    24 volt fan with PWM control
    521
    • Zsevenundefined
      Zseven @Phaedrux
      @Phaedrux Yes, I have read it but not understood it.
      The fan has 3 pins 1x +24v 1x - 1x pwm
      Which is the pwm output?
      Outx-
      Or outx.tach
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Fans_connecting#connecting-fans-to-duet-fan-pins
        Click the tab for 4wire fans.
        Zsevenundefined 1 Reply Last reply Reply Quote 0
        • Zsevenundefined
          Zseven @Phaedrux
          @Phaedrux
          I have connected the fan and set the parameter Q1000. If I set the speed in the DWC to 95%, the motor burns out!
            Can you give more detail about what exactly you are connecting?
            • Zsevenundefined
              Zseven @Phaedrux
              @Phaedrux
              Hello ,
              I have
              +24V at Out5 / V_OutLC1
              -Out 5 / GND
              PWM at Out 5 / out5-
              in config.g
              M950 F2 C‘!out5’ Q1000
              M106 P2 S0.0 H-1 C ‘Blower’
              • oliofundefined
                oliof @Zseven
                @Zseven I assume this is a CPAP/vacuum blower control PCB and not a standard fan, is that correct?
                • Zsevenundefined
                  Zseven @oliof
                  @oliof
                  Yes !
                  • oliofundefined
                    oliof @Zseven
                    @Zseven then you need to give us more details. Type of blower, how everything is wired between the PCB and the Blower and the control board, etc.
                    I highly doubt the Duet board can burn out the big blower because those fan ports are limited to 1A; I assume the blowers pull more than that.
                    Zsevenundefined 2 Replies Last reply Reply Quote 0
                    • Zsevenundefined
                      Zseven @oliof
                      @oliof
                      Hello ,
                      I have requested the data sheet from the manufacturer.
                      • Zsevenundefined
                        Zseven @oliof
                        @oliof
                        ello ,
                        I have now got a replacement as the last fan has burnt out.
                        DC7-24V brushless turbo fan motor 100000 rpm high speed aluminium alloy impeller with brushless motor and speed controller
                        I have now connected the fan direnkt to the 24V power supply and I can control it very well with the potentiometer
                        I have now measured the voltage at the potentiometer and between the red and black cable are 5V
                        The yellow cable should be the PWM signal.
                        How can I now control this fan with the Duet 6xd?
                        Witch pins ?
                        • oliofundefined
                          oliof
                          The wiring on the photo does not match the wiring on the PCB graphics.
                          If you could provide a link to the listing and/or a full spec sheet that would help. "PWM control" can mean different things, in this case it could be 0-5V for example which would require extra circuitry.
                          • Zsevenundefined
                            Zseven @oliof
                            @oliof
                            I have fix it !
                            • oliofundefined
                              oliof @Zseven
                              @Zseven please share your fixed setup for the benefit of all (-;
                              • Zsevenundefined
                                Zseven @oliof
                                @oliof
                                Hello ,
                                here is my solution for the 6XD board
