    Ender 3 nothing working right
    My Duet controlled machine
    ender 3 duet 2 wifi help
    3.4k
    • waggonburner3undefined
      waggonburner3
      I reinstalled everything hardware and software all endstops working everything moving in the right direction. Now trying to get the heater 1 to tune and not fault out everytime.
      Wyvernundefined 1 Reply Last reply Reply Quote 0
      • mudcruzrundefined
        mudcruzr
        Glad you're getting everything sorted out.
        • Wyvernundefined
          Wyvern @waggonburner3
          @waggonburner3
          On my 24V 40W heater I had to reduce max PWM to 90% otherwise it will overshoot and fail the auto pid tune.
          waggonburner3undefined 1 Reply Last reply Reply Quote 1
            waggonburner3 @Wyvern
            @wyvern thank you
              waggonburner3
              Thank you to everyone for the help I'm getting decent prints now I'll probably hooking up the bltouch in a day or so hope u can handle that by my self but I'm not holding my breath. Lol
              • Wyvernundefined
                Wyvern
                Just a note, don't know if it was my network or what, but yesterday I could not connect the printer, after an hour of farting around I ran M552 on the panel due- the IP address changed after a month of flawless communication.
                So keep that in mind if that happens to you.
                  dc42 administrators @Wyvern
                  @wyvern said in Ender 3 nothing working right:
                  The IP address is allocated by the router. Most routers will allow you to set an IP address reservation so that the router always assigns the same IP address to a particular device. The router identifies devices from their MAC addresses. The MAC address of a Duet WiFi should never change unless you replace the WiFi module.
                  • Martin1454undefined
                    Martin1454
                    I think it is amazing that you have installed an Duet wifi in a printer that cost almost the same as the duet šŸ˜„
                    Looking foward to see then end result. šŸ™‚ šŸ‘
                    3dmntbighkerundefined 1 Reply Last reply Reply Quote 1
                    • 3dmntbighkerundefined
                      3dmntbighker @Martin1454
                      @martin1454 said in Ender 3 nothing working right:
                      My Maestro Ender 3 works fantastic. I saw it as a cheap way to acquire the basic bits, and build what I wanted. I probably could have sourced the same parts from China for less, but this was a lot easier and faster.
                      Scratch built CoreXY with Maestro
                      Heavily modified Ender 3 with Maestro
                      MPCNC work in progress with Duet WiFi
                      dc42undefined 1 Reply Last reply Reply Quote 3
                        dc42 administrators @3dmntbighker
                        @3dmntbighker said in Ender 3 nothing working right:
                        Yes, the Maestro is better matched to the Ender 3 from a pricing perspective, also the use of 24V power and lower current motors on the Ender 3 is a good match for the Maestro. A WiFi derivative of the Maestro (which would cost a little less to manufacture than the Ethernet version) might be an even better match, provided that the WiFi antenna can be kept out of the enclosure metalwork.
                        • JamesMundefined
                          JamesM
                          I love my Ender 3 with the Duet Wifi...it works great and now greatly out performs my Taz 6 printer in both speed and quality. Granted...my ender 3 is far from stock using a geared printable extruder first was using a Greg's wade bowden variant and now one called the Pitan, linear guide for the bed, polycarbonate v-slot wheels on the x and z axis as well as dual z rods and stepper motors.
                          The thing is so reliable now, just set and go.
                          • Wyvernundefined
                            Wyvern
                            There are really only 4 tiers of 3D printers.
                            Super low end- they just barely run and cost under $200, avoid.
                            Clone/enthusiast grade- usually do a good job with a little tweaking and sourcing of better parts- it's possible to get high end results with enough patience. $250-500
                            High end enthusiast- usually setup with all the goodies, think ultimaker- out of the box run like a expert adjusted/modified clone. $1000-3000
                            Commercial grade- huge machines- huge price tag, made for business unless you just really like 3D printing and have a huge wallet $5000+++
                            I have seen parts come out of my $270 Qidi Xone-2 come out as good as a ultimaker, the little guy has a mic6 build plate, 24V,32 bit board, all steel construction and 10 mm Z rods. 150X150X150 build size and weighs about 35lbs!
                            My Folgertech FT-5 has about $900 now, I have yet to install some of the upgrades, but I am just now getting the Qidi quality- hoping to surpass it after the bed/z axis upgrades.
                            IMHO it's worth putting a duet Wifi in a cheaper clone, part of the fun is making a clone/kit work as good or better than a $2000 printer, as they say built not bought.
                              I've taken the liberty of marking this as solved, as the original title doesn't reflect the recent posts.
