    Software package 3.3beta3 released
    Beta Firmware
    34
    96
    11.0k
    • Lorisundefined
      Loris
      Hi all, i have a strange behaviour using rrf 3.3b3.
      I printed a file already in my SD (when i use 3.3b1).
      This file is a simple testing cube sliced in simplify3d having 1 perimeter only.
      Printed with 3.3b1 is perfect.
      Printed with 3.3b3 seems that first layers are smaller than normal.
      I also confirm that the probe z-offset with 3.3b3 seems different, it print al little far away from bed, 3.3b1 perfect.
      Same config.g and same configuration.
      I only changed the firmware.
      To do a test, i rollback to 3.3b1 and it prints perfectly the same file.
      Here a picture about the print with 3.3b3
      matt3oundefined 1 Reply Last reply Reply Quote 0
      • matt3oundefined
        matt3o @Loris
        @loris could it be a temperature issue? have you tried to re-run the pid calibration?
        • Diamondbackundefined
          Diamondback @sebkritikel
          @sebkritikel said in Software package 3.3beta3 released:
          @dc42 ~~Alright, what am I doing wrong? Likely something simple
          Duet2 Wifi +Duex5
          Duet Web Control 3.3.0-b3
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.3beta3 (2021-04-22)
          Wiring diagram (tried some variations of this, including using duex.cs5, duex.cs6). Green LED on each of the boards tested.~~
          M955 P0 C"spi.cs3+spi.cs4"
          Error: M955: Accelerometer not found on specified port
          Update - I'm quite confident the cable assembly was good, but likely was too long (~11ft). Trimmed 4ft off the Duet side, re-terminated and now we're good to go.
          I have the same issue, but much shorter wiring already. (about 1.5m in total or so)
          @dc42 are there any known limitations to SPI cable length and/or crimp connection quality?
          • PaulHewundefined
            PaulHew
            Noticed that the Layer Chart does not display info.
            P.
            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
            Stephen6309undefined 1 Reply Last reply Reply Quote 0
            • Stephen6309undefined
              Stephen6309 @PaulHew
              @paulhew If you are using PrusaSlicer you need to add to the Before layer change G-Code: ;LAYER:[layer_num]
              It's under Custom G-Code in Printer Settings.
              PaulHewundefined Sytac072undefined 2 Replies Last reply Reply Quote 1
              • PaulHewundefined
                PaulHew @Stephen6309
                @stephen6309 said in Software package 3.3beta3 released:
                LAYER:[layer_num]
                Thanks, appreciate the info.
                I will try it after this tophat.
                Regards,
                Paul
                • Sytac072undefined
                  Sytac072
                  Hello... I have tried to upgrade my Tevo delta today from RRF 3.2.2 to 3.3 beta 3 but after the upgrade, the extruder disappeared from the DWC and from the paneldue.
                  This is how the motors are configured:
                  I don't what is wrong.
                    Stephen6309 @Sytac072
                    @sytac072 I have a 1LC with my 6HC & Mini 5+, mine is M584 X0.0 Y0.1 Z0.2 E121.0
                    If you have a Duet 3, try adding 0. to the drive numbers. That's what the reprapfirmware configurator does.
                    Sytac072undefined 1 Reply Last reply Reply Quote 0
                    • Sytac072undefined
                      Sytac072 @Stephen6309
                      @stephen6309 Thank you very much for your tip. I have a duet2 Wifi. I am not sure if your settings may also work on mine.
                        @sytac072 Have you tried the good ol' turnoff/turnon fix? 🙂
                        The config.g is still valid?
                        • Sytac072undefined
                          @stephen6309 Yes, I did it... The config.g is the same I was using with RRF 3.2.2. I reinstalled it and the printer was working again.
                          SIamundefined 1 Reply Last reply Reply Quote 0
                          • SIamundefined
                            SIam @Sytac072
                            @dc42 I had the same issue with "long" cable to the Accelerometer long means in my case 1.5 meters with this cable the Accelerometer doesn't work 😞
                            25.4.2021, 14:00:31	M955 P0 C"spi.cs3+spi.cs4"
                            I have measured the cable with all the crimps and this is ok. After that I have build a second cable with ca 40 cm and connected this to the Accelerometer and the duet board and surprise the Accelerometer works!
                            25.4.2021, 16:37:37	M955 P0 C"spi.cs3+spi.cs4"
                            Accelerometer 0 with orientation 20 samples at 1344Hz with 10-bit resolution
                            But i can't use it because the cable is to short to move the print head. Now my question can we do something with pull up, pull down or a capacitor to use "Long" cables?
                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                            Duet WiFi 1.02 or later + DueX5
                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                            Duet WiFi Server: 1.26
                            Duet Web Control 3.4.0beta4 (2021-09-27)
                            pkosundefined 1 Reply Last reply Reply Quote 0
                            • Nurgelrotundefined
                              Nurgelrot
                              Okay I'm lost. In SBC Mode. I've switched my SBC software repository to unstable and atp-get update|grade.
                              DWC is listing Duet Web Control 3.3.0-b3 and
                              Machine is showing :
                              Board: Duet 3 Mini 5+ (Mini5plus)
                              DSF Version: 3.3-b3
                              Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.2.2 (2021-02-11)
                              M115:
                              FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-11
                              So everything but the board is upgraded what did I miss?
                              the right package is installed on the PI:
                              ii reprapfirmware 3.3-b3-1 all RepRapFirmware Software Bundle
                              Rebooting nothing working.
                                Phaedrux Moderator @Nurgelrot
                                @nurgelrot Try updating the mini5 firmware directly to get back in sync with DSF.
                                https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Firmware
                                Nurgelrotundefined 1 Reply Last reply Reply Quote 0
                                • pkosundefined
                                  pkos @SIam
                                  @siam I know it sounds janky, but wrap your wire in aluminum foil or any other kind of shielding. Should work then.
                                  Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                                  SIamundefined 2 Replies Last reply Reply Quote 0
                                  • SIamundefined
                                    SIam @pkos
                                    @pkos that will not work so easy the cable is inside a Energy chain, but I think I have some shielded cable here if so i will try a test with it
                                      Nurgelrot @Phaedrux
                                      @phaedrux Well that was a major PITA but they are now in sync again. Had to tear my lab apart and move crap all over the place. If I had wanted to make direct connections to the printer board I would have used the Wifi version of the card. But I got there in the end. Any thoughts on why this happened? Not looking forward to that next time I update.
                                        droftarts administrators @Nurgelrot
                                        @nurgelrot I think by ‘directly’ @Phaedrux didn’t mean by USB; you should have been able to send M997 S0 (the matching firmware should have downloaded with DSF), or uploaded the firmware file in DWC, and it would ask if you want to update it. I’ve done this a lot recently, when testing firmware.
                                          Nurgelrot @droftarts
                                          @droftarts Well sadly I'm not a walking encyclopedia of gcode... But I'll file that one away if it happens again...
                                          • nmsmith89undefined
                                            nmsmith89
                                            After upgrading (SBC) it looks like neither variables nor RGBW Neopixels work which sucks because I've been dying for both!
                                            @nurgelrot said in Software package 3.3beta3 released:
                                            I'm in the same boat where the firmware doesn't upgrade. I'm considering just reflashing the SD card but that would be a pain.
