    Auto pressure advance turning by hotend pressure
    35
    3.0k
    • PenguinAkikoundefined
      PenguinAkiko
      RP2040 have two core and fust enough ADC to measure string gauge.
      I think it can save pressure data to calculate pressure curve
      PenguinAkikoundefined 1 Reply Last reply Reply Quote 0
        PenguinAkiko @PenguinAkiko
          PenguinAkiko @T3P3Tony
          @T3P3Tony found some articles https://airtripper.com/1338/airtripper-extruder-filament-force-sensor-introduction/
            PenguinAkiko
            15 minutes, 16 seconds to 17 seconds, the hotend moves up and down.
            https://www.youtube.com/watch?v=EZ3BtQ7k9Ak
            • nikschaundefined
              nikscha
              I love the idea!
              I guess you could write a gcode snippet in daemon.g which continously reads straingauge values and adjusts pressure advance values?
              Duet can read sensors via SPI, maybe a dedicated "strain gauge sensor" option would be possible? One could also put together a small PCB that amplifies the strain gauge reading into a voltage that can just be read by a linear analog sensor on the Duet?
              Stay in school
                PenguinAkiko @nikscha
                @nikscha macro not fast enough, and this is my idea https://forum.duet3d.com/post/324006
                nikschaundefined 1 Reply Last reply Reply Quote 0
                  PenguinAkiko
                  Automated PA testing is still an early idea. I hope to implement z probe and collect enough PA pressure data for research.
                  • nikschaundefined
                    nikscha @PenguinAkiko
                    @penguinya I think it would be fast enough. Just put a "while true" into daemon.g and then a G4 P50 in the body to execute your script every 50ms. (Edit: this wouldn't actually run that frequent, more like 3-6 times a second)
                    I don't think pressure advance needs to be adjusted that often, right?
                    Stay in school
                    PenguinAkikoundefined 2 Replies Last reply Reply Quote 0
                      @nikscha Bambu Lab tests pa every print, and 50ms really slow, HX711 can reach 80HZ, Prusa using HX717 320HZ, higher the sampling frequency, the more beneficial for auto PA testing.
                        PenguinAkiko
                        find a better chip for load cell.
                        CS1237 http://www.asidesigner.com/Files/PartFiles/15315/222/cs1237_datasheet.pdf
                        spi bus 1.28kHz ADC and PGA
                          @nikscha Here is a post about sampling speed
                          https://forum.duet3d.com/post/251488
                            PenguinAkiko
                            https://wiki.bambulab.com/en/a1/manual/intro-a1
                              @penguinya The introduction of bambulab confirmed my guess.
                              • Charlieundefined
                                Charlie
                                Correct me if Im wrong, but I feel like this sensor could also be used for filament runout/jam detection as well. Like if the force expected by feeding the filament is not produced, it could indicate that there is some filament error.
                                PenguinAkikoundefined Richard Fundefined 2 Replies Last reply Reply Quote 0
                                  PenguinAkiko @Charlie
                                  @Charlie Yes prusa has implemented it
                                  Charlieundefined MJLewundefined 2 Replies Last reply Reply Quote 0
                                  • Richard Fundefined
                                    Richard F @Charlie
                                    @Charlie would a mouse optical sensor work to monitor filament
                                    oliofundefined Charlieundefined 2 Replies Last reply Reply Quote 0
                                    • oliofundefined
                                      oliof @Richard F
                                      @Richard-F that's the simple runout switch that you find on many printers. There are other filament failures you'd want to catch.
                                      • Charlieundefined
                                        Charlie @PenguinAkiko
                                        @penguinya Do you have a link to this? I havent seen anything about it.
                                        PenguinAkikoundefined 1 Reply Last reply Reply Quote 1
                                        • Charlieundefined
                                          Charlie @Richard F
                                          @Richard-F It would absolutely work. Ive seen a few systems using this, and Ive used it myself in the past. I know the Duet supports it, though Id recommend looking around to see how others have implemented it. (eg: using printed levers to contact the filament instead of the switch lever contacting the filament directly)
                                          Richard Fundefined 1 Reply Last reply Reply Quote 1
                                            Richard F @Charlie
                                            @Charlie Thanks 🙂
                                            Charlieundefined 1 Reply Last reply Reply Quote 0
