    Z wont go to the corect dept when printing.
    1.7k
    • Snippyundefined
      Snippy @gloomyandy
      This post is deleted!
        droftarts administrators @Snippy
        @Snippy said in Z wont go to the corect dept when printing.:
        From tip to nozzle tip in Z is 2mm
        Are you measuring the Z offset of the probe in this position, ie when it is retracted? If so, that's wrong. You need to measure the height of the nozzle when the probe is triggered, ie when the probe pin is deployed, and it comes in contact with the bed, which then retracts. The nozzle will be a couple of mm off the bed, and it is this offset you need to measure. The instructions to mount the BLTouch "2mm above the nozzle" is just to make sure it's far enough away from the nozzle when retracted that it doesn't hit the print, but low enough that when it deploys it is below the nozzle, so touches first.
        Follow the instructions to determine the Z height that you posted. If the probe isn't consistent in the number it reports from multiple probing (try running the script here: https://forum.duet3d.com/post/335748)
        im starting to think that duet in general is just cursed.
        Nope.
        Snippyundefined 2 Replies Last reply Reply Quote 0
        • Snippyundefined
          Snippy @droftarts
          @droftarts
          So this
          Checking the trigger height
          The Z probe trigger height must not vary significantly with XY position. Measure the trigger height of your Z probe at various XY positions and make sure it is consistent. To measure the trigger height:
          Make sure there is no filament stuck to the nozzle (you may want to do this test with the nozzle hot)
          Cancel any existing bed compensation by sending M561
          Send M564 S0 to allow movement lower than where the firmware thinks Z=0 is. This is to ensure that you can lower the nozzle all the way to the bed in step 5.
          Command the print head to the XY coordinates you want to probe. This can be any place where both the nozzle and the probe are over the bed. Either use the jog buttons in DWC, or send a G1 command (eg G1 X100 Y100) to move to a specific location.
          Command the print head down in small steps, using the jog buttons in DWC or by sending individual G1 Z[value] commands, until the nozzle just touches the bed or just grips a sheet of paper. You may also wish to create a macro to lower the head by e.g. 0.02mm to get greater accuracy (G91 followed by G1 Z-0.02).
          Send G92 Z0 to define that height as Z=0
          Command the nozzle up 5mm (G1 Z5)
          Send G30 S-1 to probe the bed without resetting the Z=0 position
          Read off the Z height from the web interface. That is the trigger height.
          Repeat the previous two steps a couple of times to make sure you are getting a consistent result
          Repeat steps 4-10 for the other XY positions you want to check.
          Does nothing?
          • Snippyundefined
            Snippy @droftarts
            @droftarts
            G1 Z-1.97 F50 ; Nozzle Z0 Y200 X160
            G92 Z0
            G1 Z5
            G30 S-1
            Stopped at height 4.054 mm
            Got G30 S-1
            Stopped at height 4.054 mm to give a consistent result.
            is 4.054 mm the nozzle height?
            ; Probes
            M558 K0 P9 C"io7.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
            G31 P500 X45 Y0 Z4.054 ; set Z probe trigger value, offset and trigger height
            M950 S0 C"io7.out" ; create servo #0 for BLtouch
            M557 X0:400 Y0:400 S20
            droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
              Yes.
              Yes, put it in the G31 Z parameter.
