Ender 3 nothing working right
On my 24V 40W heater I had to reduce max PWM to 90% otherwise it will overshoot and fail the auto pid tune.
@wyvern thank you
Thank you to everyone for the help I'm getting decent prints now I'll probably hooking up the bltouch in a day or so hope u can handle that by my self but I'm not holding my breath. Lol
Just a note, don't know if it was my network or what, but yesterday I could not connect the printer, after an hour of farting around I ran M552 on the panel due- the IP address changed after a month of flawless communication.
So keep that in mind if that happens to you.
@wyvern said in Ender 3 nothing working right:
The IP address is allocated by the router. Most routers will allow you to set an IP address reservation so that the router always assigns the same IP address to a particular device. The router identifies devices from their MAC addresses. The MAC address of a Duet WiFi should never change unless you replace the WiFi module.
I think it is amazing that you have installed an Duet wifi in a printer that cost almost the same as the duet
Looking foward to see then end result. -
@martin1454 said in Ender 3 nothing working right:
Looking foward to see then end result.My Maestro Ender 3 works fantastic. I saw it as a cheap way to acquire the basic bits, and build what I wanted. I probably could have sourced the same parts from China for less, but this was a lot easier and faster.
@3dmntbighker said in Ender 3 nothing working right:
Yes, the Maestro is better matched to the Ender 3 from a pricing perspective, also the use of 24V power and lower current motors on the Ender 3 is a good match for the Maestro. A WiFi derivative of the Maestro (which would cost a little less to manufacture than the Ethernet version) might be an even better match, provided that the WiFi antenna can be kept out of the enclosure metalwork.
I love my Ender 3 with the Duet Wifi...it works great and now greatly out performs my Taz 6 printer in both speed and quality. Granted...my ender 3 is far from stock using a geared printable extruder first was using a Greg's wade bowden variant and now one called the Pitan, linear guide for the bed, polycarbonate v-slot wheels on the x and z axis as well as dual z rods and stepper motors.
The thing is so reliable now, just set and go.
There are really only 4 tiers of 3D printers.
Super low end- they just barely run and cost under $200, avoid.
Clone/enthusiast grade- usually do a good job with a little tweaking and sourcing of better parts- it's possible to get high end results with enough patience. $250-500
High end enthusiast- usually setup with all the goodies, think ultimaker- out of the box run like a expert adjusted/modified clone. $1000-3000
Commercial grade- huge machines- huge price tag, made for business unless you just really like 3D printing and have a huge wallet $5000+++
I have seen parts come out of my $270 Qidi Xone-2 come out as good as a ultimaker, the little guy has a mic6 build plate, 24V,32 bit board, all steel construction and 10 mm Z rods. 150X150X150 build size and weighs about 35lbs!
My Folgertech FT-5 has about $900 now, I have yet to install some of the upgrades, but I am just now getting the Qidi quality- hoping to surpass it after the bed/z axis upgrades.
IMHO it's worth putting a duet Wifi in a cheaper clone, part of the fun is making a clone/kit work as good or better than a $2000 printer, as they say built not bought.
I've taken the liberty of marking this as solved, as the original title doesn't reflect the recent posts.
