stepper precision
@alankilian said in stepper precision:
Try your open-loop vs. closed-loop experiment and hold the rotor with something for 10 steps and see how the closed-loop corrects for that once you remove the load and the open loop mode does not correct the error.
it does correct the missed steps, but it should be also more precise than what I'm seeing ... 1° error !?!? that's more than half a step
Anyhow done with S42B, moving on to TMC2208 driver and different motors
Would also be cool if someone can reproduce measurements with S42B as this does not require super good/expensive/high resolution encoder, even cheap 1000 lines encoder should be able to see error 0.5° and 1°
@arhi said in stepper precision:
Have you done any testing of the "two piece" closed loop systems consisting of a stepper/encoder and separate control unit?
Thanks.
@fcwilt said in stepper precision:
Haven't got to it yet, can't find where I put my vallder stepper with encoder and driver combo. Also I wanna finish with few nema17 before I have to use another mount to test the bigger motor
second super whooper
third super whapper motor
So, basically, at 180 steps or so the actual vs demanded position deviation of the last motor is more than half a step with the others close to that, with zero load?
That is way worse than what I would have expected...
That's funny.
A while back I purchased such a system for testing but the project got put on hold as other more important things needed to be done.
And now I cannot find it.
@DaBit said in stepper precision:
will have to spend more time looking at all this data, so far I'm running the tests and just showing the error of going forward than backwards. The other data I'm interested is spread of steps going in one direction only, how much off each step is from ideal position but I will do those graphs after I finish all the tests as I need to return this encoder in few days
so you understand my frustration
I'm not used to everything being "in order" and everything "having it's place" but I hate working from "storage", can't find anything, $@^%#^ is getting on my nerves and breaks my concentration too .. and I don't see the end, I doubt my house will be ready before summer -
second DPM motor
I found the box with the stepper/encoder and controller!
Now I just need to find the time - still looking for that.
@arhi Are you sure you're calibrating the controller every time?
It looks like going forward, you get 0.5-degree of error, but going backwards, you get MUCH LESS error. Under 0.1 degree
Maybe try going three turns forward and then three turns backwards just in case it take one-turn to calibrate or something.
For S42B - yes, I am sure, I calibrated every time when running closed loop. I don't see a point as nothing physically changed in the setup between runs but I still run the calibration every time before I run the test as calibration is rather quick (it goes full circle one direction and then full circle other direction) ... anyhow notice these lasts graphs are with TMC2208, nothing to calibrate there
same motor as earlier only run again to see how "repeatable" this is (not very)
JK42HS48-1684-01