              Your instructions are missing a couple of steps at the end, where it explains how to put the Z offset in G31. Where did you get them from? Proper instructions here https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing#calibrate-the-z-probe-trigger-height
              Snippyundefined 1 Reply Last reply Reply Quote 0
              • Snippyundefined
                Snippy @droftarts
                @droftarts
                Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
                378 points probed, min error -1.674, max error 0.051, mean -1.157, deviation 0.336
                Height map saved to file 0:/sys/heightmap.csv
                RepRapFirmware height map file v2 generated at 2025-02-22 20:45, min error -1.674, max error 0.051, mean -1.157, deviation 0.336
                axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
                X,Y,0.00,400.00,0.00,400.00,-1.00,20.00,20.00,21,21
                0, 0, 0, -0.605, -0.800, -0.884, -1.019, -1.089, -1.116, -1.179, -1.183, -1.143, -1.120, -1.058, -0.961, -0.838, -0.719, -0.471, -0.333, -0.113, 0.051
                0, 0, 0, -0.675, -0.775, -0.954, -1.056, -1.180, -1.183, -1.220, -1.180, -1.185, -1.170, -1.103, -1.048, -0.930, -0.776, -0.600, -0.391, -0.270, -0.060
                0, 0, 0, -0.748, -0.904, -1.031, -1.089, -1.210, -1.211, -1.238, -1.233, -1.254, -1.203, -1.158, -1.091, -0.970, -0.830, -0.620, -0.461, -0.331, -0.129
                0, 0, 0, -0.828, -0.978, -1.079, -1.143, -1.230, -1.265, -1.275, -1.261, -1.285, -1.261, -1.185, -1.111, -0.988, -0.903, -0.738, -0.518, -0.384, -0.235
                0, 0, 0, -0.900, -1.009, -1.120, -1.199, -1.276, -1.316, -1.351, -1.334, -1.295, -1.266, -1.224, -1.124, -1.035, -0.971, -0.818, -0.628, -0.464, -0.349
                0, 0, 0, -0.990, -1.073, -1.190, -1.268, -1.328, -1.373, -1.375, -1.401, -1.382, -1.338, -1.280, -1.254, -1.145, -1.046, -0.945, -0.783, -0.598, -0.480
                0, 0, 0, -0.989, -1.136, -1.244, -1.271, -1.396, -1.386, -1.431, -1.460, -1.424, -1.394, -1.348, -1.275, -1.200, -1.129, -1.021, -0.856, -0.704, -0.516
                0, 0, 0, -1.059, -1.146, -1.230, -1.348, -1.399, -1.401, -1.458, -1.435, -1.471, -1.429, -1.400, -1.360, -1.253, -1.128, -1.063, -0.945, -0.784, -0.619
                0, 0, 0, -1.106, -1.209, -1.278, -1.355, -1.419, -1.449, -1.485, -1.490, -1.471, -1.474, -1.399, -1.348, -1.263, -1.191, -1.078, -0.971, -0.815, -0.666
                0, 0, 0, -1.110, -1.191, -1.298, -1.339, -1.408, -1.441, -1.489, -1.513, -1.501, -1.479, -1.464, -1.390, -1.305, -1.215, -1.149, -0.993, -0.919, -0.704
                0, 0, 0, -1.096, -1.189, -1.280, -1.344, -1.451, -1.469, -1.513, -1.519, -1.531, -1.508, -1.497, -1.408, -1.291, -1.253, -1.141, -1.015, -0.884, -0.719
                0, 0, 0, -1.074, -1.191, -1.294, -1.368, -1.438, -1.463, -1.441, -1.519, -1.550, -1.549, -1.479, -1.426, -1.341, -1.250, -1.174, -1.054, -0.930, -0.760
                0, 0, 0, -1.073, -1.165, -1.308, -1.382, -1.439, -1.421, -1.505, -1.546, -1.551, -1.556, -1.499, -1.438, -1.350, -1.258, -1.104, -0.994, -0.853, -0.789
                0, 0, 0, -1.015, -1.134, -1.243, -1.356, -1.461, -1.454, -1.519, -1.570, -1.531, -1.509, -1.460, -1.398, -1.344, -1.268, -1.106, -0.966, -0.840, -0.730
                0, 0, 0, -0.978, -1.141, -1.239, -1.335, -1.398, -1.504, -1.528, -1.513, -1.558, -1.529, -1.485, -1.440, -1.274, -1.264, -1.111, -0.974, -0.870, -0.684
                0, 0, 0, -0.963, -1.093, -1.264, -1.308, -1.446, -1.535, -1.539, -1.504, -1.551, -1.511, -1.485, -1.411, -1.270, -1.238, -1.115, -1.011, -0.853, -0.670
                0, 0, 0, -0.903, -1.123, -1.273, -1.364, -1.435, -1.510, -1.540, -1.638, -1.565, -1.523, -1.438, -1.393, -1.313, -1.148, -1.059, -0.859, -0.734, -0.438
                0, 0, 0, -0.886, -1.054, -1.238, -1.360, -1.470, -1.483, -1.593, -1.606, -1.634, -1.499, -1.463, -1.420, -1.233, -1.136, -1.018, -0.889, -0.655, -0.490
                0, 0, 0, -0.893, -1.041, -1.201, -1.326, -1.456, -1.538, -1.558, -1.581, -1.623, -1.458, -1.550, -1.406, -1.240, -1.071, -0.921, -0.755, -0.531, -0.239
                0, 0, 0, -0.803, -1.013, -1.186, -1.266, -1.478, -1.486, -1.531, -1.596, -1.548, -1.604, -1.414, -1.368, -1.214, -1.053, -0.858, -0.620, -0.405, -0.129
                0, 0, 0, -0.789, -1.018, -1.173, -1.314, -1.465, -1.564, -1.658, -1.674, -1.616, -1.563, -1.483, -1.334, -1.213, -0.993, -0.819, -0.514, -0.275, -0.075
                Got this far again, No matter where i try to establish the Z=0 datum allways the same error.
