    Duet 3 Mini 5+ for a Voron V2.4?
    25
    1822
    • zapta
      zapta last edited by zapta
      Hi everybody, I am building a Voron V2.4 and need to pick the electronics. After reading in another thread here I tend to use:
      • DUET 3 MINI 5+
      • DUET 3 EXPANSION MINI 2+
      • No SBC. Using the Wifi of the MINI 5+.
      • Independent Wyze camera.
      • PanelDue (from my old printer).
      My questions to you are:
      1. Is this a sufficient and reasonable configuration for Voron V2.4?
      2. Will I be able to hook an accelerometer for the upcoming input shaper?
      3. Any reason to go instead with a different Duet configuration?
      4. Any other consideration I should be aware of?
      Components used:
      • 4 x Z axis https://www.omc-stepperonline.com/nema-17-bipolar-59ncm-84oz-in-2a-42x48mm-4-wires-w-1m-cable-and-connector.html
      • X,Y motors https://www.omc-stepperonline.com/nema-17-bipolar-59ncm-84oz-in-2a-42x48mm-4-wires-w-1m-cable-and-connector.html
      • Extruder motor: https://www.omc-stepperonline.com/nema-17-bipolar-1-8deg-16ncm-22-6oz-in-1a-3-7v-42x42x20mm-4-wires.html?search=17HS08-1004S
      • Z probe https://www.aliexpress.com/item/32803870919.html
      • 3 end stop microswitches (x, y, z)
      • Fans x 2 (material and heatshink)
      • 40W heater
      • 100k thermistor (nice to have an option for a higher temp sensor)
      • 110VAC heatbed with an Omron SSR.
      • 24V supply.
      • Emergency power cutoff mechanical relay (similar to PS-ON on Duet2)
      • Nice to have a few more free i/o lines, e.g. for camera timelapse trigger, RGB leds, etc.
      dc42 DIY-O-Sphere 2 Replies Last reply Reply Quote 0
        dc42 administrators @zapta last edited by
        @zapta that looks good to me, assuming TMC2209 drivers are adequate to power the motors in the Voron, and you are happy to fan-cool the Duet.
        Have you considered using a tool board mounted on the print head? This would greatly reduce the amount of wiring to the print head, and version 1.1 tool board includes the accelerometer.
        zapta 3 Replies Last reply Reply Quote 0
        • DIY-O-Sphere
          DIY-O-Sphere @zapta last edited by DIY-O-Sphere
          @zapta
          A friend is building a 2.4. Out of mind that is exactly the same HW.
          He will use a TB V1.1 and has designed an holder for the Afterburner.
          I recommended not to upgrade the existing Duet Wifi with a Duex but to replace it with the Mini + TB.
          This got a bit more expensive but as @dc42 mentioned much easier to wire and more up to date.
          I get in trouble when this does not work in the Voron....
          For me it works in a HEVO with smaller motors and Bltouch...
          (UTC+1)
          • zapta
            zapta @dc42 last edited by zapta
            Thanks @dc42. I considered the tool board idea but it may be too big to fit nicely. The Voron is a complete at tight design with great focus on aesthetics. 😉 I presume that the toolboard would be OK with the enclosed and normal than usual Voron chamber. As for the TMC2209, this is also what the stock Voron recommend so I presume they are all the same or does the heatsinks that come with the Chinese TMC2209 makes them more heat tolerant?
            As for fan cooling of the Mini 5+, is there a simple way to determine if it's sufficient? E.g. MCU temperature? Anything else? (The Voron 2.4 electronics is below the printing chamber and has a few fans on the skirt.
            @DIY-O-Sphere, yes, I plan to get a new Mini 5+ plus two drivers plugin module. This will provide better RGB LEDs support over the Duet 2 😉
            vs
            DIY-O-Sphere pixelpieper 2 Replies Last reply Reply Quote 0
            • DIY-O-Sphere
              @zapta
              Other approach...I am alowed to show some pictures...not yet tested
              Without inserts
              Perhaps a little more distance needs to be provided for the cooling.
              We will get to know it.....
              (UTC+1)
              zapta Th0mpy 2 Replies Last reply Reply Quote 0
              • zapta
                zapta @DIY-O-Sphere last edited by
                @diy-o-sphere, that's a nice location. Would be nice to redesign the toolboard for a perfect fit (dual side components, consolidating connects, shape, location of mounting holes, etc).
                BTW, this is a custom distribution PCB, no components, just connectors. It may come with its own cover design, not sure.
                https://github.com/hartk1213/Voron-Hardware/tree/hartk1213/Voron-Hardware/Afterburner_Toolhead_PCB
                DIY-O-Sphere 1 Reply Last reply Reply Quote 0
                • DIY-O-Sphere
                  @zapta
                  No input shaping...or even more wires for LIS3DH accelerometer.
                  And the wiring with CAN is so brilliant that I would never do it any other way again....
                  (UTC+1)
                  zapta 1 Reply Last reply Reply Quote 0
                  • zapta
                    @diy-o-sphere said in Duet 3 Mini 5+ for a Voron V2.4?:
                    No input shaping.
