    BL-Touch - multiple problems -
    Firmware installation
    2.4k
    • duttiundefined
      dutti @JoergS5
      @JoergS5
      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
      I wired like this....
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @dutti
        @barbarossa-cologne my experience is that the colors are sometimes wrong, better check the positions on the 5-pin-connector to be sure. I saw an image in the internet of the antclabs where black and white were exchanged. And the Creality ones cross a cable for the 3 pin connector.
        duttiundefined 1 Reply Last reply Reply Quote 0
        • duttiundefined
          dutti @JoergS5
          @JoergS5
          Without seeing the picture I thougth the same. I´ll try it on sunday.
          Thanks for your help!!
            At this point I think you should try swapping from io7 to io4 or io5 just to try a different connection. Update the config as needed to point to the new connection.
            And if that still doesn't work I would try connecting the BLTouch directly to the board with the short leads straight from the BTouch without the extension.
            If that still doesn't work I would get another BLtouch to test with.
            • duttiundefined
              dutti @Phaedrux
              @Phaedrux
              Ok. I'll do it on Sunday!
              I have a cheap Chinese BL fake at home. Should I take this BL at last try?
              Is there any other sensor you can recommend if it's not working?
              The duet one?
                The BLtouch is a good probe when it's working. It's surface agnostic and a contact probe and it's quite accurate and repeatable when configured correctly. It's the most popular option for a reason.
                The IR Probe is also very good, but your print surface must be compatible with the IR sensor.
                • duttiundefined
                  dutti
                  @Phaedrux
                  ok. Then I´ll do everything to become the BL to work.
                  • duttiundefined
                    dutti
                    @JoergS5
                    Changing the cable order wasn´t helpful.
                    There is also the problem that the duet homes the z axis. Also when the BL isn´t connected.
                    @Phaedrux
                    • duttiundefined
                      dutti
                      M558 P9 C"^io7.in" H15 F120 T1400 ;set Z probe type to bltouch and the dive height + speeds
                      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                      G31 P500 X20 Y100 Z4 ; set Z probe trigger value, offset and trigger height
                      M557 X15:650 Y15:650 S60 ; define mesh grid
                      • JoergS5undefined
                        JoergS5 @dutti
                        @barbarossa-cologne from documentation, setting lower P for G31 seems better:
                        G31 P25 X20 Y100 Z4
                        and
                        M558 P9 C"io7.in" H15 F120 T1400
                        without the ^, because Duet 3 IO ports all have pullups already.
                        https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Duet_3_endstop_inputs each IO of Duet 3 has already pullup resistors: "Endstop devices can be connected to the IO_0 through IO_9 connectors. Each endstop input has a 27K pullup resistor, so the endstop devices only need to sink 0.12mA."
                        You wrote above, that removing ^ didn't work, but how did you mention, maybe it was the wrong P of G31 or some other cause.
                        • duttiundefined
                          dutti
                          @JoergS5
                          ITS WORKING!!!!!!
                          I connected the BL to IO4.
                          I think the IO7 connector isn´t working.
                          Refund Duet??? 🙂
                          I´m not sure about the ´´^ ´´. Let it like this and its working now.
                          • JoergS5undefined
                            JoergS5 @dutti
                            @barbarossa-cologne I am glad to hear that!!
                            • duttiundefined
                              dutti @JoergS5
                              @JoergS5
                              And NO. I´m a Idiot. the ´´^ `` must be deleted. Thanks Jörg and @Phaedrux
                                dc42 administrators @dutti
                                @barbarossa-cologne said in BL-Touch - multiple problems -:
                                @Phaedrux said in BL-Touch - multiple problems -:
                                M98 Pconfig.g
                                ´´´Response to long, see console´´.
                                So switch to the Console page of DWC to see the messages.
                                I havent connected the expansion board, yet. Is this a problem?
                                You will get some error messages from running config.g if it refers to ports on an expansion board that isn't connected.
                                  Phaedrux Moderator @dutti
                                  @JoergS5
                                  So you're able to use io7 when removing the ^?
                                  • duttiundefined
                                    dutti @dc42
                                    ok. problem solved.
                                    thanks
                                    • duttiundefined
                                      dutti @Phaedrux
                                      @Phaedrux
                                      no IO7 is dead. with or without. no retract or deploy
                                      • JoergS5undefined
                                        JoergS5 @dutti
                                        @Phaedrux
                                        I would make an image from the soldered side of io7 and publish so it can be valued whether it may be a soldering problem.
                                        duttiundefined 1 Reply Last reply Reply Quote 1
                                        • duttiundefined
                                          dutti @JoergS5
                                          @JoergS5
                                          ok. I´ll do it!
                                            In addition to the photos can you also provide the following:
                                            The output of M122
                                            The output of M98 P"config.g"
                                            Your current config.g
                                            Also please do this test and report the results:
                                            Send M950 J5 C"io7.in", then read the state of the pin by sending: echo sensors.gpIn[5]
                                            Do this both with and without a jumper shorting io7.in to ground.
                                            Result should be 0 with the jumper, 1 without
