    Macro's - Repository?
    23
    4.3k
    • tsitalon1undefined
      tsitalon1
      Awesome guys, thanks for adding this!
      It'll help out the Duet newbies like me, hopefully I'll be able to contribute shortly.
        T3P3Tony administrators @Phaedrux
        @phaedrux Thanks - I have added them.
        Looking forward to seeing some more.
        • Jason Kundefined
          Jason K
          I LOVE THIS!
          I cant believe no one thought of this earlier.
          I know for myself, I sometimes get confused because there are so many ways to use a duet and I can't find an example for say a Cartesian vs a delta. The duet team does such a good job with documentation but it is an impossible task for a small team to give so many examples. (now that i own 3 duets im a little better).
          I imagine this will be another invaluable resource. Especially for people just starting out.
            T3P3Tony administrators @Jason K
            So I have added some macros provided by @deckingman
            It would be good to get some more off people, then i will have another look at the documentation page and slot in examples and links.
              deckingman @T3P3Tony
              @t3p3tony
              I did actually start a thread way back in May 2017 https://forum.duet3d.com/topic/162/macros-ideas-suggestions-tips-and-tricks to try and get people to submit ideas.
              There wasn't all that much feedback but you might find a couple more there.
                T3P3Tony administrators @deckingman
                @deckingman thanks, I will take a look
                • Alex.crundefined
                  Alex.cr
                  If I knew how to use github i would add these directly...
                  I did not write the first one, someone on the old forum did. Sorry stranger for not writing down your name.
                  [EDIT: @dc42 and @burtoogle are responsible for this macro]
                  The second one is a simple probe repeatability test with moves between.
                  These aren't rocket science but have helped me.
                  0_1530932915653_non linear test.txt
                  0_1530932923605_probe test.txt
                  Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                  Phaedruxundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @Alex.cr
                    @alex-cr The non-linear extrusion test is interesting, but how do you use the results? Non-linear extrusion is on my list to explore next.
                    Alex.crundefined 1 Reply Last reply Reply Quote 0
                      T3P3Tony administrators @Alex.cr
                      @alex-cr Thanks. I have added them to the repository.
                      • Alex.crundefined
                        Alex.cr @Phaedrux
                        @phaedrux said in Macro's - Repository?:
                        The intent is to measure the length of the extruded sections to ensure they all come out the same length, regardless of extrusion speed.
                        I need to add to the macro to supply rectraction because of my 1.2m bowden tubes on my main printer now so in reality I have not used the macro very much.
                        I really wish I could find the forum post to reference...
                        • fmaundefined
                          fma
                          But how do you fit the measured values, to get A and B params?
                          Frédéric
                          • Alex.crundefined
                            Alex.cr @fma
                            I found the link! Turns out it was @dc42 and @burtoogle that wrote the macro. Thanks guys!
                            https://forum.duet3d.com/topic/3625/new-beta-firmware-1-20-1rc2-and-duetwifiserver-1-20-1/14
                            @fma Set A=0.015 and B=0.0012 and start there. At least that's what I did. Extrusion was more consistent at higher speeds. These numbers worked on my direct drive system at the time.
                            I was not very scientific with it, it just helped so I left it there. That's what @dc42 had come up with on his setup.
                            I need to look into this again but since upgrading to a bondtech extruder the problem hasn't resurfaced.
                            • fmaundefined
                              fma
                              I'll try these values, but I would like to know how to compute them from a set of measures...
                              Frédéric
                              • Alex.crundefined
                                Alex.cr @fma
                                @fma This involves solving for a nonlinear equation. A recent posting shows sort of how to do it.
                                https://forum.duet3d.com/topic/5588/non-linear-extrusion
                                I have build an excel form to create a best fit equation, this may help you.
                                The values in the form are bogus, do not use those... enter your own.
                                0_1531274344816_nonlinear extrusion sheet.xlsx
                                  @alex-cr that's great. I will definitely be checking that out.
                                  • Alex.crundefined
                                    Alex.cr
                                    @Phaedrux I hope it's not too rough. My old engineering professors and current coworkers would kill me for not labeling all the axis...
                                    • fmaundefined
                                      fma
                                      Thanks! I used gnuplot, which is able to fit any curve, and successfully computes A and B. Here is how I did:
                                      • extrude 50mm (for example) at different speeds and read the real extrusion length;
                                      • build a table with 2 cols: first col = speed, second col = error from theorical extrusion / theorical extrusion. You need to revert the sign so the table contains the correction to retreive the correct extrusion;
                                      • save this table in a file called 'extrusion.dat';
                                      • in gnuplot, do:
                                      A = 1
                                      B = 1
                                      f(x) = A * X + B * x * x
                                      fit f(x) 'extrusion.dat' via A, B <<<<< will print A and B and errors
                                      plot 'extrusion.data'
                                      replot f(x)
                                      Hope this helps.
                                      Frédéric
