    any suggestion for a connector for the printhead?
    3D Printing General Chat
    12
    19
    320
    • matt3o
      matt3o last edited by
      I've built a corexy and I found a cable with 12x0.22mm² + 2x0.75mm² wires (about AWG24 + 18). That would be just enough for 2 fans+thermistor+probe+heater+stepper. I was wondering what could be a nice connector I could use able to handle the 50W heater (and everything else) and possibly that is not bigger than the head itself 🙂
      The best I could think of is a D-SUB DB15 or VGA, looking at some datasheet they claim 5A per contact which is insane 🙂 but maybe you are aware of some better connector.
      thanks!
      Dougal1957 1 Reply Last reply Reply Quote 0
      • Veti
        Veti last edited by
        xt60 for hotend and cat5+rj45 for everything else.
        • Dougal1957
          Dougal1957 @matt3o last edited by
          @matt3o Molex Microfit 3
          • A Former User
            A Former User last edited by
            i found this quite interesting, although I doubt i'll try it https://www.youtube.com/watch?v=I-izkShIDXU
            (XT60 is a nice connector for high current, but its rated for 60A and just ever so slightly overkill for a hotend)
            • Danal
              Danal last edited by
              Use a D-Sub whatever, with pins in parallel for the heater.
              • DaBit
                DaBit last edited by
                Another vote for the D-sub, but the regular 2-row type. Much easier to solder on, more robust pins.
                D-subs are very robust connectors for very little money.
                There is also a smaller XT connector BTW: the XT30.
                • oliverracing
                  oliverracing last edited by
                  Was about to ask a very similar questions but minus the probe, Dsub 15 looks like it'll do the trick very nicely!
                  • Dougal1957
                    Dougal1957 last edited by
                    I would still recommend the Molex Microfit 3.0 series which can be had unto 24 way so more than enough also much lighter than D-Sub connectors.
                    Microfit 3.0 series
                    • gtj0
                      gtj0 last edited by
                      I use the microfits in other places and like them but I also use RJ45 for the hot-end signal and low power stuff and simple spade connectors for the hot-end.
                      • Danal
                        @Dougal1957 said in any suggestion for a connector for the printhead?:
                        I've used these on other things, and they do work very well. Were it me, I'd be comfortable with my own "psuedo-standard" connector for a standard tool, meaning:
                        • Stepper (4)
                        • Sensor/thermistor (2)
                        • Heater (2)
                        • Hot end fan (2)
                        • Part fan (2)
                        • Sensor for tool alignment(2)
                        Total 14, with no allowance for future expansion.
                        From USA supplier Mouser, 16 position are actually slightly cheaper than 14, and I like the expansion possibility:
                        Receptacle Pins
                        Plug Pins
                        With no expansion, and no extra sensor, 10 position will work.
                        • matt3o
                          thanks guys, haven't though about using molex, but it actually makes sense. way easier to handle than dsubs and more flexible!
                          bricor 1 Reply Last reply Reply Quote 0
                          • bricor
                            bricor @matt3o last edited by
                            @matt3o Not sure if this would work for you (see pics).
                            Using extension/adapter cables or adding connectors to a harness adds bulk and creates potential failure points.
                            I found this method to be the best. If anything needs to be changed, its simple. Supports up to 16 terminal points.
                            All that's missing is a printed label plaque
                            matt3o 1 Reply Last reply Reply Quote 1
                            • matt3o
                              matt3o @bricor last edited by
                              @bricor thanks, that is also pretty clever and super easy if you need to change parts
                              • littlehobbyshop
                                littlehobbyshop last edited by
                                Check out this project:
                                https://www.hackster.io/viktorsilivanov/quick-swap-board-for-3d-printer-hotend-fb26e4
                                @matt3o I'd be interested to know where you found that cable.
                                I had some boards made and have populated but not installed yet, they'll be part of a new build.
                                • zapta
                                  zapta last edited by
                                  Just a thought, you can distribute high currents over two wires and/or contacts. This may give you more flexibility. Also, Some wires can be merged, e.g. the +24V for heater and fans.
                                  (Duet people mentioned in the past a possibility for smart head board that just need power and CANBUS data, this would make requirements like yours easier to solve).
                                  • matt3o
                                    matt3o last edited by matt3o
                                    @littlehobbyshop that is very close that what I was planning to do, with less fancy PCB and more DIY 🙂 The cable is from a local supplier but I believe they can be easily found. They are sold as "security/alarm cables" they come in many variants.
                                    @zapta at the moment I'm only sharing the positive leads of the fans, that's all I need but I'll check what else I could share. thanks!
                                    • Danal
                                      So I decide to go the Molex Microfit way on a toolchanger. Purchased Molex 16 pin, m/f, pins, etc. Pleasantly enough, they were smaller than I'd thought.
                                      This is working out well, the connectors are great... but... do be aware it is labor intensive. Every wire going to a tool now requires three crimps. One for the Duet board, one for the male molex, and one for the female molex. I haven't even gotten one tool completely setup!
                                      Not saying anyone should/shouldn't... just be aware.
                                      matt3o 1 Reply Last reply Reply Quote 0
                                      • matt3o
                                        matt3o @Danal last edited by
                                        @Danal they are indeed smaller than I thought!
                                        I got used to crimping, that wouldn't be a big issue. Still not sure if I want to go with a more polished solution (like the one posted by @littlehobbyshop ).
                                        I've also found connectors with dedicated pins for power, but let's not go overboard 🙂
                                        thanks for your report btw!
                                        • avion23
                                          avion23 last edited by
                                          I'm using Wago 221 for everything.
                                          This relieves me from soldering and I can throw out the old fans without working.
