    Ender 3 Pro configuration
    8.2k
    • baesjerkerundefined
      baesjerker
      Thanks again for a really good reply. I will look into 123 block and swapping out those springs. Looking forward to more replies. I’m going to try to test print something later today.
      • PaulHewundefined
        PaulHew
        If you would like to see my settings for my ender3 with a BL Touch for comparison, please let me know.
        baesjerkerundefined NoSkillzEngineerundefined 2 Replies Last reply Reply Quote 1
          baesjerker @PaulHew
          @paulhew hi. I would love to. Please share.
          • NoSkillzEngineerundefined
            NoSkillzEngineer @PaulHew
            @paulhew said in Ender 3 Pro configuration:
            I would be curious what XY offset you are using and what mount you are using, I kinda eye-balled it with my dial caliper.
            It is worth noting that my bedmesh and bed.g files are most likely going to change, but it hits the bed right now, so, for now, it is good enough to move onto the next problem.
            I would be curious what is different between ours,
            • PaulHewundefined
              PaulHew
              Before my last upgrades, these configs are for Ender3 Pro which has a Bullseye duct and its BL Touch Mount, I am also running a Maestro board in my printer and using a PanelDue touch screen. All original hardware.
              0_1556009924222_config.g
              0_1556009972883_bed.g
              0_1556009989340_deployprobe.g
              0_1556009998929_homeall.g
              0_1556010027421_homex.g
              0_1556010036914_homey.g
              0_1556010048946_homez.g
              0_1556010058346_retractprobe.g
              Hope these help!
              P.
              baesjerkerundefined 1 Reply Last reply Reply Quote 2
                baesjerker
                Ok. So I printed a test cube yesterday. Usually when I printed something with the stock Ender 3 Pro board, the BLTouch would probe the bed before it starts to print, but not this time. The print looked decent, but a little squished in the layers. I need to experiment a bit here. BUT the strangest thing happened when the print finished. The extruder just stopped at the very last point in the very last layer and then the extruder retracted all filament from the nozzle and all the way back to the filament spool.
                I think this has to be related to Cura somehow. I’m going to try reprap flavor and some tunings found on this forum.
                This is a learning curve, but it’s fun to see progress.
                  baesjerker @PaulHew
                  @paulhew great! Thank you!
                  • Vetiundefined
                    Veti
                    since a lot of people are converting their ender 3s it might make sense to include this as a default option in the configurator
                    • PaulHewundefined
                      PaulHew
                      @Veti Those configs are for a stock Ender 3 Pro with a BL Touch mounted on these parts.
                      https://docs.google.com/spreadsheets/d/e/2PACX-1vS2TxsX-kBR6hmoeuBAtugCa8P2651bOPuQJ76QD8jk-UFWg4FWrNI2Ca36mKzLy2FUOWAu_IpzywLo/pubhtml?gid=1441642341&single=true
                      BULLSEYE_BASE_CREALITY_9.27
                      Bullseye_Duct_9.27
                      ALL_BLT_LEFT_X-48_Y-10_3.29
                      I was still unsure of the thermistor params, but the ones in the config seemed to work OK.
                      Regards
                      Paul.
                      • Vetiundefined
                        Veti
                        ender 3 uses epocs 100k. Marlin Thermistor table 1
                        see
                        https://forum.duet3d.com/topic/9464/m305-thermistor-values-for-the-duet-maestro-on-the-ender-3-pro/9
                        • PaulHewundefined
                          PaulHew
                          Thanks @Veti I used those params in the end, I remember.
                            baesjerker
                            Thanks again for sharing your configs. I noticed right away that the heated bed/nozzle did not get hot enough so I kept the stock config here.
                            M305 P1 T100000 B4138 R4700
                            I also changed the xy offset to match my bltouch mount because I don't have a bullseye. Even after that it still seems to probe on the outside. I bumped "Y" again and it is probing on the bed again.
                            I am running a test print again using Slic3r. Checked "Use relative E distances".
                              Phaedrux Moderator @baesjerker
                              @baesjerker said in Ender 3 Pro configuration:
                              You'll need to check your start and end gcode in the slicer. It specifies what happens before and after the print. To home before printing there needs to be a G28. And to lift the nozzle after or at least move it away you can use G28 X to home the X axis to move it away from the print. You can get as fancy as you want.
                              The retracting all the filament thing happens when cura is set to use absolute extrusion and the end gcode tells it to retract a bit of filament but instead of retracting just a bit, it commands it to go all the way back to the very beginning of extrusion. Setting cura to use relative extrusion distances will solve that.
                              baesjerkerundefined 1 Reply Last reply Reply Quote 1
                                baesjerker @Phaedrux
                                Thank you @phaedrux Slic3r stock with checked " Use relative E distances" solved it, but I really don't like Slic3r. I find Cura much easier to use.
                                I will look into how to use relative extrusion in Cura.
                                  It's an option under the Special Modes menu heading. It might be hidden by default.
                                    @phaedrux Awesome. Found it.
                                      baesjerker
                                      Now everything seems to be working like it was when using my stock Ender 3 Pro board.
                                      Print quality is more or less the same, maybe a bit worse than before, but I need to experiment a little more with the duet config and in Cura.
                                      But the stepper motor noise is almost gone they are so much quieter now!
                                      I also had to lower the current for the stepper motors. They where running really hot using stock (x, y, z, e) (725, 725, 725, 900). Trying to find the magic numbers here.
                                      I see everything from 400 to 900 on this forum.
                                      NoSkillzEngineerundefined 1 Reply Last reply Reply Quote 1
                                        The Ender 3 uses low current motors and 24V power, so I am not surprised that you need to reduce motor current. Stepper motor current is adjustable in steps of 100mA on the Duet WiFi/Ethernet, and 50mA on the Duet Maestro. So 600mA may be a good value to try, perhaps a little more on the extruder motor if necessary.
                                        baesjerkerundefined 1 Reply Last reply Reply Quote 0
                                        • JamesMundefined
                                          JamesM
                                          I've been using the following currents on my Ender 3 since I put the Duet wifi in it without issue.
                                          M906 X950.00 Y950.00 Z850.00 E900.00 I30
                                          I think the motors at their hottest hit mid 40C range so not hot for stepper motors.
                                          • Vetiundefined
                                            Veti
                                            the ender 3 motors are
                                            x,y,z 0.84A
                                            e 1A
                                            https://gist.github.com/knoopx/e6c40a009e796203b93a75a3ed6a5ab8
                                            950 might be a little bit hight for x and y.
