    Zesty Nimble Direct Drive extruder launched on KS
    44
    6.5k
    • DjDemonDundefined
      DjDemonD
      I'm backing them, I can vouch that flexible drive extruders work having tried the competition, and this one is simpler, looks easier to use and is even lighter.
      A delta/corexy must have. Useful for dual/triple extrusion on cartesian machines too I suspect.
      www.precisionpiezo.co.uk
      • Dougal1957undefined
        Dougal1957
        yep pledged for a pair as well
        • briangilbertundefined
          briangilbert
          Thanks for the support guys!
          Co-creator of the Zesty Nimble direct drive extruder
          • Rommieundefined
            Rommie
            Me too yay
              deckingman
              Let me know when you come up with a way to graft 3 of them on to a Diamond hot end and I might be tempted.
                T3P3Tony administrators
                https://twitter.com/ZestyTechnology/status/790097955843825666
                  deckingman
                  OK so I'm tempted. It's bloody huge though….......
                    Yes - time for a bigger delta to accommodate it 😉
                      Dougal1957
                      Oh I am tempted to increase my Pledge now to 4 of the things rather than 2 Think it would work well on my MegaBeast (1.5 tall 750mm horizontal extrusions).
                        deckingman
                        Knowing how much the Diamond needs high air flow to cool the heat sinks, that ducting arrangement with the Nimbles encroaching into it would concern me a bit. I'd like to see some heat break temperature data or real world test results before I committed any hard earned.
                        • ShadowXundefined
                          ShadowX
                          It sounds like your hot end should be using a blower fan instead of an axial fan if you need high air flow with higher pressure.
                            briangilbert
                            I'm planning to use a blower fan when I set mine up (once I have Duex2)
                              briangilbert
                              the image in the tweet was a quick blocking up to prove it will work, we're refining the design of the diamond mount before we release it
                              • ShadowXundefined
                                ShadowX
                                Deckingman,
                                One thing thing to consider is adding an insulation blanket between the hot end nozzle interface and the cooling fins and also down a bit to cover the nozzle but exposing the tip area. There are ceramic fiber sheets you can order on Ebay that you cut to shape and you can use high-temp kapton tape to attach to the surfaces. I wrap my hot end block with the insulation and it helps maintain the heat where I need it and not radiate to surrounding areas where I don't want it. It helps improve the temperature stability.
                                  deckingman
                                  @ShadowX:
                                  Deckingman,
                                  Yes, I've been using a Diamond for quite a while now. Insulation between the nozzle and hot end is absolutely essential. The "stock" RepRap.Me hot end is supplied with 3 layers of "fire blanket". They work well but have a tendency to fray at the edges. When I assemble them, I put the 3 layers of insulation together then stick Kapton tape around the edges. It works but isn't a very elegant solution. There is a user on the RepRap forums who cut some from silicone sheet (as used for cooking trays) and kindly supplied me with some extra samples. I did some back to back tests to compare the two by fitting a thermocouple inside the heat sink in the area of the thread (the heat break). The results aren't conclusive because it is very difficult to position a thermocouple inside the heat break and know that you have exactly the same contact when you do it a second time. Also, there were other differences apart from the insulation as they were two different assemblies. So although the parts were the same specification, there were not the exact same parts, so it is possible that one fan may have bee slightly more efficient than the other. Anyway, for tests I did with the standard "fire blanket" insulation, the temperature I measured at the heat break with the hot end at 200 deg C was 46.5 deg C and was stable after 180 seconds (I carried on for another 120 seconds just to make sure there was no "creep". With the silicone sheet insulation, the temperature was 51.7 deg C and stable after the same time period. However, for reasons given above, I would not like to say that the silicone is definitely worse (and in any case 51.7 deg C is probably acceptable).
                                  As for wrapping the nozzle in insulation, I understand that some people like to do this. I prefer to use the minimum required print cooling. For me, using cooling only if the layer time is less than 30 seconds, and then not all for the first 5 layers works well. I'm also careful not to have the print cooling directed at the nozzle.
                                    deckingman
                                    @ShadowX:
                                    It doesn't need to be high pressure - just a minimum of 18 c.f.m. I'm using a "normal" 50mm square 24v fan which gives around 22 c.f.m. (can't remember the exact figure). You'd have to be careful how you position a high pressure fan so as to have the airflow coming out through the heat sink fins and not blowing directly on to the brass nozzle.
                                      deckingman
                                      @briangilbert:
                                      Good to hear. You'd probably need a range of mounting options to suit different machines (mine isn't a delta).
                                        briangilbert
                                        @deckingman
                                        Can you provide some info on your printer, how do you have the diamond mounted currently?
                                          briangilbert
                                          Some short videos showing some of the unique selling points of the Nimble..
                                          Pulling force of Nimble: https://www.youtube.com/watch?v=iLDT1MgwAKg
                                          Ambidextrous: https://www.youtube.com/watch?v=EVk5cfnrU6Y
                                          Unobstructed filament changing: https://www.youtube.com/watch?v=ok1W635JVfA
                                          • Zesty_Lykleundefined
                                            Zesty_Lykle
                                            As I mentioned on a Reprap post, the area of the smallest opening of the designed shroud is slightly bigger than the opening of the standard shroud used by the Diamond Nozzle.
                                            I am in the process of tweaking it further and would love to have some more detail on how people intend to use it.
                                            The fan I am using currently is 60x60x25. I used this fan as it is nice and quiet. If I can find a smaller fan with 18cfm I will use that. That would make my life easier. And as you know, Zesty Technology is all about easy! 🙂
                                            The difficulty I am currently having is to make the shape such that it can be printed on a normal printer, instead of sending it off to Shapeways. Getting there, but it is a hassle.
                                            Lykle
                                            Lykle
                                            Design, make and enjoy life
                                            Co Creator of the Zesty Nimble
