    Macro's - Repository?
    23
    4.4k
      T3P3Tony administrators @Phaedrux
      @phaedrux Thanks - I have added them.
      Looking forward to seeing some more.
      • Jason Kundefined
        Jason K
        I LOVE THIS!
        I cant believe no one thought of this earlier.
        I know for myself, I sometimes get confused because there are so many ways to use a duet and I can't find an example for say a Cartesian vs a delta. The duet team does such a good job with documentation but it is an impossible task for a small team to give so many examples. (now that i own 3 duets im a little better).
        I imagine this will be another invaluable resource. Especially for people just starting out.
          T3P3Tony administrators @Jason K
          So I have added some macros provided by @deckingman
          It would be good to get some more off people, then i will have another look at the documentation page and slot in examples and links.
            deckingman @T3P3Tony
            @t3p3tony
            I did actually start a thread way back in May 2017 https://forum.duet3d.com/topic/162/macros-ideas-suggestions-tips-and-tricks to try and get people to submit ideas.
            There wasn't all that much feedback but you might find a couple more there.
              T3P3Tony administrators @deckingman
              @deckingman thanks, I will take a look
              • Alex.crundefined
                Alex.cr
                If I knew how to use github i would add these directly...
                I did not write the first one, someone on the old forum did. Sorry stranger for not writing down your name.
                [EDIT: @dc42 and @burtoogle are responsible for this macro]
                The second one is a simple probe repeatability test with moves between.
                These aren't rocket science but have helped me.
                0_1530932915653_non linear test.txt
                0_1530932923605_probe test.txt
                Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
                Phaedruxundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @Alex.cr
                  @alex-cr The non-linear extrusion test is interesting, but how do you use the results? Non-linear extrusion is on my list to explore next.
                  Alex.crundefined 1 Reply Last reply Reply Quote 0
                    T3P3Tony administrators @Alex.cr
                    @alex-cr Thanks. I have added them to the repository.
                    • Alex.crundefined
                      Alex.cr @Phaedrux
                      @phaedrux said in Macro's - Repository?:
                      The intent is to measure the length of the extruded sections to ensure they all come out the same length, regardless of extrusion speed.
                      I need to add to the macro to supply rectraction because of my 1.2m bowden tubes on my main printer now so in reality I have not used the macro very much.
                      I really wish I could find the forum post to reference...
                      • fmaundefined
                        fma
                        But how do you fit the measured values, to get A and B params?
                        Frédéric
                        • Alex.crundefined
                          Alex.cr @fma
                          I found the link! Turns out it was @dc42 and @burtoogle that wrote the macro. Thanks guys!
                          https://forum.duet3d.com/topic/3625/new-beta-firmware-1-20-1rc2-and-duetwifiserver-1-20-1/14
                          @fma Set A=0.015 and B=0.0012 and start there. At least that's what I did. Extrusion was more consistent at higher speeds. These numbers worked on my direct drive system at the time.
                          I was not very scientific with it, it just helped so I left it there. That's what @dc42 had come up with on his setup.
                          I need to look into this again but since upgrading to a bondtech extruder the problem hasn't resurfaced.
                          • fmaundefined
                            fma
                            I'll try these values, but I would like to know how to compute them from a set of measures...
                            Frédéric
                            • Alex.crundefined
                              Alex.cr @fma
                              @fma This involves solving for a nonlinear equation. A recent posting shows sort of how to do it.
                              https://forum.duet3d.com/topic/5588/non-linear-extrusion
                              I have build an excel form to create a best fit equation, this may help you.
                              The values in the form are bogus, do not use those... enter your own.
                              0_1531274344816_nonlinear extrusion sheet.xlsx
                                @alex-cr that's great. I will definitely be checking that out.
                                • Alex.crundefined
                                  Alex.cr
                                  @Phaedrux I hope it's not too rough. My old engineering professors and current coworkers would kill me for not labeling all the axis...
                                  • fmaundefined
                                    fma
                                    Thanks! I used gnuplot, which is able to fit any curve, and successfully computes A and B. Here is how I did:
                                    • extrude 50mm (for example) at different speeds and read the real extrusion length;
                                    • build a table with 2 cols: first col = speed, second col = error from theorical extrusion / theorical extrusion. You need to revert the sign so the table contains the correction to retreive the correct extrusion;
                                    • save this table in a file called 'extrusion.dat';
                                    • in gnuplot, do:
                                    A = 1
                                    B = 1
                                    f(x) = A * X + B * x * x
                                    fit f(x) 'extrusion.dat' via A, B <<<<< will print A and B and errors
                                    plot 'extrusion.data'
                                    replot f(x)
                                    Hope this helps.
                                    Frédéric
