    Duex5 not showing up in "Machine-Specific"
    449
    • jontek2undefined
      jontek2
      Hey!
      I've just noticed that my Duex5 is no longer showing up under Settings -> Machine-Specifics and "Electronics".
      It's lists:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23
      And if i run "Diagnostic" it recognises the duex;
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
      Can anybody with a Duet2Wifi + Duex and Duet Web Control 3.1.1 check their?
      • jontek2undefined
        jontek2
        Oh yeah, i forgot to mention that the board works just fine. I've got two fans, one motor and a bltouch connected to it.
          I think the machine specific tab has lost some functionality in RRF3 that is intended to be added back with more info from the object model.
          • jontek2undefined
            jontek2
            Puh, that's nice to hear. I thought i've got an issue.
            It would be great if anybody with a duet2wifi and a duex running the latest firmware and DWC could confirm this.
            sebkritikelundefined 1 Reply Last reply Reply Quote 0
            • sebkritikelundefined
              sebkritikel @jontek2
              @jontek2 said in Duex5 not showing up in "Machine-Specific":
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2-beta3.2 running on Duet WiFi 1.02 or later + DueX5
              No issues to speak of with my machine. I think you'll be good to go!
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
              jontek2undefined 1 Reply Last reply Reply Quote 0
                I think the difference is that DWC 3.2 gets the electronics info from the object model, and that doesn't include the DueX. I'll look at adding the DueX information.
                RodrigoRMaraujoundefined 1 Reply Last reply Reply Quote 0
                • jontek2undefined
                  jontek2 @sebkritikel
                  @sebkritikel Big thanks!
                  @dc42 Awesome!
                  Happy new year 🙂
                  • RodrigoRMaraujoundefined
                    RodrigoRMaraujo @dc42
                    Hello @dc42 .
                    Could you tell if this documentation is already available?
                    I'm having difficulties to map the duex5 pins, to use them with M950.
                    Thanks.
                      Phaedrux Moderator @RodrigoRMaraujo
                      @rodrigormaraujo Which pins are you trying to use?
                      https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                        RodrigoRMaraujo @Phaedrux
                        @phaedrux
                        I'm still learning about pins and I'm still not sure which ones I can use. For now I'm using the 2 to 6 duex endstop pins for extruders. I wish I could use some more, to put physical buttons and trigger macros. They can be in the duet or in the duex.
                        Thanks for replying with the link, I haven't seen this list yet.
                          @rodrigormaraujo said in Duex5 not showing up in "Machine-Specific":
                          @phaedrux
                          Probably best to start a new thread with the details of what you want to do.
                            @phaedrux Yes thanks. I had already done that.
                            https://forum.duet3d.com/topic/24878/physical-buttons-to-run-macros-using-duex5-with-rrf3-3