                    No way to connect an accelerometer to a Mini 5+ for input shaper calibration? That would be a show stopper for me.
                      Phaedrux Moderator @zapta last edited by
                      @zapta said in Duet 3 Mini 5+ for a Voron V2.4?:
                      Mini5+ will work with input shaping. I'm not sure what @DIY-O-Sphere was meaning. Perhaps he meant that if you didn't go with a toolboard 1.1 you'd need to add more wires for the accelerometer as well to get the input shaping.
                      DIY-O-Sphere zapta 2 Replies Last reply Reply Quote 0
                      • DIY-O-Sphere
                        DIY-O-Sphere @Phaedrux last edited by
                        @phaedrux
                        You got it...👍
                        (UTC+1)
                        • zapta
                          zapta @Phaedrux last edited by
                          @phaedrux said in Duet 3 Mini 5+ for a Voron V2.4?:
                          Thanks @Phaedrux. Is it reasonable to mount the accelerometer temporarily for calibration or is a strong argument for having the accelerometer mounted all the time?
                            My understanding is that it's only required for the initial measurements, so could be removed. But that's not to say there won't be some future benefit to having real time accelerometer data.
                            • zapta
                              @phaedrux, thanks.
                              • 3DPMicro
                                3DPMicro last edited by
                                I like the 50w heaters personally. Super fast heat up times. I used to kill one about every 100hrs at 350-380c until I spent a few extra bucks and got one from Slice. If your printing 250 and below the Slice or amazon/Ebay sourced versions will probably last forever.
                                • zapta
                                  zapta @3DPMicro last edited by
                                  @3dpmicro, last time I run PID tuning I got a warning message about a very high max temperature which cause me to be more humble when selecting heater wattage 😉
                                  In my current printer I have a 40W 'only nozzle heater and it still heats faster than the bed.
                                  BTW, I place an order for a Mini5+ and a dual drivers module, so will see how it will go. I am quiet excited about having only a small Wifi board in the Voron, dropping the SBC and the auxiliary 5V power supply. Need to see where to fit that external antenna. Keeping the clean box shape of the frame makes it easier to place it in any orientation while working on it.
                                  3DPMicro 1 Reply Last reply Reply Quote 0
                                  • 3DPMicro
                                    3DPMicro @zapta last edited by
                                    Cant argue with the desire to be safe
                                    • Th0mpy
                                      Th0mpy @DIY-O-Sphere last edited by
                                      @diy-o-sphere Do you have the files for that back-side mount that you'd be willing to share? I'm getting ready to build my Voron 2.4 and I'm adding as many bells and whistles as I can 🙂
                                      Usually the team that scores the most points wins the game.
                                      • DIY-O-Sphere
                                        DIY-O-Sphere @Th0mpy last edited by
                                        @th0mpy
                                        At the moment, my friend is still struggling with the connection of the energy chain. He is currently adjusting the position and size of the chain so as not to lose any space in the x-direction. As soon as this works he will share them.
                                        (UTC+1)
                                        • zapta
                                          Any issue with the Tool Board electronics operating in the enclosed and hotter than usual Voron V2.4 chamber?
                                          Dudek23 1 Reply Last reply Reply Quote 0
                                          • Dudek23
                                            Dudek23 @zapta last edited by
                                            @zapta At 60 degrees in the chamber, it works for me without any problems
                                            • pixelpieper
                                              pixelpieper @zapta last edited by
                                              @zapta This is my solution with the Galileo variant of the clockwork extruder
                                              Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                                              Voron V0.250 / Duet 2 Maestro
                                              jumpedwithbothfeet 1 Reply Last reply Reply Quote 0
                                              • zapta
                                                My Voron V2.4 is working now with a Mini5+2 WiFi, RRF, no SBC and the Mini5 seems to be a very good fit. Coming from Duet2, it has nice touches such as 30 tolerance (for an Omron probe), external antenna, 12V DC/DC for fans, Neo Pixels outputs, small footprint for 7 drivers configuration, and more.
                                                My only complains is the add on +2 drivers board hanging below the main board with. I would prefer to have a single board with 7 drivers.
                                                • jumpedwithbothfeet
                                                  jumpedwithbothfeet @pixelpieper last edited by jumpedwithbothfeet
                                                  @pixelpieper or anybody else, is there anywhere I can download these files for the 1.1v mount?
                                                  #edit. Found semi-hidden in Github! https://github.com/christophmuellerorg/VoronUsers/tree/afterburner_1LC/printer_mods/christophmueller/Voron2-Gallileo-Afterburner-Duet-1LC
                                                  Thanks Jim
                                                  Voron Trident based (4Z) - too much to list!
                                                  • zapta
                                                    After using a Voron 2.4 with a stand alone Duet Mini5+2, I am in the opinion that's an excellent fit. Just saying.
                                                    dc42 1 Reply Last reply Reply Quote 1
                                                      @zapta thanks for confirming this!
