Heated build plate.
3D Printing General Chat
1.1k
    DallasH
    Does anyone have recommendations for a magnetic build surface. This is what I am building and have everything except for the actual top magnetic plate. please comment if you see something that doesn't look like it will work properly.
    Thanks
    ![alt text](![image url](![image url](0_1560815891241_heat bed exploded.jpg image url)))
    undefined 1 Reply Last reply 19 Jun 2019, 03:09 Reply Quote 0
      Gone2Far
      How big, what plastics are you printing with?
      I'm currently using a CHPOWER Creality Magnetic build surface from Amazon. Very flat, prints PLA very well. Downsides: 300x300 mm only (could trim smaller), max 70C temp. Have not tried it with PETG, which I usually like to print with 90C bed temp.
      I was looking at the magnetic beds sold by Geckotek, but got an EZ-Stik Hot print surface to try. At first, was really liking it, but started having problems with the filament not sticking after only about 15-20 prints. I think their magnetic beds all come with that surface applied.
      Original Prusa i3 MK2S
      Large Kossel Homebrew
      undefined 1 Reply Last reply 19 Jun 2019, 03:02 Reply Quote 0
        smoki3
        1000 Watt seems to be very very high. Magnets looses his strength at high temperatures.
        I prefer to use a magnetic foil and a ferro foil. So you have the whole surface as magnetic area.
        undefined 1 Reply Last reply 18 Jun 2019, 07:14 Reply Quote 0
          fma @smoki3
          @smoki3 said in Heated build plate.:
          Rare earth magnets handle higher temperatures than standard neodym magnets (there are high temperature neodym, but they are more expensive).
          I have a similar setup.
          Frédéric
          undefined 1 Reply Last reply 19 Jun 2019, 02:59 Reply Quote 0
            DallasH @fma
            @fma
            i am using Samarium-Cobalt magnets 5lb's pull each, good up to 570 Deg.F
              DallasH @Gone2Far
              @gone2far
              Ultimately I want to do PEEK, Carbon Fiber, ect engineering grade materials.0_1560913350063_magnetic plate.jpg
                DallasH @DallasH
                Is there any effect on the silicone heater from the magnetic fields?
                undefined 1 Reply Last reply 19 Jun 2019, 03:20 Reply Quote 0
                  Phaedrux Moderator @DallasH
                  @dallash said in Heated build plate.:
                  No, but some probes can be affected by the magnets. BLTouch for example. Maybe others?
                  undefined 1 Reply Last reply 19 Jun 2019, 03:26 Reply Quote 0
                    DallasH @Phaedrux
                    @phaedrux said in Heated build plate.:
                    well that could suck, my BL Touch is to be delivered Thursday. any way of sheilding the touch? wire wrap or something?
                    undefined undefined 2 Replies Last reply 19 Jun 2019, 03:33 Reply Quote 0
                      @dallash I'm not too sure really. If it does end up affecting your heightmap you can manually edit the .CSV file to bring the erroneous points in line with the rest.
                      It's possible the newer BLTouch aren't as effected by it?
                      So definitely report back.
                        Scachi @DallasH
                        @dallash There is an option "B1" to stop the bed heater during probing:
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
                          PaulHew
                          Railcores probe a mag bed with a BL Touch between the magnets. Do not know if you could do that with the spec of your magnets.
                            DallasH
                            Thanks for the insight, I will post results, i'm still a couple weeks away from running, waiting for a new design Bondtech Bmg X2 with direct mosquito mounts. still machining parts for the print carriage
                            5 out of 13
