    Slow printing whit duet2 wifi on ender 3 pro
    658
    • hannes0913undefined
      hannes0913
      hello i have a question about my duet 2 wifi.
      well after a while I didn't use my printer ender 3 pro anymore with a duet 2 wifi board.
      well I wanted to print an x again but now print that maximum but with 8mm / s have already updated the firmware also on newly configured but nothing help.
      can someone help maybe.
      this is terrible
        hannes0913
        when I start the printer and click on homing, everything still works perfectly in terms of speed.
        even if I operate the printer manually, there is still nothing going on until I put a file in it to print, then it suddenly becomes very slow.
        then print it with 8mms and wait for a few seconds after each line before it continues
        • T3P3Tonyundefined
          T3P3Tony administrators
          hey @hannes0913 please can you share the gcode file you are trying to print.
          Also what slicer are you using?
          www.duet3d.com
          • oliofundefined
            oliof
            this is usually the case when the slicer talks about speeds to the printer in Marlin units which is mm/sec on most settings, whereas RepRapFirmware sets limits in mm/min.
            Especially if you use Cura, try disabling Acceleration Control and see if that improves speeds. Similar on PrusaSlicer if you set the GCode flavor to Marlin and set speeds in the additonal settings page that comes up onlz when you do that.
              hannes0913
              i use slicer cura
              ; generated by RepRapFirmware Configuration Tool v2 on Thu Dec 13 2018 20:04:59 GMT+0000 (Greenwich Mean Time)
              M550 P"Ender3" ; Set machine name
              M552 S1 ; Enable network
              M587 S"rdint01" P"golgofrinsham" ; Configure access point. You can delete this line once connected
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S0 ; Drive 0 goes backwards
              M92 X80.00 Y80.00 Z400.00 E100.00 ; Set steps per mm
              M566 X900.00 Y900.00 Z150.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; Set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
              M906 X800.00 Y800.00 Z800.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X200 Y180 Z200 S0 ; Set axis maxima
              M574 X1 Y1 S1 ; Set active low and disabled endstops
              M574 Z1 S2 ; Define Z to use Probe. Home to Min
              M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
              G31 P25 X-17 Y-6 Z1.1 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
              M557 X20:160 Y20:180 S20 ; Define mesh grid
              M305 P1 T100000 B4400 R4700 ; Set thermistor + ADC parameters for heater 1
              M563 P0 D0 H1 ; Define tool 0
              ; BLTouch - Heaters
              M307 H3 A-1 C-1 D-1 ; Disable the 3rd Heater to free up PWM channel 5 on the Duex board
              • Vetiundefined
                Veti
                set the g code flavour to reprap in the printer config in cura.
                hannes0913undefined 1 Reply Last reply Reply Quote 0
                  hannes0913 @Veti
                  @Veti that's how it is already imaged, but it still prints slowly
                  • Vetiundefined
                    Veti
                    post the beginning of a g code where it is slow.
                    hannes0913undefined 2 Replies Last reply Reply Quote 0
                      hannes0913 @Veti
                      @Veti what do you mean?
                      • T3P3Tonyundefined
                        T3P3Tony administrators @hannes0913
                        @hannes0913 the file you are trying to print, that is printing slow. Please upload that.
                        www.duet3d.com
                          hannes0913 @Veti
                          @Veti
                          M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                          M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                          M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                          M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                          M220 S100 ;Reset Feedrate
                          M221 S100 ;Reset Flowrate
                          G28 ;Home
                          G92 E0 ;Reset Extruder
                          G1 Z2.0 F3000 ;Move Z Axis up
                          G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                          G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                          G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                          G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                            jay_s_uk
                            Your jerk is really low. I would multiply that by at least 60. Don't for get it's in mm/min
                            • Vetiundefined
                              Veti
                              @hannes0913 said in Slow printing whit duet2 wifi on ender 3 pro:
                              that is in mm/min
                              500mm/sec is 8.3 mm/sec. that is really slow
                              are you sure that you set the flavor to reprap in cura?
                              • chas2706undefined
                                chas2706
                                @Veti If you are running a recent version of Cura it comes with a pre-configured set of profiles for the Ender 3. I had the same problem. I assume that your speed settings shown above are in the Cura start.g. Go to start.g and comment out M201,M203,M204,M205,M220 and M221. The next print you slice will print at the speeds set up in RRF.
                                • Vetiundefined
                                  Veti
                                  ah those are the CreawsomeMod settings. yes. they need to be removed for the duet.
                                  • chas2706undefined
                                    chas2706
                                    Yes that's correct otherwise the printer is extremely slow.
