    RRF 3.4 input shaping preview available
    Beta Firmware
    25
    205
    24.9k
      dc42 administrators @PCR
      @pcr said in RRF 3.4 input shaping preview available:
      @dc42 how does klipper handle this? only curious how its done? are they syncing axis then?
      Good question! The Klipper docs mention "smoothing" but don't elaborate. They also suggest use of low acceleration.
      PCRundefined 2 Replies Last reply Reply Quote 0
      • PCRundefined
        PCR @dc42
        @dc42 https://github.com/KevinOConnor/klipper/blob/master/klippy/chelper/kin_shaper.c
        static double
        shaper_xy_calc_position(struct stepper_kinematics *sk, struct move *m
                                , double move_time)
            struct input_shaper *is = container_of(sk, struct input_shaper, sk);
            if (!is->sx.num_pulses && !is->sy.num_pulses)
                return is->orig_sk->calc_position_cb(is->orig_sk, m, move_time);
            is->m.start_pos = move_get_coord(m, move_time);
            if (is->sx.num_pulses)
                is->m.start_pos.x = calc_position(m, 'x', move_time, &is->sx);
            if (is->sy.num_pulses)
                is->m.start_pos.y = calc_position(m, 'y', move_time, &is->sy);
            return is->orig_sk->calc_position_cb(is->orig_sk, &is->m, DUMMY_T);
        i am no coder but looks like the calculating it
        • PCRundefined
          PCR @dc42
          @dc42 ah i think klipper can only use one shaper for x and y but diffrent freq. 😉
          So i think different freq. per axis should be possible?
            @pcr if you use different frequencies per axis, the axes will move out of step. But the amount of out-of-step movement may be small enough to be acceptable, especially if the accelerations are low. It makes no difference whether the same or different input shapers are used per axis.
            CR3Dundefined 1 Reply Last reply Reply Quote 0
            • CR3Dundefined
              CR3D @dc42
              Sorry dc42 I have to contradict you. Without doing X and Y separately, it won't work properly and properly. Out of interest, I looked at clippers last week and took a measurement. As a result you get the following graphs and also the suggestions for the frequency and the shaper. and these are always different for X and Y.
              In addition, you will also receive a recommendation for the respective max.accelerations per axis ...
              Christian from CR-3D
              Homepage:
              www.cr-3d.de
              Facebook:
              https://www.facebook.com/cr3d.official
              Our Discord Server
              https://discord.gg/SxRaPNuRdA
              Thingiverse Profile:
              https://www.thingiverse.com/cr-3d_official/about
                dc42 administrators @CR3D
                @cr3d said in RRF 3.4 input shaping preview available:
                Which bit of my post are you contradicting?
                • skrotzundefined
                  skrotz @dc42
                  @dc42 I was able to do a print and captured some stepper errors with debug output. Included is my config.g, the gcode I was printing, and the output logs. Hopefully this helps diagnose the issues some of us are having with RRF 3.4. This was with PA disabled , and input shaping enabled via M593 P"ei2" F41 S0.10
                  config.g
                  printOutput.txt
                  CFFFP_xyzCalibration_cube_205.gcode
                  dc42undefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @skrotz
                    @skrotz thanks for that, it shows clearly some step errors on the extruder drive and that PA was not involved. I will investigate.
                    • CR3Dundefined
                      CR3D @dc42
                      I ment this part here:
                      "if you use different frequencies per axis, the axes will move out of step. But the amount of out-of-step movement may be small enough to be acceptable, especially if the accelerations are low. It makes no difference whether the same or different input shapers are used per axis."
                      I think it is absolutely necessery and with klipper it also works...
                      Just for information 🙂 We want the same perfect shaper here in RRF 🙂
                      Homepage:
                      www.cr-3d.de
                      Facebook:
                      Our Discord Server
                      • psychotik2k3undefined
                        psychotik2k3
                        i really think that at least different frequencies should be possible because i really don't see how the frequency should be the same on X and Y as the weight in movement is not the same at all, and thus the moment.
                        • oliofundefined
                          oliof @psychotik2k3
                          @psychotik2k3 could still be that the frequencies are close enough that the wider band from one configuration is enough to improve both X and Y
                          • Dudek23undefined
                            Dudek23 @dc42
                            @dc42 This is exactly what happens in Klipper at high smoothing values. In recent versions, during the calibration procedure, the software gives the recommended acceleration values ​​so that the loss of accuracy is not noticeable. I think it is definitely worth testing how it will look in rrf, even for duet3 only, maybe the loss of accuracy will be acceptable.
                              @skrotz said in RRF 3.4 input shaping preview available:
                              config.g
                              printOutput.txt
                              With your files I was able to identify and reproduce the problem. It is now fixed and I can run your test print using your configuration without errors.
                              We will release a new beta with input shaping within the next few days.
                              skrotzundefined 1 Reply Last reply Reply Quote 0
                              • skrotzundefined
                                skrotz @dc42
                                @dc42 great! More than happy to test out a pre-release version of it if you put it on the dropbox 🙂
                                  I've just put the Duet 2 version at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0. Please try it with care, this doesn't just contain a bug fix for that issue, the units used internally to measure speeds and accelerations have changed. It works OK so far on my delta, but I haven't tried it on a Cartesian or CoreXY machine yet.
                                  • skrotzundefined
                                    skrotz @dc42
                                    @dc42 I installed the new firmware, did some basic homing and movement tests, and all seemed fine, so I went for broke and printed out the calibration cube with both input shaping and pressure advance enabled.. no clunking issues or anything that seemed amiss during the print. However, I still have some extrusion zits (in the same places as before, seems caused by input shaping) and the print looked extremely similar to a non PA enabled print, with slightly bulging corners. M122 after showed no errors but 2 hiccups.
                                    == Move ===
                                    DMs created 83, segments created 33, maxWait 125385ms, bed compensation in use: mesh, comp offset 0.000
                                    === MainDDARing ===
                                    Scheduled moves 11545, completed moves 11545, hiccups 2, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                    === AuxDDARing ===
                                      @skrotz thanks for your fast feedback! It has prompted me to check the balance between axis movement and extrusion again, and I have found an issue that may explain those symptoms. More soon.
                                        @skrotz I have updated the binary at https://www.dropbox.com/sh/ja08b7qdzsl8kjc/AAAwUbkN2XJvurq5CuQTgx5Wa?dl=0 to fix the extrusion issue that I identified.
                                        Adrian52undefined skrotzundefined 3 Replies Last reply Reply Quote 0
                                        • Adrian52undefined
                                          Adrian52 @dc42
                                          @dc42 just done calibration cubes, with no extruder problems and no hics or step errors, but appears that pa is not working for me with the latest 3.4
                                          • skrotzundefined
                                            skrotz @dc42
                                            @dc42 Unfortunately things look pretty much the same for me with the newest code. Some small extrusion zits or bubbles on the print, and PA doesn't seem like it is working. I did get a few step errors also it looks like, printing out a calibration cube:
                                            DMs created 83, segments created 35, maxWait 140417ms, bed compensation in use: mesh, comp offset 0.000
                                            === MainDDARing ===
                                            Scheduled moves 11545, completed moves 11545, hiccups 2, stepErrors 3, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                            === AuxDDARing ===
                                            Things didn't seem or sound better or worse than previously. There are a couple of clunks I've heard during the prints I did on this firmware and the previous one.. I wasn't sure but now that I've done another print I'm fairly certain towards the end of the print in a couple of spots there was a distinct "clunk" noise, at the same place in both prints.
                                            I will see if I can capture step error data again with this new firmware.
