D-PATCH
Hey guys,
after countless hours and multiple iterations, I would like to present to you the D-PATCH (Delta Printer with automatic tool changing). To my knowledge there is no Delta Printer available with tool-changing. I have been working on it for over 2 years (started in March 2018) and I am proud, that it is now a reality.
As you can see it’s not completely finished yet, because the actual tool changer is missing, but is in the making. A prototype is existing already.
Stats about the Printer:
Print volume: 300x300mm
Available tools: 5 (for now)
Board: Duet 2 Wifi + Duex 5
Power Supply: 24V 13A Meanwell
Security: Circuit breaker + RCD +Emergency Stop
Bed: milled aluminium bed with 600W mains heater switched with SSR
Print surface: Magnetic bed
Tool-Changing: Automatic and Manual
Control: PanelDue
I will updated the tread when I make more progress.
I'm really curious about your opinions and please let me know if you have any questions.
Adrian
Added a cover for the electronics compartment and fixed the bed. The bed sits on 1 Standoff and 2 Balls, so that the system is constraint but thermal expansion is allowed.
@taconite Nice work! I have no experience with Deltas but I'm definitely interested in how the tool changer works out.
FANTASTIC. I was thinking about going down this road...
You've posted a lot of info and pics, and I will be looking at them very carefully, meanwhile TELL US MORE!!!
This is incredible. Fantastic. Superlative. Nifty. I'm running out of words (at least without cheating on the web) and I hope I've conveyed just how cool this is.
Bravo!
Now, to look at your pics!!
Would you be willing to post the tool macros?
Hey Guys,
I uploaded some videos of the first prints here.
Furthermore I added a video of a manual tool change
https://www.youtube.com/user/Taconiteable/videosBest Regards
Adrian -
That's really cool, I missed your original post! The first tool changing delta I am aware of is from 2013 (see https://www.youtube.com/watch?v=f60YuBrHRCA -- it's actually a pancake printer as shown in https://www.youtube.com/watch?v=t3O19n_JqXU).
We've come a long way in the mean time! Can you give some details on your locking mechanism? It seems way more involved than a bunch of magnets.
@oliof Yeah you are right - I found these videos, too, when I started to look into tool changing Delta printers, but not many infos out there.
About your question - yeah a little more brain juice went into the design of the locking mechanism.
So it is basically a bayonet lock that is driven by a Bowden cable and reset by a bunch of springsThe pieces of the bayonet that lock the tool are angled so a downward force is created by the rotation of the bayonet. It is locking onto 3 zylindrical pins that are placed 120° apart from each other so that the locking is uniformly
Pretty cool! I hope you publish your design one day as this would be an interesting setup for three printers down my ideas to build (orthogonal tripteron, or sextupteron). But that's a couple years out optimistically speaking (-:
Thanks that you like it! Yeah as soon as this version will be finished I'm thinking about publish the files under CC-BY-NC so that the community can use it
BTW: I really love your unconventional tripteron design!
The design is not mine though. That credit goes to Evan Callicoat.
Started working on the Tool-Changer itself
Hey guys,
worked a little bit more on the printer.
I got the first automatic tool change (even if it needs a little more tuning), but it's a first step in the "proof of concept" direction (which I already did with the first prototyp). -
@taconite that's a cool design. Where did you get the tapered metal parts?
@fšk thank you
I designed the tool so, that it utalizes standard stock material. The tapered part was done by a friend of mine on a standard lathe. -
Tool Change Scripts
Tool Changing of two tools can be seen here:
https://youtu.be/nLvNUum48fgupcoming is the first multi-material print
@taconite that's a nice tool changer!
@taconite Hey any thoughts about preventing heat-creep after a (hot) tool is placed back on the carousel?
@JoergS5 Thank you
@jpomo10 of course ;). There are multiple options:-
set the stand-by temperature so low, that a equilibrium is reached
(+ no additional fans, - long heat up time) -
one fan for each tool in parking position
(+ sufficient cooling, - lot of fans with lots of noise) -
one bigger fan with a fan-duct to direct the air to the heat sinks of the tools in parking position
For now I have no fans at all. So after the first prints I had not a lot of heat creep and no problems with jams. But I guess I will move on with option 3
BTW: I posted another video of the first dual color print on youtube
this looks like a sci fi attack hovercraft
@taconite Thanks for the reply!
Is the tool-changer "carriage" set up as an additional axis? How does it increment along with the Z-axis?
@jpomo10
Yep it is set up as U axis. I wrote a custom post-processing script for cura -
Hey guys,
I keep posting small videos - some are not really special but I still want to share them with you: https://youtu.be/6-CR_1vN3cE
In this small video I print with my go-to 100mm/s-profile
And I just uploaded a video of the change of 4 tools
https://youtu.be/aJt_HRal5rY
