    6XD I/O >> Issue solved
    5.1k
    • tecnoundefined
      tecno @droftarts
      @droftarts
      Duet Web Control 3.5.1
      Yes it is stuck on one LED no color change
        droftarts administrators @tecno
        @tecno RepRapFirmware 3.5.1 as well? Please update to 3.5.3 (RRF and DWC) and test, there have been some fixes for LEDs. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3
        This was a fix in 3.5.2:
        [Duet 3 MB6HC] [Duet 3 MB6XD] When a Neopixel LED strip was configured on a part other than the LED port, the first LED in the strip sometimes had the wrong colour (issue 996). This was a new bug in RRF 3.5.0.
        It could also be the M950 Q parameter. We say:
        The Qnn parameter sets the LED clock frequency. This is 4x the bit rate. Most datasheets for LEDs (at least SK6812 and WS2812B based LEDs) suggest a maximum data rate of 800Kbps, so 800000 * 4 = 3200000. The default of 3000000 appears to work well with most LEDs.
        So try M950 E0 C"led" Q3200000, and M950 E0 C"led" Q2800000, but after you have updated the firmware.
        Also, check your wiring!
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @droftarts
          @droftarts
          Wires OK
          Same lonly LED
          Sanity check
            @tecno I've just tested it on a 6HC, on RRF 3.5.1, and it's working for a 7-segment LED strip. All light up correctly. The fix in 3.5.2 was if you were using IO ports for LEDs. I don't have a 6XD to test, but it should be exactly the same as 6HC.
            Can you send M115 and post the response?
            Can you post a picture of the other side of the neopixel ring?
            Also, I'm not sure using the uninsulated wire as the high frequency data line is a good idea! Most likely it has higher resistance than a 'normal' wire, and may not be transmitting the signal effectively. Use a different wire.
            • tecnoundefined
              tecno @droftarts
              @droftarts
              m115
              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet 3 MB6XD v1.01 FIRMWARE_DATE: 2024-09-18 11:27:56
              This cable is a HQ Audio twisted pair with foil shield. Change White to shield.
                @tecno Ah, that looks like an RGBW ring. Try
                M950 E0 C"led" Q3000000 T2
                M150 E0 R255 P128 S20 F0
                M950 T2 tells RRF that it's RGBW, not RGB.
                • tecnoundefined
                  tecno @droftarts
                  @droftarts
                  Same same
                  Will change LED ring to one with black PCB board. This a job for torrow 😉
                  • tecnoundefined
                    tecno @tecno
                    @droftarts
                    Morning Ian,
                    Changed LED strip and only 1 of 8 is working on this one too.
                    Any suggestions?
                    Cheers
                    Bengt
                      @tecno I've just tested both RGB and RGBW LEDs on my 6HC, both worked without issue. I've asked someone with a 6XD to test.
                      Can you post a link to the white LED ring you bought? And post a picture of the current wiring?
                      • tecnoundefined
                        tecno @droftarts
                        @droftarts
                        https://vi.aliexpress.com/item/1005002313192735.html?spm=a2g0o.order_list.order_list_main.11.364b1802NFG3VP&gatewayAdapt=glo2vnm
                        Both white and ´blach PCB 8 LEDS
                        Wiring https://forum.duet3d.com/post/345489
                        gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                        • gloomyandyundefined
                          gloomyandy @tecno
                          @tecno Shouldn't the control signal be going to d0 and not to d1?
                          • tecnoundefined
                            tecno @gloomyandy
                            @gloomyandy
                            As I understand is 6XD D0 out goes to Di in.
                            gloomyandyundefined 1 Reply Last reply Reply Quote 0
                              @tecno Those do look like RGB LEDs, looking closer. Though they should light up, just with the wrong colours, if you put the wrong T parameter in M950.
                              I thought you said you had changed the wire over? @tecno said in 6XD I/O >> Issue solved:
                              On each LED, there is a corner 'notch' to indicate which pin is GND. Can you check continuity of GND, DI and 5V from the LED pins to the connector?
                              @gloomyandy It's DI for Digital In, DO is Digital Out, where it passes the signal on to the next one. Mine are labelled and wired like that.
                                gloomyandy @tecno
                                @tecno This has nothing to do with the 6XD I'm talking about the pads on the LED ring, there is a D0 and a D1. Your wiring here: https://forum.duet3d.com/post/345489 shows it going to D1 I think it should go to D0. It seems very odd to me to have the input labelled D1 and the output labelled D0.
                                  gloomyandy @gloomyandy
                                  Ah yes that may be Din and Dout I suppose. Oh well good luck!
                                  • tecnoundefined
                                    tecno @gloomyandy
                                    @droftarts
                                    So now I changed White to signal and Shield is now 5V
                                    So now we are getting closer 🙂
                                      @tecno Okay, so now use:
                                      M950 E0 C"led" Q3000000 T1
                                      ie change T2 to T1
                                      I expect that bare 'earth' wire had too much capacitance to transmit the signal. Now you're using the bare wire for 5V, so easier to create a short. Same goes for using that wire for GND. I'd replace the wiring with individually insulated wires, ie 3-core wire. If you don't have 3-core wire, use left-over stepper motor wire, that's about the right gauge for LEDs.
                                      • tecnoundefined
                                        tecno @droftarts
                                        @droftarts
                                        Works in R255 and P can be set = Nice.
                                        Now to play with new colors
                                          @tecno Do all 8 LEDs work now, and are controllable?
                                          RGB LEDs aren't the best for white light. You'll have to play around with the levels in M150 for R, U (for green) and B, and brightness (P) to get close to what you want. If it's mostly white you want, you probably should have got RGBW, or just white, LEDs.
                                          • tecnoundefined
                                            tecno @droftarts
                                            @droftarts
                                            Yes all 8 work
                                            I am aware that I can not get perfect greyscale with RGB. Hard to find 8leds RGBW that fits.
                                            Thank you very much for your kind help Ian, I owe you a pint or two 🙂
                                            I am sure more questions will arise
                                            Cheers
                                            Bengt
