    Software package 3.3beta3 released
    Beta Firmware
    34
    96
    10.8k
      dc42 administrators @droftarts
      The support in RRF is intended for driving the LEDs on 7567 displays, however I think it should work without a display being configured provided that you don't try to use drivers 10 and 11. You will need to level shift the signal from 3.3v to 5V.
      nmsmith89undefined TheBasedDogeundefined 2 Replies Last reply Reply Quote 0
      • nmsmith89undefined
        nmsmith89 @dc42
        The RGBW Neopixels don't seem to work in 3.3b3 even though it's in the release notes. Is it not implemented yet or am I doing something wrong?
          dc42 administrators @nmsmith89
          @nmsmith89, it is implemented. There are new M150 X parameter values for RGBW. I have just updated the documentation at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M150_Set_LED_colours.
          nmsmith89undefined 1 Reply Last reply Reply Quote 0
          • TheBasedDogeundefined
            TheBasedDoge @dc42
            @dc42 I do have a PanelDue 5" display, but i dont have anything on stepper 10/11. so do I just need to use pin 5? what fw config changes are required?
              nmsmith89 @dc42
              @dc42 Thank You!!!
              • Diamondbackundefined
                Diamondback @SIam
                @siam Finally managed to get the accelerometer connected... I'm currently using about 3m of USB 3 extension cable and that seems to work ok, was just a lot of pain to wire up...
                It looks like shielding is way more effective here than just twisted wire pairs (which I tried before and didn't work on its own)
                dc42undefined 1 Reply Last reply Reply Quote 1
                  dc42 administrators @Diamondback
                  @diamondback said in Software package 3.3beta3 released:
                  The SPI frequency is currently 4MHz. I'll try reducing it, that may make it easier to use long cables.
                    Diamondback
                    @dc42 said in Software package 3.3beta3 released:
                    Thanks for looking into this. Is there any advantage to the higher frequency in practical use? If so, maybe offer te higher speeds as an option still?
                      3.3RC1 will default to 2MHz and allow the frequency to be changed using a new Q parameter on the M955 command.
                      • snagit007undefined
                        snagit007
                        Thanks all for your great work!
                        I have updated my BLV Cube with Duet3 and SBC to 3.3beta3 and everything works flawlessly. It is just incredible that the software can support individual configured systems providing first class prints.
                        • MintyTreborundefined
                          MintyTrebor
                          I have had a couple of instances of SBC users experiencing issues with the duetpluginservice not running by default, which is preventing 3rd party plugins being installed/run.
                          Running
                          sudo systemctl enable duetpluginservice
                          and rebooting the sbc seems to clear the issue.
                          Not sure if its the right thing to do or not.
                          Adding it here by way of feedback.
                          NodeDSF - Native Node-Red integration with Duet boards.
                          BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                          ReleaseMgr - Duet update info inside DWC.
                          Repo
                          • A Former User?
                            A Former User @Phaedrux
                            @phaedrux said in Software package 3.3beta3 released:
                            @thebaseddoge said in Software package 3.3beta3 released:
                            I see that Duet 2 can now do neopixel LEDs, which is super cool, but how do I wire them up and configure? Which pins should I use?
                            https://duet3d.dozuki.com/Wiki/Neopixel_and_DotStar_LEDs
                            Does it support only original Adafruit NeoPixel stripes or other brands of RGBW stripes?
                            cosmowaveundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • cosmowaveundefined
                              cosmowave @A Former User
                              @thedragonlord In the dozuki is written:
                              Duet 3 MB6HC supports both DotStar and NeoPixel LED strips. Duet 3 Mini supports NeoPixel only. Duet 2 and Duet Maestro do not support these LED strips directly, but you can use an Arduino to interface them to a Duet.
                              Mankati FSXT+, DeltaTowerV2, E3D MS/TC
                              • A Former User?
                                A Former User @cosmowave
                                @cosmowave said in Software package 3.3beta3 released:
                                sure but some rows below:
                                Connecting NeoPixel strips to Duet 2 Wifi or Ethernet
                                A signal for controlling Neopixel strips can be output on pin 5 of the CONN_LCD connector provided that you do not have external stepper drivers connected to CONN_LCD. The signal level is 3.3V so you need to level shift it to 5V. A non-inverting 74HCT series gate or buffer such as 74HCT08 can be used to do this.
                                RGB NeoPixels draw up to 60mA per LED. RGBW ones draw up to 80mA per LED. Therefore the Duet cannot provide enough power for an LED strip unless the number of LEDs in the strip is small (for example 16 RGB or 12 RGBW LEDs). For longer strips you must provide external 5V power to the strip.
                                  dc42 administrators @A Former User
                                  @thedragonlord said in Software package 3.3beta3 released:
                                  Any brand using the WS2812B or compatible chips should work.
                                  • A Former User?
                                    A Former User @dc42
                                    excellent thanks
                                    • gloomyandyundefined gloomyandy referenced this topic
                                    • System referenced this topic
                                    • janjohundefined janjoh referenced this topic
                                    • tfjieldundefined tfjield referenced this topic
                                    • RogerPodacterundefined RogerPodacter referenced this topic
