    Is my extruder set up properly?
    anet a8 extruder 0.9 stepper retraction voids
    623
    • gibbethundefined
      gibbeth
      Hi all,
      I'm getting intermittent voids in my horizontal layers, around 2-3 mm long and occasional popping sounds from the extruder. Could it be my extruder setup? I plugged in my numbers to dc42's "choosing a stepper" formulas when i set up everything and i think it's okay but I'm not sure. I thought maybe it was the PLA filament so i dried it for 24 hours in a dehydrator but it didn't help. I've also tried varying the hotend temperature from 200-225.
      My printer is a duet 2 wifi, 24v AM8 with 0.9 degree steppers.
      Thank you for reading this.
      Here's my config.g
      Firmware Name:		RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:	Duet WiFi 1.02 or later
      Firmware Version:	2.01(RTOS) (2018-07-26b2)
      WiFi Server Version:	1.21
      Web Interface Version:	1.21.2-dc42
      Extruder stepper part number: 17HM15-0904S
      stepper spec sheet.pdf
      PullOutTorque.pdf
      benchy pic
      alternate link to benchy pic
      Here are my Cura settings:
      cura settings
      Alternate link to cura settings
        Phaedrux Moderator @gibbeth
        @gibbeth said in Is my extruder set up properly?:
        What is your extruder setup? Bowden? Direct? 6.5mm retraction could be too much, or maybe it's not enough? We don't have enough information to say.
        gibbethundefined 1 Reply Last reply Reply Quote 1
          jay_s_uk
          Popping is usually a sign of wet filament.
          Maybe think about trying some other filament if you have some?
          Other than that, its generally a good looking benchy
          fxsteinundefined 1 Reply Last reply Reply Quote 1
          • fxsteinundefined
            fxstein @jay_s_uk
            @jay_s_uk said in Is my extruder set up properly?:
            Agreed.
            Popping sounds are little steam explosions that rip the layer apart. They can be cause by
            • wet filament - try drying it before using it or use an inline dryer for your prints
            • too much retraction - I found that when retracting too much I get ambient air pulled into the nozzle, that will produce the same effect a few millimeters after the start of a new line.
            Good looking benchy indeed
            • gibbethundefined
              gibbeth @Phaedrux
              It's direct.
              I changed to 1mm retraction and that seems to have solved it. Thanks for your help!
              Thank you 😊
              • fxsteinundefined
                fxstein
                Glad it worked.
                I found there is a pretty universal rule of thumb for retractions:
                0.5-2.5 mm + 1% of bowden tube length
                For direct drive there is no bowden part so you are just left with 0.5-2.5mm (found that even at 2.5 mm you can see popping)
                For bowden drive on e.g. 500mm bowden tube you end up with 0.5-2.5mm + 5mm -> often in the 6.5mm range
                Also found that its true for wether you run a V6 style hotend or a Volcano. Despite some online suggestions that a Volcano should have longer retractions because of its longer meltzone. Above 2mm even Volcanos will start popping because in the end its not about the top of the melting zone, but the bottom of the nozzle.
                Once you pull up the filament past 1-2mm you get air into the melting chamber, that violently overheats once re-primed.
                oliofundefined 1 Reply Last reply Reply Quote 1
                • oliofundefined
                  oliof @fxstein
                  @fxstein somewhat offtopic nit-pick, but "direct drive" and "direct" are two different things. "Direct drive" usually means an ungeared extruder (while I am nit-picking, I'll nitpick on myself and mention that this should be "filament feeder", with the opposite being geared extruder (like Bondtech or Hemera). The "direct" versus "Bowden" (no drive) are really "short distance" vs "long distance" (between filament feeder and hotend).
                  fxsteinundefined 1 Reply Last reply Reply Quote 2
                  • fxsteinundefined
                    fxstein @oliof
                    @oliof said in Is my extruder set up properly?:
                    I know exactly what you mean. We - no I am are butchering a bunch of terms. Guilty as charged. Having said so, the vast majority will understand the meaning of it - might even be less confused than when we speak more precisely.
