    Tips to mitigate vertical artifacting Duet 2 Wifi
    91
    8.1k
    • lord binkyundefined
      lord binky
      I got fed up with something retraction related in Simply3d. So I did some test prints in Kisslicer and Cura (cura definitely has some odd quirks when it comes retraction though...) and the diagonal cross hatch lines that plagued me are smooth as silk in the Cura prints. So I just wanted to put the reminder to rule out slicer quirks occasionally when hunting this down.
      • brotherchrisundefined
        brotherchris @sebkritikel
        @sebkritikel I now have a Bondtech BMG and mosquito installed. The artifacts appear to be the same, but I will run another pyramid to see if there are any changes.
        Phaedruxundefined sebkritikelundefined 2 Replies Last reply Reply Quote 0
          Phaedrux Moderator @brotherchris
          @brotherchris said in Tips to mitigate vertical artifacting Duet 2 Wifi:
          Same stepper?
          brotherchrisundefined 1 Reply Last reply Reply Quote 2
          • sebkritikelundefined
            sebkritikel @brotherchris
            Thats a bummer to hear. Is it the same stepper motor on the extruder? beat me to it!
            Some other testing steps... the goal of course is to not waste filament, but sometimes we need to 🙂
            1. If you do the same print (same exact GCODE file) multiple times in a row - print, remove, restart, repeat - are the patterns in the exact same spot(s), or does it vary print to print?
            2. Can you do a medium-small box - 40mm x 40mm x 40mm perhaps? Both with infill, and another print with only one or two walls? If it happens to both (I know you said it does previously) can you take more images, measure the horizontal distance (period), and try and measure the slope of the artifact, and upload the GCODE file?
            Large(ish?) IDEX - 6HC, 1HCL
            Stratasys Dimension 1200es to 6HC Conversion
            Vetiundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti @sebkritikel
              @sebkritikel said in Tips to mitigate vertical artifacting Duet 2 Wifi:
              i think filament is the least of his problem
              it will make for an interesting video to watch in the end.
              how many times have you disassembled and reassembled the belt with its idlers by now?
                brotherchris @Phaedrux
                @Phaedrux Different stepper. I might try the other E driver though.
                • Vetiundefined
                  Veti @brotherchris
                  @brotherchris
                  i know you want to reveal your project once its ready, but a picture of the belt and its path might help to think of more things that could be causing this.
                  brotherchrisundefined 1 Reply Last reply Reply Quote 1
                    brotherchris @Veti
                    @Veti No worries on that. It's kind of a mess at the moment, but here are some shots of the stuff that matters.
                    20201014_145549.jpg 20201014_145554.jpg 20201014_145601.jpg 20201014_145618.jpg
                    brotherchrisundefined 1 Reply Last reply Reply Quote 0
                      brotherchris @brotherchris
                      @brotherchris 20201014_145454.jpg 20201014_145504.jpg 20201014_145511.jpg 20201014_145516.jpg 20201014_145539.jpg
                        lord binky
                        Looking at the long spans on the belts remind me of another issue I had (I run a delta though). The constant tension on the motors eventually affected the bearings in the motors. I eventually replaced the motors, but I also added in thrust bearings* between the pulley and the motor, so any lateral pull on the motor shaft is limited by the pulley pushing down on the thrust bearing against the motor. Granted the motors were also like 7 years old so they did good. Still, I'd at least consider these since they are easy to replace, inexpensive, and they worked great for me removing a visible deflection in the motor shaft when the belts were tightened. Tuning after that I tuned for better jerk and accel, but that could have been the motor model changing. Still, these did have noticeable improvement on the hash pattern for the old motors before I replaced them, but the artifacts were not fully resolved until I changed slicers. I had to format my computer recently and didn't deem those pictures as worthy of backup....heh.. and it's kind of hard to describe how it changed to a kind of fainter or less pronounced but crisper or finer lines at the same time.
                        *- https://www.amazon.com/gp/product/B07QKKYKR8/
                        • Vetiundefined
                          Veti
                          taking the last picture as a reference.
                          the belt at the top motor is angled and goes from the bottom path to the top path. that could be the cause of those artefacts. the belt would be constantly pushed upwards on the pulley.
                          looking at the bottom motor. here the belts are not parallel. this will cause dimensional inaccuracies. the belt path creates a triangle where the belt moved is longer than the axis movement it causes.
                          That part of the belt path and the one on the x axis has to be parallel to the extrusions.
                          brotherchrisundefined 2 Replies Last reply Reply Quote 2
                            brotherchris @Veti
                            @Veti I will take another look, I might have to make some modifications. I don't know if the setup I have now will let me get any closer.
                            • Vetiundefined
                              Veti @brotherchris
                              @brotherchris
                              This is to illustrate why the inner belts need to be parallel.
                              Assume C is the belt with a length of 11cm (high numbers to make the point)
                              A is the length of the y axis that it can move and is 10cm
                              You are printing a straight Line in Y direction with a length of 11cm.
                              The Motors pull 11cm of the belt, but the y axis only moves 10cm. causing the line to be printed to have a length of 10cm.
                              Even worse. if you dont have the same triangle on the other side of the y, you now have 1cm extra belt in your belt path. this reduces the belt tension.
                                I would be surprised if the exoslide printer design had such a common corexy flaw.
                                  brotherchris @Veti
                                  @Veti Check this out, top pic, Gates belts. Bottom pic cheap Amazon belt. My only guess if the cheap belt teeth are more forgiving. 20201017_165848.jpg 20201017_165902.jpg
                                  • Vetiundefined
                                    Veti
                                    that is indeed an interesting result. i guess time to wait for the toothed idlers to arrive.
                                    the belts from your pictures do not look like gates belts though.
                                      brotherchris @Veti
                                      @Veti They are gates high temp belts. That could be the issue. Maybe these are stiffer then regular belts. https://www.printedsolid.com/products/gates-powergrip-2gt-high-temp-belt-1m
                                      matt3oundefined 1 Reply Last reply Reply Quote 0
                                      • matt3oundefined
                                        matt3o @brotherchris
                                        @brotherchris not to be the party pooper but I have standard 2GT with toothed idlers and I get the same issue as yours (or at least the end result is very close).
                                        I ended up re-engineering the whole thing, now waiting for a few more piece to arrive to see if it actually worked.
                                          brotherchris @matt3o
                                          @matt3o No, great to hear, I am too working to find ways to improve.
