Combined Smart Effector and tool board for delta printers
@dc42 it would be good if voron style hotend mounting was supported.
I'd be interested in a Sherpa mini variant.
I am a go, I support all of your specifications. Although I am sold on the E3D rapid change nozzles.
Thanks, Ed -
@dc42 Since the user has to assemble the kit anyway (crimping wire loom) it would be nice to have both connectors available as option.
I think everyone re-buildinging a delta with different rod-distance can solder a few connectors? -
@dc42 A definite yes please from me (but only for one).
I'd use Orbiter 2.0 extruder and revo hot end. The proposed spec looks good to me.
Delta-development was on the low burner for a few years. There wasn't much to improve if you use linear rails and magball rods.
Everyone interested to DIY printers has gone the IDEX or toolchanger route on a CoreXY frame.IMHO, it would fuel up the interest for a new Delta effector, if it comes with tool changing options. ("thumb up" if you agree)
It could be an outer frame with the magballs, which connects to the smartEffector with a twist lock mechanism.
I have thought about details, how to park the tools (eg. one tool on every tower) but haven't made any drawings yet.
All wiring had to be done in a way that it doesn't interfere with the magball frame. Same goes for hotend and partcooling fans.
It would be best if they were placed on the outer frame.I don't want to hijack this thread, but if there is enough interest, I start a separate one.
With the release of the new Duet 3 Roto Toolboard I am not sure if a new smart effector is really needed. for me the main advantage of the smart effector was nozzle probing. But with the new Scanning Z-Probe Nozzle probing is already obsolete in my opinion. Of course you woul need to set the probe offset manually with a Scanning Z-Probe. To do this I use either a separate button style probe or I adjust the z height manually with baby stepping and run a simple macro to adjust the probe offset by the baby stepping amount and save the new probe offset in config-override.g.
I would still be interested in buying multiple smart effectors if they support the following points. some of them are obvious but for the sake of completeness...
- Scanning Z-Probe
- onboard accelerometer
- onboard motor driver
- Io input for filament monitor
- VZ style hotend mounting holes for Hotends like the Phaetus Rapido, VZ-Revo or Mellow Goliath Hotends.
- Enough space for direct drive extruders.
And lastly not necessarily a must but it is nice to have options.
- A hotend mosfest that can handle <100 W (Mellow Goliath Hotend)
Since I use CPAP style part cooling and watercooling for the hotend I do not require fanports on the tool board. But I recon This would be a no-go for most users.
@MaxGyver for delta printers I strongly recommend a nozzle contact probe. The reason is that it is very hard to prevent the effector from tilting slightly as it moves in X and Y; and with an offset Z probe any varying tilt will cause the relative heights of the nozzle and the probe to vary. Therefore, unless we can make the probe coil concentric with the nozzle, we can't use the scanning probe on a delta.
That's a very good point.
I am wondering if the effector tilt can be measured and actively compensated by software...but this is probably another topic...Ball spacing of 70mm between the ball centers should be sufficient for a compact direct extruder. It would need to be raised tough in order to clear the hotend collet. I have also tried fitting other hotends like the Voron-Revo and Pheatus Rapido/Goliath. The Voron-Revo does not work, but the Pheatus Rapido/Goliath might just work. The M3 mounting holes just clear the center hole of the effector, but I recon it will mess with the placement of the strain gauges. The threaded E3D-V6 and E3D-Revo Micro support a large range of hotend combinations. Maybe we should stick with those for the sake of simplicity.
EDIT: and there is also the option to use an adapter like this
I'd be interested in an Orbiter V2.0 or Bondtech LGX Lite or Revo Roto version.
@MaxGyver those renders were very helpful. could you do one for the Revo Roto as well?
@T3P3Tony said in Combined Smart Effector and tool board for delta printers:
Of course, I am happy to!
The Revo Roto is a bit longer, so it would have to be rotated by 60°
The setup would be extremely compact.
I have designed a Delta Printer a while back and was basically waiting for a CAN-Smart effector to emerge. So I took the chance to ckeck for any collision points between extruder the Arms (360mm Haydn Magball Arms).
And it looks like the Revo Roto will juuuust fit.Unfortunately, there is no way to mount the Revo Roto from below trough the effector plate
I would buy an updated effector and new extruder assembly if available.
@MaxGyver said in Combined Smart Effector and tool board for delta printers:
Wouldn't the tight clearance be solved by rising the balls ever so slightly from the PCB? I mean just 1-2mm would have alot of effect, if it don't play very negstively into the kinematics (I have no experience with Deltas).
@o_lampe there will be electronic components and the headers for fans, heaters, the stepper motor etc however we may be able to provide a clear area to allow this sort of mounting, won't know until we start the design. Each extruder will need a different shape and amount of clear area however we may get a lot of overlap. Same with mounting holes. In the end we may need an interface bracket or brackets for all or some extruder options.
A couple of L shaped printed brackets would be needed for sure.
Right, I thought the same. But in case of a raised Roto it would interfere with the rods?
How much would the rod spacing need to be increased to accommodate the Roto without it interfering with the rods, assuming it is mounted on top of the effector as illustrated earlier?
I would try at least one
