    3D Printer Connectors - What's best for in-line connections?
    3D Printing General Chat
    14
    29
    4.1k
    • sebkritikelundefined
      sebkritikel
      And if you don't want to crimp...
      https://www.amphenol-industrial.com/images/catalogs/PT.pdf
      https://www.peigenesis.com/en/shop/part-information/PT01E84PSR/APH/EACH/69387.html#mates
      https://www.peigenesis.com/en/shop/part-information/PT06A84SSR/APH/EACH/72221.html
      Could get worse!
      Large(ish?) IDEX - 6HC, 1HCL
      Stratasys Dimension 1200es to 6HC Conversion
      • jens55undefined
        jens55
        I know this is an old topic but I have a relevant update:
        I started with Dupont style connections for the hot end heater for my 12V based printer. That caused all kinds of grief fairly quickly due to overheating of the connector (40W heater). I then went to a JST style interlocking connector. That worked for a while but is again causing failures due to overheating of the connector.
        Up to now, these connectors where sourced from China .... and are costing me way more in frustration and spoiled prints than they are worth.
        My next and hopefully final connector style will be a genuine Molex Microfit 3.0 connection system sourced from Digikey. I just had a print abort after about 4 hours of printing and it just isn't worth the pain and suffering any more.
        Even at ten times the price of the China product, it's worth it if it fixes this mess!
        • o_lampeundefined
          o_lampe @jens55
          @jens55
          dc42 also suggested to use the MicroFit 3.0, but I couldn't find a reseller (accepting paypal) with all the required parts in Stock. I guess, the German/EU components-market is empty, due to the well known issues. (and the supercontainership blocking Suez-channel forever)
          PaulHewundefined DIY-O-Sphereundefined zaptaundefined dc42undefined 4 Replies Last reply Reply Quote 0
          • PaulHewundefined
            PaulHew @o_lampe
            @o_lampe All my printers use Microfit 3.
            In the UK I can get them from CPC, Farnell and if I have a big enough order Mouser.
            I use DuPont for things like accelerator where it is not a permanent fixture.
            • DIY-O-Sphereundefined
              DIY-O-Sphere @o_lampe
              @o_lampe
              Reichelt....
              (UTC+1)
              • zaptaundefined
                zapta @o_lampe
                @o_lampe said in 3D Printer Connectors - What's best for in-line connections?:
                ... supercontainership blocking Suez-channel forever
                Now it's the canal that blocks the ship 😉 https://www.youtube.com/watch?v=FESrIXpsQJc
                There is a general shortage of electronic components to a point that car manufacturer dropped features or stopped production because they can't get the chips they need.
                https://www.youtube.com/results?search_query=car+chip+shortage
                Did it affected Duet3D in any way?
                  dc42 administrators @o_lampe
                  @jens55
                  There appear to be plenty on eBay. https://www.ebay.de/sch/i.html?_nkw=molex+microfit
                  • o_lampeundefined
                    o_lampe @dc42
                    That's where I was looking. The problem was the crimp connectors for both housings. I'd have had to buy from here and there to scratch everything together.
                    • CNCModellerundefined
                      CNCModeller
                      Hi All,
                      I've been thinking about these for allowing me to make my printer more modular. A single connection to the radial axis that holds both the radial and extruder motors and all of the hot end connections. That way I could remove it for transportation, assuming I created locating features for easy realignment.
                      I use an SSR for the hotend heater cartridge so power could be run separately if the connector isn't up to it, although the listing does suggest high power capacity but i haven't found a comprehensive data sheet yet.
                      https://cpc.farnell.com/c/cable-leads-connectors/connectors/circular-multipole-connectors/industrial-circular-connectors?brand=amp-te-connectivity
                      Any thoughts?
                      Cheers
                      Barry M
                      Polar Duet3 Mini + 1HCL
                      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                      Wanhao D4S: Duet2
                      https://forum.duet3d.com/post/296755
                      K40 Laser, Duet2
                      https://forum.duet3d.com/post/312082
                      Wanhao D5S
                      https://www.youtube.com/CNCModellerUK
                      • o_lampeundefined
                        o_lampe @CNCModeller
                        @cncmodeller
                        Those AMP connectors are huge compared to MicroFit. Doesn't matter, if they don't sit in the cable-chain.
                        CNCModellerundefined 1 Reply Last reply Reply Quote 0
                          Have you tried https://de.farnell.com/search?st=molex microfit ?
                            CNCModeller @o_lampe
                            @o_lampe yeah they were intended as a single bulkhead connection mounted on the structure of my radial axis assembly.
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
