    Combined Smart Effector and tool board for delta printers
    Future Direction
    17
    31
    2.0k
    • Edkirkundefined
      Edkirk
      I am a go, I support all of your specifications. Although I am sold on the E3D rapid change nozzles.
      Thanks, Ed
      • o_lampeundefined
        o_lampe @dc42
        @dc42 Since the user has to assemble the kit anyway (crimping wire loom) it would be nice to have both connectors available as option.
        I think everyone re-buildinging a delta with different rod-distance can solder a few connectors?
        • achrnundefined
          achrn @dc42
          @dc42 A definite yes please from me (but only for one).
          I'd use Orbiter 2.0 extruder and revo hot end. The proposed spec looks good to me.
          • o_lampeundefined
            o_lampe
            Delta-development was on the low burner for a few years. There wasn't much to improve if you use linear rails and magball rods.
            Everyone interested to DIY printers has gone the IDEX or toolchanger route on a CoreXY frame.
            IMHO, it would fuel up the interest for a new Delta effector, if it comes with tool changing options. ("thumb up" if you agree)
            It could be an outer frame with the magballs, which connects to the smartEffector with a twist lock mechanism.
            I have thought about details, how to park the tools (eg. one tool on every tower) but haven't made any drawings yet.
            All wiring had to be done in a way that it doesn't interfere with the magball frame. Same goes for hotend and partcooling fans.
            It would be best if they were placed on the outer frame.
            I don't want to hijack this thread, but if there is enough interest, I start a separate one.
            MaxGyverundefined 1 Reply Last reply Reply Quote 1
            • MaxGyverundefined
              MaxGyver @o_lampe
              With the release of the new Duet 3 Roto Toolboard I am not sure if a new smart effector is really needed. for me the main advantage of the smart effector was nozzle probing. But with the new Scanning Z-Probe Nozzle probing is already obsolete in my opinion. Of course you woul need to set the probe offset manually with a Scanning Z-Probe. To do this I use either a separate button style probe or I adjust the z height manually with baby stepping and run a simple macro to adjust the probe offset by the baby stepping amount and save the new probe offset in config-override.g.
              I would still be interested in buying multiple smart effectors if they support the following points. some of them are obvious but for the sake of completeness...
              • Scanning Z-Probe
              • onboard accelerometer
              • onboard motor driver
              • Io input for filament monitor
              • VZ style hotend mounting holes for Hotends like the Phaetus Rapido, VZ-Revo or Mellow Goliath Hotends.
              • Enough space for direct drive extruders.
              And lastly not necessarily a must but it is nice to have options.
              • A hotend mosfest that can handle <100 W (Mellow Goliath Hotend)
              Since I use CPAP style part cooling and watercooling for the hotend I do not require fanports on the tool board. But I recon This would be a no-go for most users.
              dc42undefined 1 Reply Last reply Reply Quote 2
                dc42 administrators @MaxGyver
                @MaxGyver for delta printers I strongly recommend a nozzle contact probe. The reason is that it is very hard to prevent the effector from tilting slightly as it moves in X and Y; and with an offset Z probe any varying tilt will cause the relative heights of the nozzle and the probe to vary. Therefore, unless we can make the probe coil concentric with the nozzle, we can't use the scanning probe on a delta.
                • MaxGyverundefined
                  MaxGyver @dc42
                  That's a very good point.
                  I am wondering if the effector tilt can be measured and actively compensated by software...but this is probably another topic...
                  Ball spacing of 70mm between the ball centers should be sufficient for a compact direct extruder. It would need to be raised tough in order to clear the hotend collet. I have also tried fitting other hotends like the Voron-Revo and Pheatus Rapido/Goliath. The Voron-Revo does not work, but the Pheatus Rapido/Goliath might just work. The M3 mounting holes just clear the center hole of the effector, but I recon it will mess with the placement of the strain gauges. The threaded E3D-V6 and E3D-Revo Micro support a large range of hotend combinations. Maybe we should stick with those for the sake of simplicity.
