    24 volt fan with PWM control
    524
    • Zsevenundefined
      Zseven @Phaedrux
      @Phaedrux
      Hello ,
      I have
      +24V at Out5 / V_OutLC1
      -Out 5 / GND
      PWM at Out 5 / out5-
      in config.g
      M950 F2 C‘!out5’ Q1000
      M106 P2 S0.0 H-1 C ‘Blower’
      • oliofundefined
        oliof @Zseven
        @Zseven I assume this is a CPAP/vacuum blower control PCB and not a standard fan, is that correct?
        Zsevenundefined 1 Reply Last reply Reply Quote 0
        • Zsevenundefined
          Zseven @oliof
          @oliof
          Yes !
          • oliofundefined
            oliof @Zseven
            @Zseven then you need to give us more details. Type of blower, how everything is wired between the PCB and the Blower and the control board, etc.
            I highly doubt the Duet board can burn out the big blower because those fan ports are limited to 1A; I assume the blowers pull more than that.
            Zsevenundefined 2 Replies Last reply Reply Quote 0
            • Zsevenundefined
              Zseven @oliof
              @oliof
              Hello ,
              I have requested the data sheet from the manufacturer.
              • Zsevenundefined
                Zseven @oliof
                @oliof
                ello ,
                I have now got a replacement as the last fan has burnt out.
                DC7-24V brushless turbo fan motor 100000 rpm high speed aluminium alloy impeller with brushless motor and speed controller
                I have now connected the fan direnkt to the 24V power supply and I can control it very well with the potentiometer
                I have now measured the voltage at the potentiometer and between the red and black cable are 5V
                The yellow cable should be the PWM signal.
                How can I now control this fan with the Duet 6xd?
                Witch pins ?
                • oliofundefined
                  oliof
                  The wiring on the photo does not match the wiring on the PCB graphics.
                  If you could provide a link to the listing and/or a full spec sheet that would help. "PWM control" can mean different things, in this case it could be 0-5V for example which would require extra circuitry.
                  • Zsevenundefined
                    Zseven @oliof
                    @oliof
                    I have fix it !
                    • oliofundefined
                      oliof @Zseven
                      @Zseven please share your fixed setup for the benefit of all (-;
                      • Zsevenundefined
                        Zseven @oliof
                        @oliof
                        Hello ,
                        here is my solution for the 6XD board
