    3D Printer Connectors - What's best for in-line connections?
    3D Printing General Chat
    14
    29
    4.0k
    • PaulHewundefined
      PaulHew @o_lampe
      @o_lampe All my printers use Microfit 3.
      In the UK I can get them from CPC, Farnell and if I have a big enough order Mouser.
      I use DuPont for things like accelerator where it is not a permanent fixture.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
      • DIY-O-Sphereundefined
        DIY-O-Sphere @o_lampe
        @o_lampe
        Reichelt....
        (UTC+1)
        • zaptaundefined
          zapta @o_lampe
          @o_lampe said in 3D Printer Connectors - What's best for in-line connections?:
          ... supercontainership blocking Suez-channel forever
          Now it's the canal that blocks the ship 😉 https://www.youtube.com/watch?v=FESrIXpsQJc
          There is a general shortage of electronic components to a point that car manufacturer dropped features or stopped production because they can't get the chips they need.
          https://www.youtube.com/results?search_query=car+chip+shortage
          Did it affected Duet3D in any way?
            dc42 administrators @o_lampe
            @jens55
            dc42 also suggested to use the MicroFit 3.0, but I couldn't find a reseller (accepting paypal) with all the required parts in Stock. I guess, the German/EU components-market is empty, due to the well known issues. (and the supercontainership blocking Suez-channel forever)
            There appear to be plenty on eBay. https://www.ebay.de/sch/i.html?_nkw=molex+microfit
            • o_lampeundefined
              o_lampe @dc42
              That's where I was looking. The problem was the crimp connectors for both housings. I'd have had to buy from here and there to scratch everything together.
              • CNCModellerundefined
                CNCModeller
                Hi All,
                I've been thinking about these for allowing me to make my printer more modular. A single connection to the radial axis that holds both the radial and extruder motors and all of the hot end connections. That way I could remove it for transportation, assuming I created locating features for easy realignment.
                I use an SSR for the hotend heater cartridge so power could be run separately if the connector isn't up to it, although the listing does suggest high power capacity but i haven't found a comprehensive data sheet yet.
                https://cpc.farnell.com/c/cable-leads-connectors/connectors/circular-multipole-connectors/industrial-circular-connectors?brand=amp-te-connectivity
                Any thoughts?
                Cheers
                Barry M
                Polar Duet3 Mini + 1HCL
                https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                Wanhao D4S: Duet2
                https://forum.duet3d.com/post/296755
                K40 Laser, Duet2
                https://forum.duet3d.com/post/312082
                Wanhao D5S
                https://www.youtube.com/CNCModellerUK
                • o_lampeundefined
                  o_lampe @CNCModeller
                  @cncmodeller
                  Those AMP connectors are huge compared to MicroFit. Doesn't matter, if they don't sit in the cable-chain.
                  CNCModellerundefined 1 Reply Last reply Reply Quote 0
                    Have you tried https://de.farnell.com/search?st=molex microfit ?
                      CNCModeller @o_lampe
                      @o_lampe yeah they were intended as a single bulkhead connection mounted on the structure of my radial axis assembly.
                      Wanhao D4S: Duet2
                      K40 Laser, Duet2
                      Wanhao D5S
