinAkiko
                      15 minutes, 16 seconds to 17 seconds, the hotend moves up and down.
                      https://www.youtube.com/watch?v=EZ3BtQ7k9Ak
                      • nikschaundefined
                        nikscha
                        I love the idea!
                        I guess you could write a gcode snippet in daemon.g which continously reads straingauge values and adjusts pressure advance values?
                        Duet can read sensors via SPI, maybe a dedicated "strain gauge sensor" option would be possible? One could also put together a small PCB that amplifies the strain gauge reading into a voltage that can just be read by a linear analog sensor on the Duet?
                        Stay in school
                          PenguinAkiko @nikscha
                          @nikscha macro not fast enough, and this is my idea https://forum.duet3d.com/post/324006
                          nikschaundefined 1 Reply Last reply Reply Quote 0
                            PenguinAkiko
                            Automated PA testing is still an early idea. I hope to implement z probe and collect enough PA pressure data for research.
                            • nikschaundefined
                              nikscha @PenguinAkiko
                              @penguinya I think it would be fast enough. Just put a "while true" into daemon.g and then a G4 P50 in the body to execute your script every 50ms. (Edit: this wouldn't actually run that frequent, more like 3-6 times a second)
                              I don't think pressure advance needs to be adjusted that often, right?
                              Stay in school
                              PenguinAkikoundefined 2 Replies Last reply Reply Quote 0
                                @nikscha Bambu Lab tests pa every print, and 50ms really slow, HX711 can reach 80HZ, Prusa using HX717 320HZ, higher the sampling frequency, the more beneficial for auto PA testing.
                                  PenguinAkiko
                                  find a better chip for load cell.
                                  CS1237 http://www.asidesigner.com/Files/PartFiles/15315/222/cs1237_datasheet.pdf
                                  spi bus 1.28kHz ADC and PGA
                                    @nikscha Here is a post about sampling speed
                                    https://forum.duet3d.com/post/251488
                                      PenguinAkiko
                                      https://wiki.bambulab.com/en/a1/manual/intro-a1
                                        @penguinya The introduction of bambulab confirmed my guess.
                                        • Charlieundefined
                                          Charlie
                                          Correct me if Im wrong, but I feel like this sensor could also be used for filament runout/jam detection as well. Like if the force expected by feeding the filament is not produced, it could indicate that there is some filament error.
                                          PenguinAkikoundefined Richard Fundefined 2 Replies Last reply Reply Quote 0
                                            PenguinAkiko @Charlie
                                            @Charlie Yes prusa has implemented it
                                            Charlieundefined MJLewundefined 2 Replies Last reply Reply Quote 0
