Endstop switches doesnt work
@droftarts i checked my wiring 3 times. i measured with a multimeter on the plug, and ih have signal or no signal, but the duet doesn't recognize the signal. i know that only work in x and y because my config.
But x and y doesn't work. -
@goodchrhere said in Endstop switches doesnt work:
M574 X1 Y1 S1can you manually put this command in the console and try again?
post the actual output of M119 before and after the closing the endstop -
@veti i will do that today or tomorrow evening.
Looking at https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
... where exactly did you plug in the two wires coming from the endstop switches? -
@themelle i did that, i checked the wiring 3 times.
@themelle said in Endstop switches doesnt work:
... where exactly did you plug in the two wires coming from the endstop switches?This.. we need pictures of where the switches are plugged in to the switches and the duet. And dont take it that we are saying you are wrong we are only trying to help you, so for us to do that we need to see if there is anything wrong you might have missed.
@calvinx okay i will make photos today or tomorrow evening.
thanks for your help -
okay, i dont know, i had new wired and x and y works. i'm an idiot xD
What i have to chance in my config, to active z with the same switch? -
@goodchrhere I'm glad you got it working!
To have Z axis behaving as X and Y you should just remove the linesM574 Z1 S3 ; set endstops controlled by motor stall detection ; Z-Probe M574 Z1 S2 ; set endstops controlled by probe from
config.g
I‘t works fine, thanks for your helps!
