    24 volt fan with PWM control
    521
      Can you give some information about your fan?
      Have you seen this? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Fans_connecting
      Zsevenundefined 1 Reply Last reply Reply Quote 0
      • Zsevenundefined
        Zseven @Phaedrux
        @Phaedrux Yes, I have read it but not understood it.
        The fan has 3 pins 1x +24v 1x - 1x pwm
        Which is the pwm output?
        Outx-
        Or outx.tach
          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Fans_connecting#connecting-fans-to-duet-fan-pins
          Click the tab for 4wire fans.
          • Zsevenundefined
            Zseven @Phaedrux
            @Phaedrux
            I have connected the fan and set the parameter Q1000. If I set the speed in the DWC to 95%, the motor burns out!
              Can you give more detail about what exactly you are connecting?
              • Zsevenundefined
                Zseven @Phaedrux
                @Phaedrux
                Hello ,
                I have
                +24V at Out5 / V_OutLC1
                -Out 5 / GND
                PWM at Out 5 / out5-
                in config.g
                M950 F2 C‘!out5’ Q1000
                M106 P2 S0.0 H-1 C ‘Blower’
                • oliofundefined
                  oliof @Zseven
                  @Zseven I assume this is a CPAP/vacuum blower control PCB and not a standard fan, is that correct?
                  • Zsevenundefined
                    Zseven @oliof
                    @oliof
                    Yes !
                    • oliofundefined
                      oliof @Zseven
                      @Zseven then you need to give us more details. Type of blower, how everything is wired between the PCB and the Blower and the control board, etc.
                      I highly doubt the Duet board can burn out the big blower because those fan ports are limited to 1A; I assume the blowers pull more than that.
                      Zsevenundefined 2 Replies Last reply Reply Quote 0
                      • Zsevenundefined
                        Zseven @oliof
                        @oliof
                        Hello ,
                        I have requested the data sheet from the manufacturer.
                        • Zsevenundefined
                          Zseven @oliof
                          @oliof
                          ello ,
                          I have now got a replacement as the last fan has burnt out.
                          DC7-24V brushless turbo fan motor 100000 rpm high speed aluminium alloy impeller with brushless motor and speed controller
                          I have now connected the fan direnkt to the 24V power supply and I can control it very well with the potentiometer
                          I have now measured the voltage at the potentiometer and between the red and black cable are 5V
                          The yellow cable should be the PWM signal.
                          How can I now control this fan with the Duet 6xd?
                          Witch pins ?
                          • oliofundefined
                            oliof
                            The wiring on the photo does not match the wiring on the PCB graphics.
                            If you could provide a link to the listing and/or a full spec sheet that would help. "PWM control" can mean different things, in this case it could be 0-5V for example which would require extra circuitry.
                            • Zsevenundefined
                              Zseven @oliof
                              @oliof
                              I have fix it !
                              • oliofundefined
                                oliof @Zseven
                                @Zseven please share your fixed setup for the benefit of all (-;
                                • Zsevenundefined
                                  Zseven @oliof
                                  @oliof
                                  Hello ,
                                  here is my solution for the 6XD board
