    Burnin’ down the house.
    17
    2.0k
    • chriskimbrundefined
      chriskimbr @gavatron3000
      @gavatron3000 Just the vents that you see.
      Been running it like this, for some reason it got really hot this time.
        Yikes. 😬
        • frank26080115undefined
          frank26080115
          Got any specs of your hardware? How much current you are passing? On resistance of the MOSFET? It'll be a good case study.
          • Edgars Batnaundefined
            Edgars Batna
            That doesn't look like proper airflow to me. I suppose the widening gaps prevented it from catching fire. My suggestion is to make a force-ventilated case that encompasses all the components as opposed to covering them one by one.
            • NeoandGeoundefined
              NeoandGeo
              I had an identical looking Mosfet almost catch fire about a year ago. Had proper airflow over the top of it. Buying cheap random brand parts from Amazon usually works out great, but sometimes you get a dud.
                A Former User @chriskimbr
                @chriskimbr
                • always-on fan on top?
                • next enclosure out of PolyCarbonat (choose black for UV-protection) (is flame reluctant (not unflammable, but at least it takes longer))?
                chriskimbrundefined 1 Reply Last reply Reply Quote 0
                  chriskimbr @A Former User
                  @lb Found out why it overheated. On the mainboard where you screw in the bed heater wires, they were little exposed and touching. so it arced and started heating up. Make sure when you screw your wires into board that no metal wire is exposed and that its covered so they don't touch or arc.
                  • gtj0undefined
                    gtj0 @chriskimbr
                    @chriskimbr That's what the ferrules are for. 🙂
                    A Former User? 1 Reply Last reply Reply Quote 2
                      A Former User @gtj0
                      @gtj0
                      But even with ferrules you need a good light if you do that in the night, because in a dim lit room it happened to me that even with ferrule-crimping I missed one of those wires thin like a hair... 😉 but yeah it is always good to do the complicated things in the morning with the sun shining I guess
                      @chriskimbr
                      Will check on saturady my wiring again after seeing your picture 😞 good luck & thanks for sharing!
                      • fmaundefined
                        fma
                        I recently bought some fire retardant ABS, from here:
                        http://www.sovb3d.fr/abs-175mm-ignifuge-1kg/52-fil-abs-blanc-ignifuge-175mm-1kg.html
                        I ran a test, and it indeed does not propagate fire.
                        Frédéric
                        • zaptaundefined
                          zapta
                          You want to use low ON resistance mosfet to reduce the generated heat. For example, like this one
                          https://www.auberins.com/index.php?main_page=product_info&cPath=2_30&products_id=288
                          • JRDMundefined
                            JRDM
                            Did you need more than 15A of current, and if so, why?
                            • DocTruckerundefined
                              DocTrucker @JRDM
                              @jrdm perhaps because they are following recommended heating capacities and for cost reasons are sticking to 12V.
                              Folowing the Duet docs gives over 15A for a 220mm square bed. Plenty of beds bigger than this about too. Large enough to give the 18A current limit of the Duet 2s a threat.
                              https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater
                              Where has 15A come from?
                              JRDMundefined 1 Reply Last reply Reply Quote 0
                              • JRDMundefined
                                JRDM @DocTrucker
                                @doctrucker said in Burnin’ down the house.:
                                OK I thought most DC beds had switched to allowing two different voltages.
                                According to the Duet wiki, that's the rating of the fuse provided for protecting bed circuit. At first glance, 18A ATO fuses aren't readily available.
                                  DocTrucker @JRDM
                                  @jrdm fair point! 😄 The docs I linked specified 18A, but I think not all the Duet 2s had fuses and it's the fuse holder that limits ot to 15A.