                What i can tell from this height map that it is the most accurate so far.
                Still the height map does ''jack shit'' when it comes to printing, nozzle wont go Z- It can only go Z+.
                Why???
                • fcwiltundefined
                  fcwilt @Snippy
                  @Snippy
                  G92 Z0
                  G1 Z5
                  G30 S-1
                  Why are you doing the G92 Z0 - that is quite likely going to mess things up entirely.
                  Before you can use mesh compensation you first have to insure your Z probe is correct configured so that setting the Z**=0 Datum**, using G30, gives the correct result.
                  After doing a G30 (usually at the center of the bed) you can then, using the DWC, "nudge" the bed toward the nozzle of the hotend. When the bed just touches the top of the nozzle the DWC should report the Z position as 0 (zero).
                  If it does not you need to adjust the Z trigger height of your Z probe configuration until you do get Z=0 when the bed just touches the nozzle.
                  It will like take several attempts to find the exact value you need for your Z probe.
                  Once the Z probe is working then and only then can you create an accurate height map. You must always use G30 to set the Z=0 Datum BEFORE using G29 to create the height map or when loading the height map.
                  • Snippyundefined
                    Snippy @fcwilt
                    @fcwilt
                    This is why
                    • Snippyundefined
                      Snippy
                      My problem is that after get a height map from G29 the map does nothing to compensate when printing, Z does not moove in -Z only in Z+.
                      • fcwiltundefined
                        fcwilt @Snippy
                        @fcwilt
                        This is why
                        OK - so the bed was just touching the nozzle at that point when you set Z=0?
                        • fcwiltundefined
                          fcwilt @Snippy
                          Well how it should move would depend on the height map values and the height map value nearest to where the Z=0 Datum was set.
                          If the Z=0 Datum happened to be set equal to the lowest point of the mesh then movement would only be in Z+, as all of the other points, being higher, would need to be lowered.
                          • Snippyundefined
                            Snippy @fcwilt
                            @fcwilt Z datum was set to the highest part, So in order to print Z should go in the -
                            • Snippyundefined
                              Snippy @fcwilt
                              @fcwilt
                              Yes
                              sebkritikelundefined 1 Reply Last reply Reply Quote 0
                              • sebkritikelundefined
                                sebkritikel @Snippy
                                @Snippy Can you post your config.g file? Specifically looking for your M208 line based on the following quote:
                                Edit: Your bed does not look healthy lol.
                                Large(ish?) IDEX - 6HC, 1HCL
                                Stratasys Dimension 1200es to 6HC Conversion
                                • fcwiltundefined
                                  fcwilt @Snippy
                                  I assume you have verified that the Z axis moves in the correct direction when controlled from the DWC?
                                  P.S. Just out of curiosity what is the bed made from? It seems to have quite a bit of curve.
                                  Here is the height map from one of my better printers. I had the bed created by a local machinist and it is very flat. Even came with a certificate.
                                  • Snippyundefined
                                    Snippy @fcwilt
                                    @fcwilt
                                    Bed is https://www.aliexpress.com/item/1005003056403054.html?spm=a2g0o.order_list.order_list_main.84.71821802lt2l0t
                                    The printer is homebrew 100%, Core XY
                                    Printed parts are mostly nylon with 10% carbonfiber.
                                    So far ~900€ in parts.
                                    • Snippyundefined
                                      Snippy @fcwilt
                                      @fcwilt
                                      And yes, Z mooves corectly.
                                      Only problem i have is the mesh bed compensation does absolutely nothing.
                                      And i might have a solution for the bed being a dish, ill just drill and tap some holes in the bed subplate 6mm 7068 aluminium plate and use some extra bolts with rubber tips to push out the bow.
                                        @Snippy so you are homing the bed at the one of the high corners eg X0 Y0? Generally you should home Z at either the ‘most used’ point (usually the bed centre) or the lowest point (in your case also the bed centre), and the mesh is better positive, because negative moves are limited, because the nozzle won’t move below Z0 (unless your M208 allows it, or you have sent the Gcode to allow moves outside the machine limits). ie if your printing at 0.1mm layer height, and your mesh needs -1mm of movement, it’s only going to move -0.1mm.
