    What are the next major 3d printing developments?
    3D Printing General Chat
    8
    21
    1.3k
    • Blacksheep99undefined
      Blacksheep99
      Bit of an open question and I have my own thoughts. I think in recent years FDM printing has reached a stage where even cheap machines can deliver quality. Spend a bit of money and you get reliable quality. This year seems to be all about speed. So logically it's speed with good quality we are moving towards.
      I want to look beyond that and get others insight. My personal thoughts are the real developments will come when we move away from machines based on other technologies and the hardware is developed exclusively with 3d printing in mind. Motion systems etc all come from other industries and whilst they transfer well can we improve if we design something with FDM as the sole purpose?
      Beyond that I think the biggest advancement is to come from the use of sensor (such as we see with input shaping) and AI. This combined with a slicer that can analyse a part and determine what it's indented purpose is then slice it in a way that is prints optimally should be the goal in the next 2-3 years. Machine learning has to play a part in this much as it does now with 2d photos. Just my thoughts, love to hear more and start the debate.
      • oliofundefined
        oliof @Blacksheep99
        @blacksheep99 I think AI is not going to be as important as proper modeling and physics simulation. Most behavior of the relevant part is either predictable or directly measurable, so either is a pre-defined, or post-evaluated control loop.
        I also am of the opinion that "speed" and "quality" are only marginally related. Printing slow and hot changes surface quality and inter layer adhesion considerably (for the better), and either you print uniques which means some extra hours aren't a problem, or you need to print on schedule and repeatedly because it's your business and then a number of printers has considerable advantages over a single fast one.
        I believe we will see some material science related improvements on the extrusion system (note that e3d recently announced phasing out brass nozzles), and some technological advances on filament feeders once someone innovates beyond dual gear extrusions (picking up on ideas from 2014ish).
        And then, returning to the initial point, even without mythological AI, firmware will make more use of readily available compute capacity which simpy didn't exist in consumer devices a scant couple years back ...
        Blacksheep99undefined 1 Reply Last reply Reply Quote 1
          Blacksheep99 @oliof
          @oliof Interesting points. I agree with many. I guess where I am coming from with regards to the slicing side is right now you need a solid understanding of the principles of 3D printing in order to make changes to the print settings in a slicer. Maybe a slicer will be a thing of the past? (I don't believe this just trying to look ahead).
          If 3D printing is to be democratised then it has to move beyond the 'enthusiast' to the point where someone can get or make a model and then print it reliably on their printer with minimal fuss and knowledge of the process behind it. Agree?
          • Nuramoriundefined
            Nuramori
            I’m excited to see development in non-planar technology, especially for my industry (architecture/design).
            • o_lampeundefined
              o_lampe
              I hope we'll see clay printers/slicers which build a mold-negative of the parts we want. That way we skip the step of printing a lost-PLA part.
              Furthermore I can't wait to try out multi-gcode stream features, where two or more tools work on one part simultaneously.
              fcwiltundefined 1 Reply Last reply Reply Quote 1
              • 3DPMicroundefined
                3DPMicro
                In the area of FFF, I wouldn't consider it a major development rather a current technology becoming more mainstream is the ability to process materials that require a high temperature (>180c) build environment. This will drive down material cost but more importantly afford the ability to create components with properties equaling, and in some cases far exceeding those of injection molded parts.
                Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                • deckingmanundefined
                  deckingman
                  Assuming we are talking about consumer or hobbyist machines, then IMO no major developments will have much effect until we move away from what is essentially a robot controlled hot melt glue gun. While we are stuck with that, we are stuck with printing at the speed at which some mushrooms can grow. There has to be a better way................