                  EDIT: and there is also the option to use an adapter like this
                  E3D Revo-Micro
                  Top View of the effektor with a sherpa mini
                  Bondtech LGX Lite
                  VZ-Hextrudort
                  EDIT: The Orbiter 2.0 was missing
                  T3P3Tonyundefined 1 Reply Last reply Reply Quote 2
                  • Bipotronicundefined
                    Bipotronic
                    I'd be interested in an Orbiter V2.0 or Bondtech LGX Lite or Revo Roto version.
                      T3P3Tony administrators @MaxGyver
                      @MaxGyver those renders were very helpful. could you do one for the Revo Roto as well?
                      MaxGyverundefined 1 Reply Last reply Reply Quote 0
                      • MaxGyverundefined
                        MaxGyver @T3P3Tony
                        @T3P3Tony said in Combined Smart Effector and tool board for delta printers:
                        Of course, I am happy to!
                        The Revo Roto is a bit longer, so it would have to be rotated by 60°
                        The setup would be extremely compact.
                        I have designed a Delta Printer a while back and was basically waiting for a CAN-Smart effector to emerge. So I took the chance to ckeck for any collision points between extruder the Arms (360mm Haydn Magball Arms).
                        And it looks like the Revo Roto will juuuust fit.
                        Unfortunately, there is no way to mount the Revo Roto from below trough the effector plate
                        Exerqtorundefined o_lampeundefined T3P3Tonyundefined 3 Replies Last reply Reply Quote 2
                        • wbrokow1undefined
                          wbrokow1
                          I would buy an updated effector and new extruder assembly if available.
                          • Exerqtorundefined
                            Exerqtor @MaxGyver
                            @MaxGyver said in Combined Smart Effector and tool board for delta printers:
                            Wouldn't the tight clearance be solved by rising the balls ever so slightly from the PCB? I mean just 1-2mm would have alot of effect, if it don't play very negstively into the kinematics (I have no experience with Deltas).
                            • o_lampeundefined
                              o_lampe @MaxGyver
                              @MaxGyver @T3P3Tony I wonder if the Revo Roto could be placed directly on the PCB?
                              Aren't there any electronic parts or headers?
                                T3P3Tony administrators @o_lampe
                                @o_lampe there will be electronic components and the headers for fans, heaters, the stepper motor etc however we may be able to provide a clear area to allow this sort of mounting, won't know until we start the design. Each extruder will need a different shape and amount of clear area however we may get a lot of overlap. Same with mounting holes. In the end we may need an interface bracket or brackets for all or some extruder options.
                                  A couple of L shaped printed brackets would be needed for sure.
                                  • o_lampeundefined
                                    o_lampe @T3P3Tony
                                    Right, I thought the same. But in case of a raised Roto it would interfere with the rods?
                                      dc42 administrators @o_lampe
                                      How much would the rod spacing need to be increased to accommodate the Roto without it interfering with the rods, assuming it is mounted on top of the effector as illustrated earlier?
                                      o_lampeundefined MaxGyverundefined 2 Replies Last reply Reply Quote 0
                                      • apakundefined
                                        apak
                                        I would try at least one
                                        • o_lampeundefined
                                          o_lampe @dc42
                                          @dc42 My observation was, that the roto's big footprint in @MaxGyver 's illustration was directly on the pcb.
                                          It depends on the height of the components how much the roto would have to be raised.
                                          Other DD-extruders like the hextrudort or sherpa mini have a much smaller footprint. I'd suggest to mount them in the same direction as the roto: with the stepper motor between the rods.
                                          A dumb question: with the accelerator chip on the effector, would it be possible to compensate tilt during probing? If so, it wouldn't have to be a nozzle touch probe, but could be any other.
                                          The math for tilt compensation would be easy. You have the offset between probe and effector-center and you can read the tilt-changes between first homing and when the effector reaches the given probing coords.
                                          • nikschaundefined
                                            nikscha
                                            I would be interested in a variant for the Roto.
                                            Stay in school
