    Auto pressure advance turning by hotend pressure
    35
    2.9k
    • PenguinAkikoundefined
      PenguinAkiko
      15 minutes, 16 seconds to 17 seconds, the hotend moves up and down.
      https://www.youtube.com/watch?v=EZ3BtQ7k9Ak
      • nikschaundefined
        nikscha
        I love the idea!
        I guess you could write a gcode snippet in daemon.g which continously reads straingauge values and adjusts pressure advance values?
        Duet can read sensors via SPI, maybe a dedicated "strain gauge sensor" option would be possible? One could also put together a small PCB that amplifies the strain gauge reading into a voltage that can just be read by a linear analog sensor on the Duet?
        Stay in school
        PenguinAkikoundefined 1 Reply Last reply Reply Quote 0
          PenguinAkiko @nikscha
          @nikscha macro not fast enough, and this is my idea https://forum.duet3d.com/post/324006
          nikschaundefined 1 Reply Last reply Reply Quote 0
            PenguinAkiko
            Automated PA testing is still an early idea. I hope to implement z probe and collect enough PA pressure data for research.
            • nikschaundefined
              nikscha @PenguinAkiko
              @penguinya I think it would be fast enough. Just put a "while true" into daemon.g and then a G4 P50 in the body to execute your script every 50ms. (Edit: this wouldn't actually run that frequent, more like 3-6 times a second)
              I don't think pressure advance needs to be adjusted that often, right?
              Stay in school
              PenguinAkikoundefined 2 Replies Last reply Reply Quote 0
                @nikscha Bambu Lab tests pa every print, and 50ms really slow, HX711 can reach 80HZ, Prusa using HX717 320HZ, higher the sampling frequency, the more beneficial for auto PA testing.
                  PenguinAkiko
                  find a better chip for load cell.
                  CS1237 http://www.asidesigner.com/Files/PartFiles/15315/222/cs1237_datasheet.pdf
                  spi bus 1.28kHz ADC and PGA
                    @nikscha Here is a post about sampling speed
                    https://forum.duet3d.com/post/251488
                      PenguinAkiko
                      https://wiki.bambulab.com/en/a1/manual/intro-a1
                        PenguinAkiko @PenguinAkiko
                        @penguinya The introduction of bambulab confirmed my guess.
                        • Charlieundefined
                          Charlie
                          Correct me if Im wrong, but I feel like this sensor could also be used for filament runout/jam detection as well. Like if the force expected by feeding the filament is not produced, it could indicate that there is some filament error.
                          PenguinAkikoundefined Richard Fundefined 2 Replies Last reply Reply Quote 0
                            PenguinAkiko @Charlie
                            @Charlie Yes prusa has implemented it
                            Charlieundefined MJLewundefined 2 Replies Last reply Reply Quote 0
                            • Richard Fundefined
                              Richard F @Charlie
                              @Charlie would a mouse optical sensor work to monitor filament
                              oliofundefined Charlieundefined 2 Replies Last reply Reply Quote 0
                              • oliofundefined
                                oliof @Richard F
                                @Richard-F that's the simple runout switch that you find on many printers. There are other filament failures you'd want to catch.
                                • Charlieundefined
                                  Charlie @PenguinAkiko
                                  @penguinya Do you have a link to this? I havent seen anything about it.
                                  PenguinAkikoundefined 1 Reply Last reply Reply Quote 1
                                  • Charlieundefined
                                    Charlie @Richard F
                                    @Richard-F It would absolutely work. Ive seen a few systems using this, and Ive used it myself in the past. I know the Duet supports it, though Id recommend looking around to see how others have implemented it. (eg: using printed levers to contact the filament instead of the switch lever contacting the filament directly)
                                    Richard Fundefined 1 Reply Last reply Reply Quote 1
                                      Richard F @Charlie
                                      @Charlie Thanks 🙂
                                      Charlieundefined 1 Reply Last reply Reply Quote 0
                                      • Charlieundefined
                                        Charlie @Richard F
                                        @Richard-F Youre welcome. Happy Printing! 🙂
                                          PenguinAkiko
                                          Just an updating.
                                            @Charlie https://help.prusa3d.com/article/stuck-filament-detection-13101-mk4-21101-mk3-9-17108-xl_690089
