PanelDue firmware 1.23 now available
@samlogan87 said in PanelDue firmware 1.23 now available:
@dc42 do you have any idea when you might implement changes for people who reassign heaters so they display correctly on the panel due. I have swapped my hot end and heat bed around as I use a ssr for the heatbed but I can not make changes to the hot end temp via the screen at the moment as it does not register any values for it (just zeros)
Kind Regards,
SamReworking the whole tools/heaters thing in on my list but will be a lot of work that I don't have time for at present. However, RepRapFirmware will soon allow you to reallocate pins, so you will be able to use the conventional heater numbering.
@phaedrux said in PanelDue firmware 1.23 now available:
I decided to give the PanelDue logo thing another shot, however it looks like bmp2c.exe is no longer supported on windows since it's a 16-bit app?
Runs fine on my Win10 x64 as well.
(Feel free to PM me the bmp and I'll return the .c file to expedite things while you figure it out) -
The version of bmp2c.exe that I am using is a different size from the one in that directory listing. I have added the one I am using to the 1.23.2 release files.
@dc42 That one worked. Thanks.
@dc42 said in PanelDue firmware 1.23 now available:
I chose the homing button colours to be similar to Duet Web Control.
At the risk of involving in bikeshedding, the blue in the Web UI seems to me at least as emphasized as the orange. In the PanelDue it's gray and closer to the background color. Not a big deal though and I it's subjective anyway.
Additional feedback:
- Having the XYZ display in the Move panel is very user friendly.
- The red heaters color is very visible and would benefit also Dark Theme 1, instead of the dark red/brown color.
It may be that highlighting an axis being NOT homed is more important than highlighting when an axis has been homed. Usually, when the axis has been homed already, you don't ever need to press that button again -- greying out makes sense in this context.
Definitely, though, achieving consistency between DWC and PD is a good goal.
@phaedrux
Thank you that was fine, everything is working now. -
@dc42 Thank you Logo work finefor me.
After update of my 7i there is always a "residual" contour of the warning windows at the right.
@brunofporto That's been reported and fixed. See the first post for link to 1.23.2.
@phaedrux Sorry then
I'll look for it, thank you!
For the V2 versions you will find an update file to put its logo.
Thank you -
@synergy41 said in PanelDue firmware 1.23 now available:
Thank youIf your v2 PanelDue has the ATSAM3S4B processor (not the ATSAM3S2B) then you can add the logo to the standard file, just as you would add the logo to the -nologo files for V3.
BIG THANKS for the new arrows! (Would be great if they could also be updated in the DWC the same way to have it consistent) -
I like the dark2 too !!!
Is really useful during the night work. All the time i watched the old light version it was a flash !
Thanks buddies -
hello they are a bug with translation to french some word messing
See my response to your other thread.