                  Blacksheep99undefined fcwiltundefined 2 Replies Last reply Reply Quote 3
                    Blacksheep99 @3DPMicro
                    @3dpmicro said in What are the next major 3d printing developments?:
                    I believe some patents have recently lapsed regarding heated enclosures so let's see what machines are developed as a result. If the market increases then materials should come down if quantities increase (i hope)
                    3DPMicroundefined 1 Reply Last reply Reply Quote 0
                      Blacksheep99 @deckingman
                      @deckingman fair point! 😀
                      peter247undefined 1 Reply Last reply Reply Quote 0
                      • peter247undefined
                        peter247 @Blacksheep99
                        @blacksheep99 I was think of rushing out and getting a KG of this PEEK 9581 filament .... https://technologyoutlet.co.uk/collections/premium-3d-printer-filament/products/primaselect-luvocom-3f-peek-9581-1-75mm-500g-natural
                        NOT !!!!!!!
                        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                        • fcwiltundefined
                          fcwilt @o_lampe
                          @o_lampe said in What are the next major 3d printing developments?:
                          Wouldn't that be easily done in whatever CAD program was used to create the model?
                          • fcwiltundefined
                            fcwilt @deckingman
                            @deckingman said in What are the next major 3d printing developments?:
                            Assuming we are talking about consumer or hobbyist machines, then IMO no major developments will have much effect until we move away from what is essentially a robot controlled hot melt glue gun. While we are stuck with that, we are stuck with printing at the speed that which some mushrooms can grow. There has to be a better way................
                            I use Shapeways to make certain part for me.
                            Are you familiar with their printers that use an approach similar to resin printers but using a powder instead of a liquid?
                            Can you envision those ever being affordable at the hobby level?
                            Thanks.
                            Nuramoriundefined 1 Reply Last reply Reply Quote 0
                            • Nuramoriundefined
                              Nuramori @fcwilt
                              @fcwilt I use jawstec for MJf printing certain things, but I would kill for a home version of the technology.
                              Maybe if I win the lottery I’ll splurge and get a 600k MJF setup 🙂
                              • fcwiltundefined
                                fcwilt @Nuramori
                                @nuramori said in What are the next major 3d printing developments?:
                                I don't know what either of those things are.
                                Please elaborate.
                                • Nuramoriundefined
                                  Nuramori @fcwilt
                                  @fcwilt jawstec is a similar printing company like shapeways. Both use Multijet Fusion technology from HP (powdered nylon) to print. It’s shortened to MJF. It’s similar to SLS in that regard. It’s supposed advantage is the material strength is equal in all axis, vs SLS is technically weaker in the z axis vs x and y. Same or better accuracy.
                                  • 3DPMicroundefined
                                    3DPMicro @Blacksheep99
                                    @blacksheep99 Yes, the Stratasys heated build chamber patent with external motion system is the main one that expired, finally after a 1 year extension.
                                    • fcwiltundefined
                                      fcwilt @Nuramori
                                      Thanks. I didn't recognize MJF but I have had parts printed with it.
                                      Shapeways seems to have another printer that does something similar, as their "Versatile Plastic" was the first type I used and the parts appear much the same as the MJF parts.
                                      • Nuramoriundefined
                                        Nuramori @fcwilt
                                        @fcwilt Yeah, their "versatile plastic" is SLS - very good. I've had them make some parts for me with that had to be larger than the limits of MJF, and that required the other process.
                                        • oliofundefined
                                          oliof @Nuramori
                                          There are a bunch of Powder SLS DIY machines, but the process is messy and wasteful.
                                          https://www.instructables.com/DIY-SLS-3D-Printer/
                                          https://github.com/MillerLabFTW/OpenSLS
                                          https://www.projectopenfuse.com
                                          And some others I can't find right now.
                                          o_lampeundefined 1 Reply Last reply Reply Quote 1
                                          • o_lampeundefined
                                            o_lampe @oliof
                                            @oliof
                                            ...who needs multitool FDM printers when you can fuse a whole layer at once 😁
                                            I've seen a video, where a guy in full_body_suit removed the excessive powder. YUCK
                                            Not my style of DIY printer
