wifi
My Duet controlled machine
590
    luca Massimiliano
    Re: My new large scale 3D printer Hydra
    ciao
    posso farti una domanda relativa al wifi che non si collega
    undefined undefined 2 Replies Last reply 10 Apr 2024, 08:43 Reply Quote 0
      moth4017 @luca Massimiliano
      @luca-Massimiliano
      I can ask you a question regarding the wifi not connecting
      you can ask a question ?
        luca Massimiliano @luca Massimiliano
        @luca-Massimiliano
        I can't connect via wi-fe
        the duet is present in the modem, you see the connection and it loads it, but if I send from PC http://192.168.xxx.xxx/Job/Status it doesn't connect, it all happened because I changed the fiber modem
        undefined 1 Reply Last reply 11 Apr 2024, 06:28 Reply Quote 0
          @luca-Massimiliano you may have to look at the modem if it is the access point as well to make sure it has 2.4Ghz active and not just the 5Ghz
          undefined 1 Reply Last reply 11 Apr 2024, 07:40 Reply Quote 0
            luca Massimiliano @moth4017
            This post is deleted!
            undefined 1 Reply Last reply 11 Apr 2024, 07:48 Reply Quote 0
              @luca-Massimiliano just making sure the modem had 2.4ghz active , i have seen modems supplied with only 5ghz active,
              undefined 1 Reply Last reply 11 Apr 2024, 13:46 Reply Quote 0
                undefined 1 Reply Last reply 11 Apr 2024, 14:10 Reply Quote 0
                  gloomyandy @luca Massimiliano
                  @luca-Massimiliano I'm not sure anyone understands what exactly your problem is. Perhaps you could answer the following questions:
                  1. Was WiFi work correctly at some point?
                  2. If it was working before what has changed between then and now? When did it stop working?
                  undefined 1 Reply Last reply 11 Apr 2024, 16:01 Reply Quote 0
                  • undefined T3P3Tony referenced this topic 11 Apr 2024, 14:51
                    luca Massimiliano @gloomyandy
                    @gloomyandyI changed modem, I did the whole procedure, the modem sees it but if I launch http://192.xxx.xxx.xxx/Job/Status it doesn't open the control panel
                    undefined 1 Reply Last reply 11 Apr 2024, 18:59 Reply Quote 0
                      @luca-Massimiliano Check that your modem is set to allow WiFi clients to see and talk to each other (sometimes called client isolation). Many modems have this setting. https://support.denon.com/app/answers/detail/a_id/3746/~/wireless%2C-ap-or-client-isolation#:~:text=Wireless Isolation%2C sometimes called Client,network by a wired connection.
                      undefined 1 Reply Last reply 12 Apr 2024, 14:30 Reply Quote 0
                        @gloomyandy
                        I HAVE RECONFIGURED THE DUET AS PER THE MANUAL
                        https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet AND AS INDICATED ON THE FORUM BY Fedrox AND dc4
                        BELOW I GIVE THE ANSWERS AND ALWAYS GIVE ME
                        M552 S1
                        ok
                        Error retrieving WiFi status message: SPI timeout
                        WiFi module started
                        WiFi reported error: no known networks found
                        WiFi module is idle
                        WiFi module is idleRISPOSTE COMANDI SU YAT.txt210a94fc-379a-413f-8fe1-71120e92549b-image.png
                        undefined 1 Reply Last reply 12 Apr 2024, 16:16 Reply Quote 0
                          @luca-Massimiliano My comment had nothing to do with re-configuring the duet so I've no idea why you have done that. What I was suggesting that you do was to check the configuration of your modem/router to check that it allows different clients to see and communicate with each other. It looks like you have now made things worse and that do not have your duet configured to talk to your router correctly, so you will need to fix that first.
                          undefined 2 Replies Last reply 12 Apr 2024, 18:24 Reply Quote 0
                              @gloomyandy MY POINT OF ERROR IS THIS WiFi reported error: no known networks found
                              WiFi module is idle
                              NO COMMAND MAKES ME DELETE DO YOU KNOW ITS CAUSE?
                                Can you try setting the Duet to Access Point Mode where it creates it's own wireless SSID that you will connect your device to? This will eliminate your router from the setup and verify that the Duet wireless hardware is still actually working correctly.
                                If that works and the hardware is good, then the problem is somewhere with your new router. Either the SSID you are giving the Duet isn't correct, or the router isn't putting out a 2.4ghz SSID at all. The Duet can only communicate with 2.4ghz networks.
                                See here for the steps to use Access Point Mode: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
                                undefined 1 Reply Last reply 12 Apr 2024, 20:44 Reply Quote 0
                                  luca Massimiliano @Phaedrux
                                  @Phaedrux
                                  THANKS YOU HAVE ALWAYS BEEN AVAILABLE, YOU ARE A GREAT SUPPORT FOR THE FORUMS, AS ALWAYS YOU RESOLVE IT, THANKS Phaedrux EVERYTHING WORKS
                                    It's connecting to your router now?
                                    undefined 1 Reply Last reply 13 Apr 2024, 07:40 Reply Quote 0
                                      @Phaedrux yes, thanks, everything is perfect, both with the modem, with the computer and with the smartphone. Thank you very much
                                      • undefined Phaedrux marked this topic as a question 13 Apr 2024, 17:58
                                      • undefined Phaedrux has marked this topic as solved 13 Apr 2024, 17:58
                                      10 out of 18
