    Ender 3 nothing working right
    My Duet controlled machine
    ender 3 duet 2 wifi help
    3.4k
    • mudcruzrundefined
      mudcruzr
      Please post your config.g and your homing files (homeall.g, homex.g, homey.g and homez.g)
      • waggonburner3undefined
        waggonburner3
        Ok I'll upload them this evening.
          Did you test the endstops? https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
          waggonburner3undefined 1 Reply Last reply Reply Quote 1
            waggonburner3 @dc42
            @dc42 no I did not test them I will test them tonight after I post my settings.
              dc42 administrators @waggonburner3
              @waggonburner3 said in Ender 3 nothing working right:
              Also remember that 2-wire switch endstops use the 2 outer pins of the endstop connector on the Duet, which is not the same as on some other controller boards.
                waggonburner3 @dc42
                @dc42 yep that's how I have them hooked up.
                • 3dmntbighkerundefined
                  3dmntbighker
                  Almost nothing on the Ender matches Duet wiring. I had to juggle wires everywhere on mine. Creality doesn't even follow industry standards when they exist šŸ˜ž
                  Let me add that mine prints amazingly well now šŸ™‚
                  Scratch built CoreXY with Maestro
                  Heavily modified Ender 3 with Maestro
                  MPCNC work in progress with Duet WiFi
                    waggonburner3
                    I reinstalled everything hardware and software all endstops working everything moving in the right direction. Now trying to get the heater 1 to tune and not fault out everytime.
                    Wyvernundefined 1 Reply Last reply Reply Quote 0
                    • mudcruzrundefined
                      mudcruzr
                      Glad you're getting everything sorted out.
                      • Wyvernundefined
                        Wyvern @waggonburner3
                        @waggonburner3
                        On my 24V 40W heater I had to reduce max PWM to 90% otherwise it will overshoot and fail the auto pid tune.
                          waggonburner3 @Wyvern
                          @wyvern thank you
                            waggonburner3
                            Thank you to everyone for the help I'm getting decent prints now I'll probably hooking up the bltouch in a day or so hope u can handle that by my self but I'm not holding my breath. Lol
                            • Wyvernundefined
                              Wyvern
                              Just a note, don't know if it was my network or what, but yesterday I could not connect the printer, after an hour of farting around I ran M552 on the panel due- the IP address changed after a month of flawless communication.
                              So keep that in mind if that happens to you.
                                dc42 administrators @Wyvern
                                @wyvern said in Ender 3 nothing working right:
                                The IP address is allocated by the router. Most routers will allow you to set an IP address reservation so that the router always assigns the same IP address to a particular device. The router identifies devices from their MAC addresses. The MAC address of a Duet WiFi should never change unless you replace the WiFi module.
                                • Martin1454undefined
                                  Martin1454
                                  I think it is amazing that you have installed an Duet wifi in a printer that cost almost the same as the duet šŸ˜„
                                  Looking foward to see then end result. šŸ™‚ šŸ‘
                                  3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
                                    3dmntbighker @Martin1454
                                    @martin1454 said in Ender 3 nothing working right:
                                    My Maestro Ender 3 works fantastic. I saw it as a cheap way to acquire the basic bits, and build what I wanted. I probably could have sourced the same parts from China for less, but this was a lot easier and faster.
                                    dc42undefined 1 Reply Last reply Reply Quote 3
                                      dc42 administrators @3dmntbighker
                                      @3dmntbighker said in Ender 3 nothing working right:
                                      Yes, the Maestro is better matched to the Ender 3 from a pricing perspective, also the use of 24V power and lower current motors on the Ender 3 is a good match for the Maestro. A WiFi derivative of the Maestro (which would cost a little less to manufacture than the Ethernet version) might be an even better match, provided that the WiFi antenna can be kept out of the enclosure metalwork.
                                      • JamesMundefined
                                        JamesM
                                        I love my Ender 3 with the Duet Wifi...it works great and now greatly out performs my Taz 6 printer in both speed and quality. Granted...my ender 3 is far from stock using a geared printable extruder first was using a Greg's wade bowden variant and now one called the Pitan, linear guide for the bed, polycarbonate v-slot wheels on the x and z axis as well as dual z rods and stepper motors.
                                        The thing is so reliable now, just set and go.
                                        • Wyvernundefined
                                          Wyvern
                                          There are really only 4 tiers of 3D printers.
                                          Super low end- they just barely run and cost under $200, avoid.
                                          Clone/enthusiast grade- usually do a good job with a little tweaking and sourcing of better parts- it's possible to get high end results with enough patience. $250-500
                                          High end enthusiast- usually setup with all the goodies, think ultimaker- out of the box run like a expert adjusted/modified clone. $1000-3000
                                          Commercial grade- huge machines- huge price tag, made for business unless you just really like 3D printing and have a huge wallet $5000+++
                                          I have seen parts come out of my $270 Qidi Xone-2 come out as good as a ultimaker, the little guy has a mic6 build plate, 24V,32 bit board, all steel construction and 10 mm Z rods. 150X150X150 build size and weighs about 35lbs!
                                          My Folgertech FT-5 has about $900 now, I have yet to install some of the upgrades, but I am just now getting the Qidi quality- hoping to surpass it after the bed/z axis upgrades.
                                          IMHO it's worth putting a duet Wifi in a cheaper clone, part of the fun is making a clone/kit work as good or better than a $2000 printer, as they say built not bought.
                                            I've taken the liberty of marking this as solved, as the original title doesn't reflect the recent posts.
