    Duet 3 Mini 5+ for a Voron V2.4?
    25
    2.9k
    • zaptaundefined
      zapta @DIY-O-Sphere
      @diy-o-sphere, that's a nice location. Would be nice to redesign the toolboard for a perfect fit (dual side components, consolidating connects, shape, location of mounting holes, etc).
      BTW, this is a custom distribution PCB, no components, just connectors. It may come with its own cover design, not sure.
      https://github.com/hartk1213/Voron-Hardware/tree/hartk1213/Voron-Hardware/Afterburner_Toolhead_PCB
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphereundefined
        DIY-O-Sphere @zapta
        @zapta
        No input shaping...or even more wires for LIS3DH accelerometer.
        And the wiring with CAN is so brilliant that I would never do it any other way again....
        (UTC+1)
        • zaptaundefined
          zapta @DIY-O-Sphere
          @diy-o-sphere said in Duet 3 Mini 5+ for a Voron V2.4?:
          No input shaping.
          No way to connect an accelerometer to a Mini 5+ for input shaper calibration? That would be a show stopper for me.
            Phaedrux Moderator @zapta
            @zapta said in Duet 3 Mini 5+ for a Voron V2.4?:
            Mini5+ will work with input shaping. I'm not sure what @DIY-O-Sphere was meaning. Perhaps he meant that if you didn't go with a toolboard 1.1 you'd need to add more wires for the accelerometer as well to get the input shaping.
            DIY-O-Sphereundefined zaptaundefined 2 Replies Last reply Reply Quote 0
              DIY-O-Sphere @Phaedrux
              @phaedrux
              You got it...👍
              (UTC+1)
              • zaptaundefined
                zapta @Phaedrux
                @phaedrux said in Duet 3 Mini 5+ for a Voron V2.4?:
                Thanks @Phaedrux. Is it reasonable to mount the accelerometer temporarily for calibration or is a strong argument for having the accelerometer mounted all the time?
                  My understanding is that it's only required for the initial measurements, so could be removed. But that's not to say there won't be some future benefit to having real time accelerometer data.
                  • zaptaundefined
                    zapta @Phaedrux
                    @phaedrux, thanks.
                    • 3DPMicroundefined
                      3DPMicro
                      I like the 50w heaters personally. Super fast heat up times. I used to kill one about every 100hrs at 350-380c until I spent a few extra bucks and got one from Slice. If your printing 250 and below the Slice or amazon/Ebay sourced versions will probably last forever.
                      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                      • zaptaundefined
                        zapta @3DPMicro
                        @3dpmicro, last time I run PID tuning I got a warning message about a very high max temperature which cause me to be more humble when selecting heater wattage 😉
                        In my current printer I have a 40W 'only nozzle heater and it still heats faster than the bed.
                        BTW, I place an order for a Mini5+ and a dual drivers module, so will see how it will go. I am quiet excited about having only a small Wifi board in the Voron, dropping the SBC and the auxiliary 5V power supply. Need to see where to fit that external antenna. Keeping the clean box shape of the frame makes it easier to place it in any orientation while working on it.
                        3DPMicroundefined 1 Reply Last reply Reply Quote 0
                        • 3DPMicroundefined
                          3DPMicro @zapta
                          Cant argue with the desire to be safe
                          • Th0mpyundefined
                            Th0mpy @DIY-O-Sphere
                            @diy-o-sphere Do you have the files for that back-side mount that you'd be willing to share? I'm getting ready to build my Voron 2.4 and I'm adding as many bells and whistles as I can 🙂
                            Usually the team that scores the most points wins the game.
                              DIY-O-Sphere @Th0mpy
                              @th0mpy
                              At the moment, my friend is still struggling with the connection of the energy chain. He is currently adjusting the position and size of the chain so as not to lose any space in the x-direction. As soon as this works he will share them.
                              (UTC+1)
                              • zaptaundefined
                                zapta @DIY-O-Sphere
                                Any issue with the Tool Board electronics operating in the enclosed and hotter than usual Voron V2.4 chamber?
                                Dudek23undefined 1 Reply Last reply Reply Quote 0
                                • Dudek23undefined
                                  Dudek23 @zapta
                                  @zapta At 60 degrees in the chamber, it works for me without any problems
                                  • pixelpieperundefined
                                    pixelpieper @zapta
                                    @zapta This is my solution with the Galileo variant of the clockwork extruder
                                    Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                                    Voron V0.250 / Duet 2 Maestro
                                    jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                                    • zaptaundefined
                                      zapta @dc42
                                      My Voron V2.4 is working now with a Mini5+2 WiFi, RRF, no SBC and the Mini5 seems to be a very good fit. Coming from Duet2, it has nice touches such as 30 tolerance (for an Omron probe), external antenna, 12V DC/DC for fans, Neo Pixels outputs, small footprint for 7 drivers configuration, and more.
                                      My only complains is the add on +2 drivers board hanging below the main board with. I would prefer to have a single board with 7 drivers.
                                      • jumpedwithbothfeetundefined
                                        jumpedwithbothfeet @pixelpieper
                                        @pixelpieper or anybody else, is there anywhere I can download these files for the 1.1v mount?
                                        #edit. Found semi-hidden in Github! https://github.com/christophmuellerorg/VoronUsers/tree/afterburner_1LC/printer_mods/christophmueller/Voron2-Gallileo-Afterburner-Duet-1LC
                                        Thanks Jim
                                        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
                                        • zaptaundefined
                                          zapta @dc42
                                          After using a Voron 2.4 with a stand alone Duet Mini5+2, I am in the opinion that's an excellent fit. Just saying.
                                            dc42 administrators @zapta
                                            @zapta thanks for confirming this!
