    Heated build plate.
    3D Printing General Chat
    1.1k
    • fmaundefined
      fma @smoki3
      @smoki3 said in Heated build plate.:
      Magnets looses his strength at high temperatures.
      Rare earth magnets handle higher temperatures than standard neodym magnets (there are high temperature neodym, but they are more expensive).
      I prefer to use a magnetic foil and a ferro foil. So you have the whole surface as magnetic area.
      I have a similar setup.
      Frédéric
      DallasHundefined 1 Reply Last reply Reply Quote 0
      • DallasHundefined
        DallasH @fma
        @fma
        i am using Samarium-Cobalt magnets 5lb's pull each, good up to 570 Deg.F
        • DallasHundefined
          DallasH @Gone2Far
          @gone2far
          Ultimately I want to do PEEK, Carbon Fiber, ect engineering grade materials.0_1560913350063_magnetic plate.jpg
          • DallasHundefined
            DallasH @DallasH
            Is there any effect on the silicone heater from the magnetic fields?
              Phaedrux Moderator @DallasH
              @dallash said in Heated build plate.:
              No, but some probes can be affected by the magnets. BLTouch for example. Maybe others?
              • DallasHundefined
                DallasH @Phaedrux
                @phaedrux said in Heated build plate.:
                well that could suck, my BL Touch is to be delivered Thursday. any way of sheilding the touch? wire wrap or something?
                Phaedruxundefined Scachiundefined 2 Replies Last reply Reply Quote 0
                  @dallash I'm not too sure really. If it does end up affecting your heightmap you can manually edit the .CSV file to bring the erroneous points in line with the rest.
                  It's possible the newer BLTouch aren't as effected by it?
                  So definitely report back.
                  • Scachiundefined
                    Scachi @DallasH
                    @dallash There is an option "B1" to stop the bed heater during probing:
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                    • PaulHewundefined
                      PaulHew
                      Railcores probe a mag bed with a BL Touch between the magnets. Do not know if you could do that with the spec of your magnets.
                      • DallasHundefined
                        DallasH
                        Thanks for the insight, I will post results, i'm still a couple weeks away from running, waiting for a new design Bondtech Bmg X2 with direct mosquito mounts. still machining parts for the print carriage
