    3D Printer Connectors - What's best for in-line connections?
    3D Printing General Chat
    14
    29
    4.1k
    • jens55undefined
      jens55
      Crimp connections are more reliable if done correctly. If you can't do them right then soldering is likely better for you.
      • hackinistratorundefined
        hackinistrator
        properly crimped connectors are better then soldered , specially on high speed moving parts like 3d printer .
        i use molex and AMP connectors . for high current heaters (no longer use them , moved to mains powered) i used RC soldered connectors like XT60 and XT30 .
        • taconiteundefined
          taconite
          I personally hate dupont but e.g. for stepper wires its super conveniant because you can change direction.
          On heaters I use Molex Micro fit or Mini fit Jr.
          Custom ANET A8
          Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
          All I do here is under this license: CC BY-NC-SA
          • Vetiundefined
            Veti @taconite
            i use Molex Micro fit for heaters as well.
            for other i use jst locking ones
            https://www.aliexpress.com/item/32856368582.html?spm=a2g0s.9042311.0.0.27424c4dyysxU1
            • zaptaundefined
              zapta @hackinistrator
              @hackinistrator said in 3D Printer Connectors - What's best for in-line connections?:
              I got recently this version of XT60 with the black covers and like it more than the older shrink tube version.
              Other interesting high current connector are Anderson Powerpole https://en.wikipedia.org/wiki/Anderson_Powerpole which are modular and genderless.
              Apropos connectors, WhamBam came recently with an interesting 3D printer gantry connector system https://whambamsystems.com/mutant
              theruttmeisterundefined 1 Reply Last reply Reply Quote 0
              • theruttmeisterundefined
                theruttmeister @zapta
                @zapta said in [3D Printer Connectors - What's best for in-line connections?](/post
                Shame they can't design a belt drive correctly... 😬
                Isolate, substitute, verify.
                • sebkritikelundefined
                  sebkritikel
                  And if you don't want to crimp...
                  https://www.amphenol-industrial.com/images/catalogs/PT.pdf
                  https://www.peigenesis.com/en/shop/part-information/PT01E84PSR/APH/EACH/69387.html#mates
                  https://www.peigenesis.com/en/shop/part-information/PT06A84SSR/APH/EACH/72221.html
                  Could get worse!
                  Large(ish?) IDEX - 6HC, 1HCL
                  Stratasys Dimension 1200es to 6HC Conversion
                  • jens55undefined
                    jens55
                    I know this is an old topic but I have a relevant update:
                    I started with Dupont style connections for the hot end heater for my 12V based printer. That caused all kinds of grief fairly quickly due to overheating of the connector (40W heater). I then went to a JST style interlocking connector. That worked for a while but is again causing failures due to overheating of the connector.
                    Up to now, these connectors where sourced from China .... and are costing me way more in frustration and spoiled prints than they are worth.
                    My next and hopefully final connector style will be a genuine Molex Microfit 3.0 connection system sourced from Digikey. I just had a print abort after about 4 hours of printing and it just isn't worth the pain and suffering any more.
                    Even at ten times the price of the China product, it's worth it if it fixes this mess!
                    • o_lampeundefined
                      o_lampe @jens55
                      @jens55
                      dc42 also suggested to use the MicroFit 3.0, but I couldn't find a reseller (accepting paypal) with all the required parts in Stock. I guess, the German/EU components-market is empty, due to the well known issues. (and the supercontainership blocking Suez-channel forever)
                      PaulHewundefined DIY-O-Sphereundefined zaptaundefined dc42undefined 4 Replies Last reply Reply Quote 0
                      • PaulHewundefined
                        PaulHew @o_lampe
                        @o_lampe All my printers use Microfit 3.
                        In the UK I can get them from CPC, Farnell and if I have a big enough order Mouser.
                        I use DuPont for things like accelerator where it is not a permanent fixture.
                        • DIY-O-Sphereundefined
                          DIY-O-Sphere @o_lampe
                          @o_lampe
                          Reichelt....
                          (UTC+1)
                          • zaptaundefined
                            zapta @o_lampe
                            @o_lampe said in 3D Printer Connectors - What's best for in-line connections?:
                            ... supercontainership blocking Suez-channel forever
                            Now it's the canal that blocks the ship 😉 https://www.youtube.com/watch?v=FESrIXpsQJc
                            There is a general shortage of electronic components to a point that car manufacturer dropped features or stopped production because they can't get the chips they need.
                            https://www.youtube.com/results?search_query=car+chip+shortage
                            Did it affected Duet3D in any way?
                              dc42 administrators @o_lampe
                              @jens55
                              There appear to be plenty on eBay. https://www.ebay.de/sch/i.html?_nkw=molex+microfit
                              • o_lampeundefined
                                o_lampe @dc42
                                That's where I was looking. The problem was the crimp connectors for both housings. I'd have had to buy from here and there to scratch everything together.
                                • CNCModellerundefined
                                  CNCModeller
                                  Hi All,
                                  I've been thinking about these for allowing me to make my printer more modular. A single connection to the radial axis that holds both the radial and extruder motors and all of the hot end connections. That way I could remove it for transportation, assuming I created locating features for easy realignment.
                                  I use an SSR for the hotend heater cartridge so power could be run separately if the connector isn't up to it, although the listing does suggest high power capacity but i haven't found a comprehensive data sheet yet.
                                  https://cpc.farnell.com/c/cable-leads-connectors/connectors/circular-multipole-connectors/industrial-circular-connectors?brand=amp-te-connectivity
                                  Any thoughts?
                                  Cheers
                                  Barry M
                                  Polar Duet3 Mini + 1HCL
                                  https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                                  Wanhao D4S: Duet2
                                  https://forum.duet3d.com/post/296755
                                  K40 Laser, Duet2
                                  https://forum.duet3d.com/post/312082
                                  Wanhao D5S
                                  https://www.youtube.com/CNCModellerUK
                                  • o_lampeundefined
                                    o_lampe @CNCModeller
                                    @cncmodeller
                                    Those AMP connectors are huge compared to MicroFit. Doesn't matter, if they don't sit in the cable-chain.
                                    CNCModellerundefined 1 Reply Last reply Reply Quote 0
                                      Have you tried https://de.farnell.com/search?st=molex microfit ?
                                        CNCModeller @o_lampe
                                        @o_lampe yeah they were intended as a single bulkhead connection mounted on the structure of my radial axis assembly.
                                        Wanhao D4S: Duet2
                                        K40 Laser, Duet2
                                        Wanhao D5S