                                        • Snippyundefined
                                          Snippy @sebkritikel
                                          @sebkritikel
                                          ; Smart Drivers
                                          M569 P0.0 S1 D3 V2000 ; driver 0.0 goes forwards (extruder 0)
                                          M569 P0.1 S0 D3 V2000 ; driver 0.1 goes forwards (Z axis)
                                          M569 P0.2 S0 D3 V2000 ; driver 0.2 goes forwards (Z axis)
                                          M569 P0.3 S0 D3 V2000 ; driver 0.3 goes backwards (X axis)
                                          M569 P0.4 S0 D3 V2000 ; driver 0.4 goes backwards (Y axis)
                                          ; Motor Idle Current Reduction
                                          M906 I30 ; set motor current idle factor
                                          M84 S30 ; set motor current idle timeout
                                          ; Axes
                                          M584 X0.3 Y0.4 Z0.1:0.2 ; set axis mapping
                                          M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                                          M906 X1040 Y1040 Z1040 ; set axis driver currents
                                          M92 X80 Y80 Z800 ; configure steps per mm
                                          M208 X0:400 Y0:400 Z0:220 ; set minimum and maximum axis limits
                                          M566 X4000 Y4000 Z4000 ; set maximum instantaneous speed changes (mm/min)
                                          M203 X35000 Y35000 Z1500 ; set maximum speeds (mm/min)
                                          M201 X10000 Y10000 Z10000 ; set accelerations (mm/s^2)
                                          ; Extruders
                                          M584 E0.0 ; set extruder mapping
                                          M350 E16 I1 ; configure microstepping with interpolation
                                          M906 E940 ; set extruder driver currents
                                          M92 E409 ; configure steps per mm
                                          M566 E120 ; set maximum instantaneous speed changes (mm/min)
                                          M203 E3600 ; set maximum speeds (mm/min)
                                          M201 E250 ; set accelerations (mm/s^2)
                                          ; Kinematics
                                          M669 K1 ; configure CoreXY kinematics
                                          M574 X1 P"!io1.in" S1 ; configure X axis endstop
                                          M574 Y1 P"!io2.in" S1 ; configure Y axis endstop
                                          M574 Z1 P"!io3.in" S1 ; configure Z axis endstop
                                          ; Probes
                                          ; Sensors
                                          M308 S0 P"temp1" Y"thermistor" A"Heated Bed" T100000 B3950 C7.06e-8 ; configure sensor #0
                                          M308 S1 P"temp0" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
                                          M950 H0 C"out0" T0 ; create heater #0
                                          M143 H0 P0 T0 C0 S110 A0 ; configure heater monitor #0 for heater #0
                                          M307 H0 R0.128 K0.179:0.000 D11.50 E1.35 S1.00 B0 ; configure model of heater #0
                                          M950 H1 C"out1" T1 ; create heater #1
                                          M143 H1 P0 T1 C0 S300 A0 ; configure heater monitor #0 for heater #1
                                          M307 H1 R1.040 K0.469:0.000 D10.85 E1.35 S1.00 B0 V23.9 ; configure model of heater #1
                                          ; Heated beds
                                          M140 P0 H0 ; configure heated bed #0
                                          M950 F0 C"out4+out4.tach" Q8 ; create fan #0
                                          M106 P0 C"PCF" S0 L0 X1 B0.1 ; configure fan #0
                                          M563 P0 D0 H1 F0 ; create tool #0
                                          M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
                                          T0 ; select first tool
                                            sebkritikel @Snippy
                                            This, combined with what @droftarts is saying about where you're setting your Z datum , is why you're not seeing compensation occur in the negative Z direction. You could allow for negative moves in the Z direction, such as M208 Z-5:220 and/or adjust where you're setting the Z datum3f8f64bd-77ad-4e9f-a9e8-58f4961ba97f-image.png
                                            For a 410mmx410mm bed, a thickness of 3mm without supporting the underside will result in poor dimension accuracy for your parts, as the bed will naturally sag in the middle. 1.6mm is substantial. I would recommend a thicker bed in the range of 10mm to 12mm, or some adjustable screws to help support the center of the bed.
                                            Snippyundefined 1 Reply Last reply Reply Quote 1
